General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: Neil Verity on September 18, 2008, 12:29:39 PM
Title: Crankshaft Identification
Post by: Neil Verity on September 18, 2008, 12:29:39 PM
I have recently aquired 3 crankshafts as part of a package deal.  All 3 are stamped "Arma Steel".  2 have the ID number 1357899 stamped on it, which from Atlantacrankshaft.com seems to be a Buick 300 crank that has been turned down to fit a Buick block (main journals ~ 2.3 inch).  The other has an ID number 1183645.  It looks like an early original Buick/rover crank but I can not match up the ID #.  Any help verifying the Buick 300 # and of course the identity of the "unknown" crank would be appreciated.
Neil
Title: Re: Crankshaft Identification
Post by: NixVegaGT on September 21, 2008, 01:36:48 AM
Does it look the same as the other two? Same stroke?
Post by: Neil Verity on September 29, 2008, 02:33:52 PM
Ok,
Turns out the 1357899 cranks are from a Buick 300 motor.  The other one (#1183645) is still unknown but does have a smaller throw than the Buick 300 cranks.
Neil
