Hi all
I recently found your site and must commend all for thier fantastic contributions.
I am starting a 1975 rubber bumper conversion down here is Australia. I have purchased some Hugger exhaust and a fresh 3.5 Rover engine with cam, Offenhauser, webber etc.
I have read the conversion pages but still have the following questions:
1. Do i still have to modify the bulk head if I am using the standard gearbox with the Costello adaptor plate?
2. Do I have to alter the steering shaft/Angle to clear the block?
All coments would help as I am finding my way as I go! I know the supra / rover box would be a better box but I am trying to keep the conversion as simple as posible as I have some time constraints.
Thanks again from OZ
Brad
Hi Brad - welcome to the message board!
I think you're going to find out that the bulkhead and steering shaft probably don't need modification - depending on your motor-mounts - but your car is different-enough from mine that I'm sure someone else will give you more definitive answers.
This car is pretty similar in spec:
Martyn Harvey's red 1977 MGB with Buick 3.5L V8 (http://www.britishv8.org/MG/MartynHarvey3.htm) (17 photos)
(Notice that this car has block-huggers until recently... some of the photos are "before" and some "after".)
Martyn checks in pretty often - but I've been keeping him busy writing a new "Canadian Corner" column. I'm sure you'll get a nice range of good advice shortly.
