General Category => Bodywork, Paint, Interior, Trim, & Wiring => Topic started by: Med72 on March 18, 2014, 02:21:32 PM
Title: Removing windshield for a 72 TR6
Post by: Med72 on March 18, 2014, 02:21:32 PM
My TR6 comes with the factory hardtop.  I going to start working on removing paint and sanding to metal. I want to remove the front windshield and back and side windows from the hardtop.  Can I go to harbor frieght and purhase a standard tools to remove the windshield clips?  If not, does anybody have experience removing front and back windshields?
Title: Re: Removing windshield for a 72 TR6
Post by: rporter on March 22, 2014, 10:04:45 AM
I have a tr6 with hardtop and removed all glass. It is just held in by the rubber there are no clips. Cut the edge of the rubber and out they come. FYI the rear rubber for the hardtop is very hard to find. You might want to try and save it.
Post by: Med72 on March 24, 2014, 03:24:40 PM
Thanks Richard:
I removed the back windshield by doing and you said.  The rubber is so cracked and brittle that I couldnt save it.  i think The Roadster Factory, Moss Motors and Victoria British all  carry the rubber for the hard tops
Post by: rporter on March 25, 2014, 07:45:57 AM
Glad it worked I did mine 10 years ago and got the last rear hardtop OEM from London TR shop name escapes me. New stuff allegedly not as good. You might try McGregor I think is the name in Canada. He often has strange stuff. Also I never got around to putting the plastic chrome strip in my windshield. don't think it matters much. I like the hardtop very few around and it stiffens up the car rides better and quiet. You can make your own headliner out of nice Vinyl. Just be sure to use super strong adhesive 3m not good enough.
Post by: Med72 on March 27, 2014, 02:01:16 PM
Thanks Richard:
Do you remember where you picked up the adhesive?
Art
Post by: rficalora on March 28, 2014, 10:59:49 PM
My Home Depot sells it.
Post by: rporter on April 25, 2014, 07:50:38 AM
I used weldwood contact adhesive landau top and trim HHR solvent industrial grade. Got off Internet but don't remember where. Just type this stuff in Goggle and should find a source. Have to buy a gallon and I used about 1/2 half on my top. Holds very well no drpped areas in a year of cold and heat. Paint on with a brush. Spray adhesive for me has not worked. Also hard to control overspray. I heard about if from a jaguar restoration log.
