General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: Dukebloodhound on April 25, 2014, 04:30:36 PM
Title: High Oil Pressure
Post by: Dukebloodhound on April 25, 2014, 04:30:36 PM
Hi, my name is Jeff and I am writing in from Utah.  I have never used a message board before, so forgive me if I do not know what I am doing!  I have a 1978 MGB that I have been converting to a Rover V8 over the last couple of years.  I have encountered an issue which I am looking for advice on.  Here is what I have:  1997 Rover 4.0, Buick 215 front timing cover, D & D high volume oil pump, Buick Metric pump cover, remote oil filter on 1/2 inch ID lines.  I broke the engine down and replaced the rings, main bearings, big end bearings, lifters and the cam.  The engine started well and ran total for about an hour before the issues developed.  Here is the problem, at idle, the oil pressure runs about 50 psi.  As you increase the rpm's, the oil pressure rises also.  I goes up to 100 psi at around 3200 rpm's.  I have not taken the engine over this due total fear!  After the engine has run for 5 minutes or so, I start to hear a lite clicking noise coming from the front timing cover.  It is about 2 clicks per second.  At this point the oil pressure starts to drop to less than 10 psi at all rpm range.  I shut the engine down immediately at this time.
This winter I found a much better looking timing cover to replace my slightly battered one.  I also replaced the oil pump, making sure I followed all directions to the letter.  When I completed these alterations last week, the oil pressure issue had not changed at all.  I am wondering if anyone has any ideas on this, or had the same problem.  I would really like to get the car running this season.
Thanks for your help
Title: Re: High Oil Pressure
Post by: BlownMGB-V8 on April 26, 2014, 09:11:38 AM
Sounds like your bypass valve may be sticking. That is in the lower cover for the oil pump. There is a "Tadpole" plunger available for it, I've not used one but it is claimed to eliminate the sticking problem.
Post by: Dukebloodhound on April 26, 2014, 12:50:16 PM
Thanks Jim,
I am new to engine building so bear with me.  I used the orange spring in the bypass (40 psi) and I fit the spring into the valve male to female.  When the Metric cover is not attached to the timing cover how should the valve be oriented?  The valve itself has cut outs in it, should you be able to see those, or should the solid side of the valve be visible looking from the inside of the metric cover?
Post by: BlownMGB-V8 on April 26, 2014, 04:22:48 PM
Not so sure about the metric cover, can you post a photo?
Post by: Dukebloodhound on April 26, 2014, 07:16:40 PM
I am going to be away from a computer over my weekend, but I can try to post a photo on Tuesday when I return to work.  It is the Buick Metric cover that is in the book  on converting your car to a V8.  Something like "How to give your MGB V8 Power".  The cover was used on a variety of GM cars in the 70's and 80's.  It changes the angle of the oil filter location to a better angle.
Post by: 88v8 on April 27, 2014, 12:31:50 PM
Agree that the first thought would be pressure relief valve is sticking.
I think RPI have the tadpole type valve.
http://www.v8engines.com/engine-6d.htm
The oil pump is driven by the distributor drive gear. The ticking noise could be the gear breaking up due to overload, or the drive pin.
When you say you changed the oil pump, was that the gears, or also the bottom cover, or did you keep the same bottom cover & valve. If so, that would explain why the problem is still there.
You might also check/change the oil filter. I have had poor oil pressure from some filters. Currently I have a Wix WL7117 which is fine.
Post by: RMO 699F on April 27, 2014, 01:23:09 PM
Did some research a couple years ago...WIX was rated the best oil filter....NAPA gold is a WIX filter...
Post by: Dukebloodhound on April 29, 2014, 02:16:53 PM
Here is some more information from the high pressure situation.  I changed out all of the oil pump components with new except for the used 215 cover.  New gears (longer ones), new gear spacer plate, new metric cover, new relief valve and spring.  I have a NAPA Gold 1068 filter on the remote filter hanger.  I pulled the pressure relief valve yesterday to check its movement.  It came right out after I pulled the spring.  Was not stuck at all
I am wondering about the actual valve/plunger that the spring retains to a pre-set pressure.  It has an oblong cut out in each side of it.  Do these cut outs have to be aligned with the access port at the bottom of the pump gears, or should a solid shaft be visible?
I started the car yesterday after checking the relief valve and had the same high pressure issue
Post by: DiDueColpi on April 29, 2014, 04:13:14 PM
Just a WAG but,
double check your remote oil filter lines Jeffrey.
If they are reversed the filter won't flow any oil and gives you astronomical oil pressures.
The engine is clicking because it doesn't see any oil.
Hope it's something that easy.
Post by: Dukebloodhound on May 01, 2014, 08:54:15 AM
Thanks Fred,
I tried switching the lines to the remote oil filter last night with no discernible difference in oil pressure noted.  I then bypassed the filter totally by coupling the lines together.  Same results, pressure up to 100 psi as the engine is revved.
What could be blocking oil flow inside of the engine?  Or could it be an problem with the oil pick up tube in the oil pan?  I have the stock tube and oil pan that came with the engine.  I am wondering if something, somehow fell in the pan and is getting stuck against the tube screen?
Post by: BlownMGB-V8 on May 01, 2014, 09:31:30 AM
It's not the pick up. Maybe you have a blockage in the main pressure galley somehow. The extended gears are generally more harm than good but unless the bearing clearances are very tight would not account for what you are seeing. You might pull a valve cover and check for adequate oiling of the top end. If it's dry up there you have a blockage.
Post by: Dukebloodhound on May 01, 2014, 10:53:58 AM
 -- moved topic --
Post by: DiDueColpi on May 01, 2014, 05:43:24 PM
I agree, the pickup can't cause a high pressure problem.
And even a blockage in the engine shouldn't be able to cause that much pressure as the pressure is regulated at the pump itself.
If the filter lines and the adapter are good then it really just leaves the pressure regulator and it's spring.
Just to go through in a reasonably logical order.
Have you tried another oil pressure gauge?
If it's electric try another sender as well and confirm that the wiring and voltages are sound.
Or better, try a mechanical one.
Is the plunger in the right way around?
It has a cup shape to it and the flat end goes in first followed by the spring which fits inside the cup by 3/4 inch.
No alignment of flats or anything like that is needed.
The plunger needs to move freely with no restriction at all.
The stock spring is 0.400" dia. by 3.050" long with a wire dia. of  0.040"
That will give all the oil pressure that you need.
Do the new gears have enough end float?
If not they can push hard enough on the housing to pinch the regulator and jam it.
That could also explain the clicking and the seemingly contradictory loss of oil pressure when hot.
If none of this resolves the problem. Then we'll try some other form of magic.
Post by: Dukebloodhound on May 02, 2014, 04:31:25 PM
Thanks for the advice guys!
I do have the plunger in the correct way then.  Cup side towards the spring with the spring seated inside of the cup.  My spring that I used is the "orange one the is set for around 40 psi.  It is not anywhere near 3 inches long. 2.25 or so.  I will look and see if I have the bolts that hold the pump cover on torqued to tightly.  They are set with 10 foot pounds, but maybe I over tightened.  The plunger does slip out easily when I pull the 1 inch spring retaining cap.  Would it only tighten up when the pump is actually spinning?
I have ran a second mechanical gauge.  It is reading within 5 lbs of the MGB gauge.  High at first, then low
Post by: Dukebloodhound on May 03, 2014, 01:57:59 PM
Thought of another potential problem to look at last night.  Is it possible that the distributor is pressing too tightly against the oil pump drive shaft?  If so, that could be causing an issue with the end float.  Has anyone ever heard of that before?
Post by: Dukebloodhound on May 10, 2014, 12:40:08 PM
Here is what has happened over the last week.  I pulled everything, up to and including the front timing cover, from the engine.  Using a soft piece of wire, I probed both oil passageways on the block.  I was able to run in each one at least 7 inches till hitting a bend.  I replaced the gasket located between the spacer plate and the Metric cover with a stock Buick 215 one.  With the standard gasket I could detect no end float on the oil pump gears.  The remote oil filter adapter was replaced on the engine with a unit from D & D.  I was worried my off the shelf unit was defective.  I insured the the bypass plunger moved freely before the distro was installed.  Everything was put back together for starting.  The engine turned over fine and started well.  Of course, the oil pressure was exactly the same.  Good pressure at low idle, with it increasing as the rpm's increased.  I think I could have hit 100 psi if I kept heading towards 4000.
So I am looking for any ideas, no matter how basic seeming.  This is the first time I have ever built an engine.  So what seems like a basic thing to you, will probably not be to me.   I started this conversion 2.5 years ago, so this is issue is really getting to me.  I looked forward to the day when I can take the MG out for real!
Thanks for any help/
Post by: mgb260 on May 10, 2014, 01:07:02 PM
I remember something about differences/compatibility between 1979 and down/1980 and up oil pumps. If using a booster plate the relief valve won't work. I think you have to line up and drill a hole. I have the old Kenne Bell instructions I will put on here that might explain it better. Actually the first paragraph answers your problem, you need the longer spring Fred mentioned for the 215 cover/oil pump. Newer Metric uses shorter spring. Bet that fixes the problem.
Post by: Dukebloodhound on May 10, 2014, 06:13:24 PM
Thanks Jim for the advice.  I will try switching out a longer spring tonight.
One more question for you-how do I know what year my Metric cover is?  I purchased a reproduction from D & D, so not sure what year it is modeled after.
Post by: mgb260 on May 10, 2014, 06:50:03 PM
Jeff, 80 and up is Metric.  It may not be just  the spring. You also have to have the gasket with  rectangular hole(bottom left pic) in it and make a 1/4" deep 1/2" wide channel (pic above the bottom left) to connect the gasket hole to the larger port if you have the booster plate. Keep us posted on the results as it may help others.
Post by: Dukebloodhound on May 11, 2014, 07:45:22 PM
Hi Jim and crew,
I was able to check the instructions you posted, and realized we are talking about two different options.  I do not have the booster plate, I have the plate installed that allows for the deeper or longer oil pump gears to be fitted to the 215 timing cover.  It is basically a spacer plate with holes around the edge that allow for oil passage.  It is listed as a K-201HV Kit-O/P Repair purchased from D & D.  This AM I did try replacing the orange pressure relief spring with a longer one.  Not successful.  The engine fired immediately, but at idle the pressure was at 95 psi.  I quickly shut it down and re-installed the orange spring (which is supposed to be set for 40 psi).  So please, more suggestions!   It has been rainy and cool here but the warm temps are on the way.
Does everyone agree that a NAPA Gold 1068 is a good filter to use on a remote mount
Post by: mgb260 on May 11, 2014, 08:36:37 PM
Jeff, Can you post a picture of it. You may have to still make that channel between the gasket hole and larger inlet hole. Do you still have the stock gears so you can try it without the spacer?
Post by: BlownMGB-V8 on May 12, 2014, 10:40:46 AM
A very odd problem to be sure. Did you pull a valve cover to be sure oil is getting to the top end? (opposite side preferred)
Post by: Dukebloodhound on May 12, 2014, 08:49:19 PM
Hi Guys
I have attached some pictures of the oil pump extension plate from the original 215 cover I removed and replaced a month or so ago.  The Metric pump cover bolts over this with longer fasteners.   A remote filter assembly screws on to this, with hoses to the filter and back.
I have not pulled a valve cover, but can tomorrow after work.  How much oil should I see in a Rover engine?
Post by: mgb260 on May 12, 2014, 09:13:15 PM
Jeff, Thanks for the pics. Can you show the face of the metric cover with gasket over it. Definitely just a spacer with longer gears. Maybe you have too tight bearing clearance? Are you oiling through the rocker shaft or through the pushrods? We will figure this out. It is unusual, as the Buick system is more often low oil pressure.
Post by: DiDueColpi on May 13, 2014, 03:31:03 AM
Jeffrey man,
I'd be more worried about blood pressure than oil pressure if I were you.
The lovely Lynne would have my "gentleman's vegetables" in a vice if I had car parts on the dining room table.
But from what is seen so far nothing seems amiss.
The little nubules of silicone are a concern though. Just a small amount of that floating around in your oil system can wreak havoc
An anaerobic sealant such as Locktite 518 for example, would be a much better choice.
Apply it in a thin layer with a brush or small roller.
Sealant trapped between the mating surfaces will be starved of air and harden.
Any excess product will be squeezed out just like normal, but it won't harden and will be carried away harmlessly.
With any luck, pictures of your cover will reveal the problem.
Post by: MGBV8 on May 13, 2014, 07:35:58 AM
For reference here's a pic of mine on my '63 215
Post by: BlownMGB-V8 on May 13, 2014, 10:19:55 AM
Jeff, I don't think those long gears are helping you any but it also does not sound to me like they are the problem. What concerns me most is that you say the oil pressure goes away when it warms up? Dropping from very high pressure to very low pressure indicates a very serious problem somewhere and off hand I just can't think of anything that would cause that.
What you are looking for when you pull the valve cover(s) is the absence of oil. Better still to see what is going on with the engine running but that is messy, though an old valve cover with the top cut away can be a big help. Then you just look for a reasonable amount of lubricant getting to all of the moving parts without a flood piling oil up in the top end, which could conceivably starve the pickup.
OK here is a possible working theory. I doubt it is the right one but may be a starting point. IF your bearing clearances are tight but you have a greatly excessive flow of oil to the top end, it MAY be possible with that high volume pump to over pressurize the system and still starve the sump. This would seem to require drainback issues as well but could be possible. If that is what's happening you either need to replace worn or out of spec components in the top end or put a restriction in the supply line, which though not a common mod is sometimes seen on race engines.
Look, I know you are probably attached to the HV pump kit and want to keep it. But at least two decades ago it was recognized by the Buick community as a VBI (very bad idea) and at best a band-aid for sloppy bearings. First thing I'd do is get rid of it, go back to the standard gears, use the booster plate and do as many of the recommended oiling mods as is reasonably feasible. Provided of course that your bearing clearances are closer than .002". At least that would get you back to a known starting point.
Post by: Dukebloodhound on May 13, 2014, 08:42:51 PM
Hi Team High Pressure
Thanks for the continued advice!  I pulled the valve cover from the drivers side when I got home tonight.  Not much oil seen, so I elected to start the motor.  That produced almost no oil!  A small amount, maybe a thimbleful, pooled in the ends of the head.  So I tried the other side.  This had slightly better results, but it was still barely noticeable.  The car could have been driven all day without the cover in place and not a drop of oil would have spilled out.  I decided to pull the rocker arm and attempt to clean it again.  I pulled both end arms and made sure all oiling passageways were clean, and I did the same with the center ones.  They all had a bit of crud in them, but none were blocked.  I snaked the soft wire down the oil holes on the head and did not hit any noticeable blockages.  After reassemble I started the motor again.  No increase in oil and still high pressure.  So I am assuming that the oil system is blocked, or partial blocked, somewhere.  I am wondering if I used to much gasket compound during initial assemble, and some broke off after I had ran the motor for awhile.
Excluding complete disassemble, is there a way to flush or clean out the oiling system?  If I could leave the block in the MG I would be happy to strip it down as far as I could take it,
Post by: mgb260 on May 13, 2014, 09:04:50 PM
Jeff,  Do the holes in the head line up with the holes in the rocker stands? Another thought, could the cam bearing holes not be lined up? Front cam bearing has 2 holes at 9 and 3 O'clock. There is a grooved front bearing from T/A. Or you can grind a slot from 9 down to 7 and 3 up to 1. This improves oiling and longevity of the front cam bearing.  All the other ones aren't as critical as to position, but are, to the distribution through out the engine. The holes still have to line up. I wonder if there is an oiling diagram available? Also, does your Metric cover and gasket look like Carl's picture.  Ok, I found a oil diagram for  the Buick 430 V8,probably pretty similar. Looks like the front cam bearing feeds the hole to rocker oiling.
Post by: Dukebloodhound on May 13, 2014, 10:26:31 PM
Guys
Here are a couple of pictures of the Metric pump cover that mates to the 215 front timing cover.  This is one that I pulled from a junkyard, but the D & D one is identical, just cleaner.  The hole on the side that is tapped is for the oil pressure gauge.
Post by: BlownMGB-V8 on May 14, 2014, 10:47:58 AM
https://www.google.com/search?q=rover+v8+oiling+diagram&es_sm=93&biw=910&bih=456&tbm=isch&imgil=KsxvNftKWrvlCM%253A%253Bhttps%253A%252F%252Fencrypted-tbn3.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcSJdkYN0O5KAnvXQap7ZFmBYOCWvWnEOtrA9fjEu7Zf7PqMtPQhmQ%253B350%253B343%253BZaVDnCMiqqGuuM%253Bhttp%25253A%25252F%25252Fwww.roversd1.info%25252F3500%25252Flubrication.html&source=iu&usg=__gWTEA0liXrc18ivVYqLb49SscFY%3D&sa=X&ei=b4FzU6iQA5KyyATr84LYBQ&ved=0CCoQ9QEwAQ#facrc=_&imgdii=_&imgrc=KsxvNftKWrvlCM%253A%3BZaVDnCMiqqGuuM%3Bhttp%253A%252F%252Fwww.roversd1.info%252F3500%252Fv8overhaul%252Flubrication-B.gif%3Bhttp%253A%252F%252Fwww.roversd1.info%252F3500%252Flubrication.html%3B350%3B343
Post by: mgb260 on May 14, 2014, 12:24:09 PM
Jeff, That spacer has the same little rectangular hole with angled end that the booster plate has. The cover Carl shows has a small hole there connecting to  the next opening. You could try that.
Post by: MGBV8 on May 14, 2014, 12:51:39 PM
QuoteThe cover Carl shows has a small hole there connecting to the next opening. You could try that.
Before you go drilling, I need to clarify that my pic above is of the original 215 base. Not the Metric base.
Although, that factory hole does seem to be where the Kenne-Bell instruction say to drill.
Additional oil pump info:
http://www.vortexbuicks-etc.com/Oilpump.htm
Post by: mgb260 on May 14, 2014, 01:57:22 PM
Carl, That's a good page! There is one more on that site also:
http://www.vortexbuicks-etc.com/frontcover.htm
Post by: Dukebloodhound on May 14, 2014, 11:56:18 PM
Hi Guys,
Did a bit of investigating when I got home tonight to try to determine the extent of oiling in the engine.  Having such a low amount going to the rockers has gotten me nervous.  I pulled the carb, intake, and the valley gasket to get a look at the tappets and cam.  It appears that oil is flowing to this section of the motor.  I did not notice any wear or burn marks.  The entire area appeared to have had a coating of oil on it.  I am wondering if it is worth it to pull the heads to check the cylinder walls.  I would like to try to verify that the passageways that feed oil to the heads are clear, or could be cleared.
In one of the posts it was mentioned that liquid gasket material can cause an issue if it gets into the system.  That is my worry.  Oil pressure is high at start up due to a blockage.  As the oil gets pumped into the top end of the engine, it has trouble returning to the sump and the pump starts to cavitate.  Still not sure why the by-pass valve is not working, but could it be the location of the gauge pick up port-right in the side of the Metric cover?
Does this seem like workable scenario?  Would you recommend pulling the heads to check passageways?
Thanks for the vortexbuick links-very helpful.  I unfortunately do not have standard volume 215 oil pump gear.  They did not come with either cover.  Would the longer gears adversely affect the larger Rover 4.0 engine?
Post by: Wilcat1@sky.com on June 08, 2014, 11:54:29 AM
Hi Jeffrey
Suggest you remove both rocker covers, be prepared for some oil splashing, start the engine and let it idle at the 50lbs you mention. DO NOT  REV the engine.
You will hopefully hear the tappets silence their clatter in 2 -3 seconds  and hopefully oil will commence its flow to the top of the engine via the rocker shafts and the rocker arms  in about 30 seconds
If the above is successful, change the oil filter to one approved by the local MG Club, and when you restart thereafter if the problem persists commit that bloody oil pump base to the trash can, and purchase one from a UK source.  Clive Wheatley the MGV8 specialist is your man, he has a web page, a phone call will have the parts you need on your doorstep within 5 days.
Let's stop pissing about with what we THINK is the appropriate pump base plate
Good weather is just around the corner
Post by: Wilcat1@sky.com on June 08, 2014, 04:46:57 PM
Hi guys
Oops just realised that there is a second page of mail on this subject, my comments re oil to the rockers etc has already been established viz  minimum oil reaching the top of the engine.
I have overhauled several Rover V8's and I recall removing the front cover on one engine  just before installing  it in the car. -  I normally use silicone liquid gasket  on  both sides of the paper gasket, and the amount of silicone being squeezed from the joint gave me worries that I might have  applied too much liquid gasket and blocked the main oil  flow port between the timing cover and the block.  It transpired that I did not  have a problem, but three days after the  installation of the timing cover the silicone  on the outside of the front cover had congealed to the extent that  it could  have formed a ' hard silicone bung' in the oil gallery if my fears had been justified.
The oil coverage on the underside of the valley gasket and the inside surface of the block might well have been caused by the turbulence created by the piston movement creating an oil mist.
I would still change the filter and if that fails to solve the problem junk the Metric oil pump base plate.
The solution is out there - somewhere
Post by: Wilcat1@sky.com on June 10, 2014, 08:20:58 AM
HI JEFFREY
Attached pic is of the original factory oil pump base,  I have 2 X MGB V8's. Both with these base plates, and in one instance  the car is fitted with your pump spacer and longer gears.   If you can relate to my pic and find yours  provides the oil  drillings , so much the better
A side issue I exploded two oil filters when I first started one of my engines, the first incident was considered.an isolated fault, but when the  second exploded I phoned the manufacturer (Unipart on the UK)  and was advised that the filters were bomb proof to 130 lbs pressure.  - I replaced the Dizzie gear at the base where it mates with the camshaft, the thing was scrap.  -  after a total of approximately 5 minutes  engine use.   I was under the bonnet in both cases and  unaware of the  pressure reached before all he'll broke loose.
The solution in my case was to fit a tadpole valve in the same oil pump base plate.  - problem solved.  Both cars now have tadpole valves and adjustable oil pressure release valves fitted.
Hope you are  making progress
Post by: Wilcat1@sky.com on June 10, 2014, 08:59:13 AM
HI  JEFFREY
DO NOT THINK MY PICS SURVIVED MY COMPUTER SKILLS. ( old age does produce a few problems )
Are you aware that the rocker shafts in these engines need to be fitted to ensure the oil flow will pass through the shafts and feed the rocker arms.  If you get them reversed you will experience higher than normal  oil pressure. -  it's difficult to explain but there should be a. 'Hack saw cut ' across  one end of the shafts.
The 'cut end ' of the shaft  goes to the front of the engine on the left side ( as you view the engine standing  in front of the car looking down on the engine) and the cut end goes to the rear of the engine  on the right side viewed from the  front.
You will find some warning messages on the Web,
Sorry about my pics, cannot work out where I went wrong -  they failed to attach ?
Post by: BlownMGB-V8 on June 10, 2014, 10:51:12 AM
Pics probably too big.
Post by: Dukebloodhound on June 14, 2014, 02:09:28 PM
Hi Guys,
Sorry it has taken so long to reply, many 12 hour days at work.  Since my last message I have pulled the heads and really cleaned them and the rocker shafts.  I re-installed the heads and tested oil flow with the rockers not attached, by just turning over the engine.
Flow looked good, so I put the whole thing back together and started it up-same issue, high pressure.  My neighbor can over and looked at it with me and made a suggestion.  He had me run the car up to the high oil pressure, then shut it off.  I quickly removed the pressure relief valve spring, reassembled and started the engine for a few seconds.  I only had about 2-3 pounds of pressure-so the bypass was working.  From there it was just a matter of fitting a weaker spring, and slowly removing a coil at a time till the correct pressure was reached.  Currently, I am at 45 psi at cold idle, It does raise up to about 52-53 when I raise the rpms.  When the car is fully warmed up, it is at around 35 at idle.  I have not experienced the drop in pressure since the weaker spring has gone in.  So I am fairly positive the spring that I was instructed to use was too stiff and caused the high pressure problem.  Cannot figure out why after warm up the pressure dropped so low though???
Thanks for all the tips, I am going to check my rocker shafts to make sure I did not reverse them.  I have only put about 30 miles on the MG since the new springs-but they have been great ones!
Post by: ex-tyke on June 14, 2014, 09:12:29 PM
QuoteCannot figure out why after warm up the pressure dropped so low though...
A drop of 10psi from cold to hot running oil pressure is quite normal.
Post by: BlownMGB-V8 on June 15, 2014, 02:53:07 PM
Rule of thumb for Buicks is 10 psi per 1000 rpms.
Post by: Dukebloodhound on June 28, 2014, 01:45:49 PM
Hi Guys,
I was talking about the original pressure issue that I had-high pressure at first, till warm up, than almost no pressure after that.  2-3 lbs when above idle.
Since I cut the pressure relief valve spring down, I have not had the low pressure.  Besides a drop as the oil heats up and thins out
