General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: BOOTLEG on January 19, 2014, 04:22:11 PM
Title: Ideal Flywheel Weight?
Post by: BOOTLEG on January 19, 2014, 04:22:11 PM
I weighed my flywheel to see how much I'd have to remove to meet the Roger William's 22lb. ideal weight.  I was surprised to find mine weighed only 17.4 lbs.  I weighed it again to be sure, then I consider that perhaps Roger was including his clutch plate or....
Anybody have a flywheel this light?
(Moderator: split this message from a thread in the classified section, renamed it, and moved it.)
Post by: BOOTLEG on January 19, 2014, 05:47:35 PM
 -- moved topic --
Title: Re: Ideal Flywheel Weight?
Post by: Dan Jones on January 20, 2014, 01:26:24 PM
A friend has an older BMW M5 that came with a 12 lb flywheel from the
factory.  The car weighs 3800 lb, has the same size engine as my TR8
(215 cubes) had, has a 264 degree cam on 110 deg center and has a 3.53
1st and 3.91 axle.  It gets off the line very easily and, thanks to the
IR EFI, can spin the rear tires (275/35R18) at will in first gear on
dry pavement.  Hooks just fine in second, though.  Gary also had a Buick
215 powered Vega.  It weighed about the same as the TR8, had a 3.36 axle
and a 3.41 first.  He lightened the 32 lb flywheel to 22 lb (mostly from
the perimeter) and said the result was wonderful.  He said he would have
gone lighter if he could.  Of course, there is a point of diminishing
returns and a combination of a very light flywheel and a digital on/off
type race clutch can make street driving less than pleasant.
A while back I ran the numbers for switching from an iron to aluminum
flywheel for my Triumph TR8 with Rover V8.  The effect was surprisingly
large.  There are a couple of approaches to doing the math.  The more
rigorous approach is to calculate the polar moment of inertia for the
two different flywheels, adjust for the square of the overall gearing
(transmission, final drive and tire diameter) and convert to an
equivalent linear inertia.  The second method (the one I chose) is to
start with a known linear to rotational equivalent and ratio from there.
The known relationship I used is a solid disk rolling on its edge.
It has an effective inertia exactly 1.5 times what it would be if it
wasn't rotating.  That means the rotational component is 50% of the
linear component.  Adjust for the square in gearing and you have the
answer.  I wrote a little Fortran program to do the calculations.
I assumed a 12" diameter flywheel which is the Buick/Rover diameter,
less the ring gear.  The circumerence of a circle is the diameter
multiplied by pi.  So if you roll the flywheel along the ground it
will move 37.7 linear inches per revolution (= pi * 12).  A 205/50/15
tire has a diameter of approximately 23.1 inches.  My TR8's final
drive ratio is currently 3.45:1 and first gear is 3.32:1, so one
revolution of the flywheel results in the TR8 moving approximately
6.3 inches.  Ratio the squares and take half ((37.7/6.3)**2)/2 = 17.9.
So each pound removed from the flywheel (equally across the face) is
the same as about 18 pounds of weight removed from the car when in
first gear.  So if you remove ten pounds from the flywheel (equally
across the face), the result is equivalent to removing 180 pounds of
vehicle weight in first gear.  The effect goes down for each higher
gear, of course.   Removing weight farther from the rotational axis
has a more pronounced effect.  If the weight is removed from the
outside of the flywheel only, the effect is about 2.78 times as strong
since a solid disk has a radius of gyration of 0.6 times the radius
(1.0/0.6)**2 is 2.78).  2.78 * 180 is 500 lbs equivalent weight
reduction.  A non-trivial effect, particularly in a lightweight car.
I ran the numbers a couple of ways to illustrate.  For my TR8,
assuming a 3.45:1 final drive ratio, 205/50/15 tires and LT77 gear
ratios of:
 1st 3.32:1
 2nd 2.09:1
 3rd 1.40:1
 4th 1.00:1
 5th 0.83:1
along with flywheel weights of:
 stock flywheel - 32 lbs
 lightened steel - 22 lbs
 aluminum - 11 lbs
The engine in the TR8 is essentially a Buick 215 aluminum V8 from the
early 1960's.  The stock flywheels in those had a big ring around the
perimeter.  Lightening the flywheel by milling off the ring is similar
to removing the mass from the perimeter (from 32 to 22 lbs).  In the
numbers below, I didn't do it that way but a more accurate approach for
the aluminum flywheel would be to assume a reduction of 22 to 11 lbs
equally across the face and add that to the difference of the 32 to
22 lbs across the perimeter.  In any event, a lighter flywheel looks
like a good thing to do for performance.  Here are the numbers:
 32 to 22 lbs (across face assumption):
 1st 177.5 lbs
 2nd  70.3 lbs
 3rd  31.6 lbs
 4th  16.1 lbs
 5th  11.1 lbs
 32 to 22 lbs (perimeter reduction assumption):
 1st 493.4 lbs
 2nd 195.5 lbs
 3rd  87.7 lbs
 4th  44.8 lbs
 5th  30.8 lbs
 32 to 11 lbs (across face assumption):
 1st  372.7 lbs
 2nd  147.7 lbs
 3rd   66.3 lbs
 4th   33.8 lbs
 5th   23.3 lbs
 32 to 11 lbs (perimeter reduction assumption):
 1st  1036.1 lbs
 2nd   410.6 lbs
 3rd   184.2 lbs
 4th    94.0 lbs
 5th    64.8 lbs
Rotational inertia is mass multiplied by the distance from the
rotational axis (integrated over the surface).  The effect is
stronger farther away from the hub.  The best is from the
perimeter.  Equally across the face is less effective and near
the hub is the least effective.  In my example, dropping 21 lbs
from the perimeter is equivalent to over 1000 lbs reduction in
weight in first gear.  Dropping the same mass from the face is
equivalent to 372.7 lbs.
Reducing the flywheel inertia does reduce the stored energy for
start from a stop.  Torque follows displacement.  Little engine
in big car with tall gearing needs more stored inertia at start.
Big engine in little car with short gearing can get away with
much less stored inertia.  On the street with a ligter flywheel,
you may need to use more RPM and clutch slip.  On the strip, you
may bog if you don't have enough excess torque at the rear tires
(more traction than engine/gearing).  Remember that HP is the
measure of how much potential torque you can have at the rear
tires via gearing.  If you have enough power to overcome your
traction, then a heavy flywheel is a loser.
Dan Jones
Post by: DiDueColpi on January 20, 2014, 05:08:58 PM
Excellent article Dan.
But don't forget to factor in the rotational mass of the engines rotating assy.
Also engine stroke and # of firing impulses per revolution influence flywheel choice.
Post by: t-100 on January 20, 2014, 09:30:24 PM
For 30 years I have used a 15 lb. alu. fly. to a cut  down Rover/GM fly to 20-22 lbs. more to take the BIG BANG that a heavy fly can/will put on the rear axel. At one time I had a 35lb fly & I would hear the tires when I would go into 4rh. With the light fly I have to work to hear the tires in 2nd. Hits RPM faster comes out of the hole real good (even when pulling a trailer) Start it up & it sits at a smooth 600 RPM. Just turned 599,000 miles on my 74.5 GT with a Rover 3.9 & & a 3.07 C rear & I have only twisted 2 rear axels.
Post by: DiDueColpi on January 21, 2014, 04:59:36 AM
Gary,
I didn't have the picture available earlier.
You have a flex plate for an automatic trans pictured.
Absolutely no relationship to a manual trans flywheel.
Post by: Dan B on January 21, 2014, 08:38:07 AM
In October when we were building motor mounts and test fitting the Lexus 1uz into my TR7, we weighed the flywheel I got with the craigslist package I bought.  It  weighs 16 pounds.
Post by: ex-tyke on January 21, 2014, 01:40:10 PM
Just weighed the Fidenza aluminum flywheel from my 302 (as it happens to be disassembled) at 12 lb.
Interesting to note that when Curtis drove my car in Omaha last year, he immediately recognized that I had an aluminum flywheel installed - so the engine response difference from a heavier flywheel must be evident.
Post by: 74ls1tr6 on January 21, 2014, 03:25:33 PM
I sure like my 12lbs aluminum flywheel. The rpm comes up very fast and goes down very fast also. It is great for autocross.
I will use a 12lbs flywheel in the GT build too! Our cars seem to be light enough for them.
Post by: kstevusa on January 21, 2014, 04:15:45 PM
WHAT?  Do the still make steel flywheels?   :-) I am happy with the Ram installed back in 04.
Post by: MGBV8 on January 21, 2014, 06:14:31 PM
Y'all are killin' me. I'm ready to yank my flywheel back out & carve on it some more!
Post by: BlownMGB-V8 on January 22, 2014, 05:36:01 PM
That Lexus flywheel was a smaller diameter too. Same effect as being lighter. I think some more weight could probably be taken off at the rim as well.
Another thing to remember is that the pressure plate is half the rotating weight with a fairly typical figure of 18 lbs for one with a ductile iron pressure ring. All of the major manufacturers make them with aluminum pressure rings, dropping that number to about 12 lbs. So with the right choice of parts you can easily go from nearly 50 lbs down to around 25 or less. That's going to make a big difference in the responsiveness of the engine, and with the displacement we have there's no need whatsoever for more.
Post by: 88v8 on January 26, 2014, 04:31:35 AM
Remarkable post by Dan.
Worth remembering that a positive or negative effect on acceleration is also seen when fitting larger/smaller tyres.
And likewise an effect on braking.
Post by: roverman on September 28, 2015, 07:22:53 PM
Yea aluminum flywheels !  Now, has anyone measured how thick is the aluminum, under the steel insert ?? Thanks, Art.
Post by: 40indianss on September 29, 2015, 12:25:21 AM
D&D sells approx. 10lb aluminum flywheels  using one it with my 4.6 in a less than 2000lb mgb  many years ago used a 10lb wheel with a 289 stroked to 327 inches with a 2.20 t10  4.88 narrowed 57 Pontiac rear  1200lbs front  1000lbs rear weight all in a 100/6 2 seat healey  never a problem with getting out of its own way  light wheels grab rpms so easily
Post by: BlownMGB-V8 on September 29, 2015, 12:03:10 PM
Think about bike engines. The flywheel on a 500+ lb bike is made as light as possible, using a multi-disc clutch. Most of the flywheel effect comes from the crankshaft. We all know how quickly a bike engine will rev up and throttle down.
Now scale that up by a factor of 4 or 5 to the V8 MGB. To have parity we would still have to use a triple disc small diameter clutch with an ultra-light pressure plate and a skeleton flywheel, with a total weight of well under 20 lbs, maybe close to 10 lbs combined including the flywheel, pressure plate and clutch package, all shrunk down into the 6-8" diameter range. The crankshaft alone weighs 60 lbs, but with the small diameter that would get us close. The torque for getting off the line would still be quite adequate and the throttle response would be exceptional.
So assuming you don't want to go sourcing exotic racing parts to get the weight down (although honestly I think some judicious shopping in the racecarparts forums could find what you'd need at fair prices) the reasonable approach would seem to be to use the lightest flywheel available. Then use the smallest diameter clutch that will handle the torque, and finally, a matching pressure plate. But not just any pressure plate, since average weight for those can easily hit 18 lbs. No, if you shop around you will find PPs with an aluminum pressure ring that will weigh about half of that. Maybe even some with an aluminum hat as well.
There can be no doubt that if you drop 20 or 30 lbs off the rotating assembly you will feel the difference immediately.
Now, are you driving twisty roads, or drag racing? If drag racing maybe you don't want to get rid of all the rotating weight, but if driving the twisties, lightning response and light speed transitions are your new best friends and any rotating weight you can eliminate will make you faster.
Title: Re: Ideal Flywheel Weight? Thickness please ?
Post by: roverman on September 29, 2015, 04:48:11 PM
Still fishing for thickness need, under the steel insert. I'm ready to make chips and I don't want to guess .  Anybody ?  Thanks, roverman.
Post by: DiDueColpi on September 29, 2015, 05:43:46 PM
I have 3 aluminium flywheels from three different manufacturers here Art.
Two of them measure at 0.575" under the insert.
The remaining one is 0.550"
From the looks of it I wouldn't go any thinner.
Also all three have nutted screws for the insert. No threads into the aluminium anywhere.
FYI the thinnest mounting hub is 0.750"
Post by: roverman on September 30, 2015, 11:53:25 AM
Thanks Fred, just what I needed. Any suggestions for a lightweight 9.5" cover ?  My Kennedy unit is quite heavy,(iron/steel).  Onward, art.
Post by: Blown v8 on October 21, 2015, 11:41:08 AM
I have a McLeod double plated clutch,with the fingers,on a steel flywheel,
The metal plate between the clutch plates,can this be lightened ?
As it is,the clutch and flywheel are quite heavy,if anybody is interested,I'll weigh it
Bryan
Post by: Nexxussian on October 21, 2015, 07:09:10 PM
Brian, I for one am interested in what your McCleod setup weighs, especially with component weights and dimensions (diameters, tape measure is good enough).
As to "can you lighten?" the floater, McCleod are the ones to ask, if it can be safely lightened, they likely sell one that already is.
Awaiting details on what monstrous engine you have to require a twin disc. :)
Just out of curiosity, do you know if McCleod sells a lightweight version of yours with an aluminum flywheel?
Post by: BlownMGB-V8 on October 22, 2015, 11:56:46 AM
The simple answer is "yes" but...
I'm guessing this is one of the 10.5" units and the capacity varies widely based on the components used. At the bottom end with organic linings and a very streetable nature they quote about 400 HP, but you aren't using that one are you. From there they go way up to over 1200 HP.
Since capacity is a function of both clamping and heat dissipation (as well as lining material), to lighten the intermediate or slider plate would at least theoretically reduce the capacity somewhat since you remove mass and therefore heat absorbing capacity. So like most things it's a matter of balance. If you have excess capacity or high temp linings you might be able to do a great deal here.
But first a safety concern. What material is the slider made from? If billet, no worries, but to lighten is to weaken and this must be remembered. I highly doubt they used cast but there is no guarantee. Best to check. You can do that with a drill or a grinder.
Quite a few of these come with rather large holes in them. You might be able to drill to lighten. Below a certain size, the bore of the hole will add more surface area than the ends take away which may help in heat dissipation. You obviously need to keep enough of a web to maintain the strength of the ring.
The flywheel and the pressure ring are the other high weight areas, and for the same reasons. It is possible to remove weight in all three places but cautiously, as you do not want the thing flying apart at redline.
But since you are in the neighborhood of 450 HP you should be able to do something with it I would think.
Post by: DiDueColpi on October 22, 2015, 12:20:10 PM
To get a good idea of what Jim is talking about. Check out the Centerforce Dyad clutches.
They have the perimeter of the flywheel lightened as well as the floater.
Post by: Blown v8 on October 22, 2015, 12:24:12 PM
It is one of the 10.5" units,I bought it about 12 years ago,allegedly capable of taking over 600lb of torque !
Flywheel is steel,and came with the clutch,weighing it at 20lb,
image.jpgj
The rest of the clutch weighs in at 26 .25ib, yes the floater has holes in it,I didn't weigh it,but it's not heavy
The clutch came complete but without the throw out bearing ! Gearbox is a cosworth T5 with Quaife internals
Giving the engine a refresh over the winter,new shells,roller cam,and new Pistons (forged) as picture tells what's happening with the TA heads and 0.650" lift
I will be getting the bottom end balanced,and any saving of weight will be a bonus !
Thank you
   Bryan
Title: Re: Ideal Flywheel Weight? Too much Wait !
Post by: roverman on October 22, 2015, 05:16:36 PM
Fed Ex lost my Fidanza insert in Bloomington, CA., but won't admit it. USPS had my carburetor kits, 40 mi. away in Ontario, but sent them up the coast, 5 different stops. What is happening to our carriers-people ?  They better hurry-up, before I fergit,," what is this insert for" ?
Post by: BlownMGB-V8 on October 22, 2015, 06:39:13 PM
You could take a good bit of weight off that flywheel yet. I've seen skeletonised steel flywheels  down around 15 lbs easy. Anything outside of the PP attachments and the clutch face is only to attach the ring gear. Almost all of that could be machined away. The clutch surface does not have to be more than 3/8" thick, the web to the crank could be thinner than that and have holes. There could be holes in the clutch face as well.
Note, the PP is available with an aluminum pressure ring at a reasonable price:
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=aluminum+pressure+plate&tbm=shop&spd=12350264774748369425
Post by: BMC on January 12, 2016, 11:03:10 PM
Although this thread was started two years ago, I thought I would give a simple and short weigh in.
First, it is not just the crankshaft that makes up the rotating weight. It is anything spinning inside and outside the engine including the crankshaft, big ends, balancer, timing chain, camshaft and everything. The further out, the more it will effect things= outer edge of the flywheel and the balancer are good items to point out.
I have used steel and aluminum flywheels and have seen no negative effect on engines that are essentially built to use on the street.
I hear and read from many people who most likely have zero experience with very light flywheels who believe with all their heart that a light flywheel is doom and gloom, especially the MG and other people in the as-it-were factory built car crowd. Some believe that a little weight off the factory flywheel is okay but not too much. My experience says otherwise but it is something that costs money and there are some other items that money is better spent on first.
My personal 3.4L powered MGB and an S10 pickup I have both have aluminum flywheels- no problems. Although everything was identical on both vehicles, it was actually more noticeable on the S10!
Speaking of the S10, with the pickup weighing in at around 2,800 pounds, adding a 200 pound fibreglass top, driver, passenger, fuel, a few spares, my very tiny tandem axle trailer and an MGB V6 to the trailer, the GVW is somewhere around 7,200 lbs. The only time I noticed any change was when pulling away from a dead stop at the top of any hill. This usually at a stop light coming off the freeway. I have to slip the clutch for an extra second- but then again, the rear end gearing is so tall (high speed) that it needed to be slipped at that point anyways. The power of that engine in that truck going down the road is not effected negatively either but it does not have the braking power in that small vehicle to stop the trailer but that's a different story.
Point is- weight of a flywheel under many circumstances I believe can be lighter than the average internet mechanic realizes. As others have said, your findings may differ.
-BMC.
Title: Re: Ideal Flywheel Weight? Got Dual Mass ?
Post by: roverman on February 27, 2016, 01:03:11 PM
Anyone using one ?  Late oem Corvette/ others ? I'm told less "lurch" ?  Like a highly effective torsional hub, in the clutch disk ?
