General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: GT8MX on January 12, 2014, 05:18:04 PM
Title: Rover 4.6L EFI - to GEM or Thor
Post by: GT8MX on January 12, 2014, 05:18:04 PM
I am an old noob to this forum.  I'm retired but this is my first post.
I have decided to install a Rover 4.6L rather than the BOP 215 I have.  I want EFI, so I'm trying to decide between:
1- Rover "GEMS" system
2 - Rover Bosch Motronic "Thor" system
My concern is not power - either yields enough - but hood clearance.  I am stuffing the engine into a Spitfire GT6.  I was worried about clearing the intake+carb+air cleaner stack, but I can't find measurement specs on either GEMS or Thor systems to determine if EFI has better hood clearnace.  I am staying away from the earlier hotwire sysytem in a blind attempt at staying with newer technology in spite of Glen Towery's excellent article "How Glen Towery Installs Rover EFI on MGB V8 Conversions",  The British V8 Newsletter, Volume XV Issue 1.
Height being equal I would go with GEMS because it is newer and I like the look of the Motronic intake runners rather than the GEMS plenum.  Under the GEMS plenum is a realy neat set of horns, ala Hilborn only shorter,  but they get hidden!
I am intrigued by the EDIS + MegaSquirt  (due to the discussions in thread "Which ECU's will run a 1998 4.6 Range Rover engine?" and talk while fielding a LeMons car  brakingwindracing.com) but I think that is independent of the Induction decision.
I have been reseraching this within the BritishV8 Forum with no luck.  Any info or pointers to info?
http://spitfiremx8.com/wordpress/
Title: Re: Rover 4.6L EFI - to GEM or Thor
Post by: mgb260 on January 12, 2014, 05:43:02 PM
Another even lower alternative is factory 215 4 barrel intake or Edelbrock Performer intake with injection bosses and 4 barrel throttle body. Could adapt GM,Ford or Megasquirt for ECU.
http://www.mgexp.com/phorum/read.php?40,2495927,2495927#msg-2495927
Post by: Moderator on January 12, 2014, 11:26:40 PM
I don't know where to get dimensions, but I expect you'll find the Thor system is larger in both height and width. That's a pity, because it looks cool and because its longer runners ought to be advantageous. I considered making a custom plenum to sit atop a Thor lower manifold. At the gasket between upper and lower manifold, the runners have the same round cross-section as earlier Rover systems, as shown here: http://forum.britishv8.org/read.php?11,40102,40373  So... you could use the trumpets from an earlier Rover plenum with the Thor lower manifold. The main reason I went with an earlier manifold and fuel rail is that the Thor fuel rail is of the more modern "returnless" type. (GEMS and earlier Rover systems use a fuel pressure regulator on the fuel rail.) Though I admired the Thor system's handsome stainless fuel rail, adding a regulator to it looked problematic. I also didn't care for the Thor water neck and thermostat installations. I don't know if there's much reason to prefer one injector over another. (GEMS uses Lucas injectors and Thor uses Bosch, right?)
Post by: GT8MX on January 13, 2014, 12:12:02 PM
I found dimensions for the GEMS EFI from three sources and the heights agree +/- 3/8in.  The sources are http://www.super7thheaven.co.uk/blog/rover-v8-dimensions-a73.html, http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=v8dimensions.jpg, http://www.v8engines.com/engine-4.htm.
The average height (from the measurements I found) from the lowest point on the stock oil pan to the top of the GEMS plenum is 27-13/16"  The distance from the bottom of the block to the top of the GEMS plenum is then 21-13/16", since the BOP215 stock oil pan I have has a dimension of ~6" from it lowest point to the block mating face.
That gives me an interference of maybe 3/8" between the top of the plenum and the underside of the hood, but the GT6 hood has a power bulge on the center line, so I might be in good shape with the GEMS induction, provided the power bulge is wide enough to span the GEMS plenum.  At worst, I can mill the bottom plenum like Glen Towery suggest in his article "How Glen Towery Installs Rover EFI on MGB V8 Conversions", The British V8 Newsletter, Volume XV Issue 1 and gain ~7/8".
So I should be OK with the GEMS EFI.
Haven't gotten hard data on the Motronic Thor EFI...
Post by: GT8MX on January 13, 2014, 12:16:07 PM
Regarding Jim Nichols' earlier post regarding the stock BOP 215 with an EFI throttle body in place of the carb....I would still have an intake + throttle body + air cleaner stack wouldn't I?  The stack is what I am trying to avoid.  Besides, I want EFI.  :)
Post by: GT8MX on January 13, 2014, 12:23:36 PM
Regarding Curtis Jacobson's ealier post...
So the GEMS lower manifold is lower than the Thor lower manifold?
What did you want to avoid with the Thor "returnless" fuel supply?  I thought that would be preferrable - one less fuel line, less energy pumping fuel not needed, less chance for a leak - less is more for reliability.
I don't know about the GEMS injectors being Lucas, but I know the Thor injectors are Bosch from the factory.  I suspect any number of maufacturers are now available for non-OEM installations.
Post by: Moderator on January 13, 2014, 12:24:23 PM
QuoteThe average height (from the measurements I found) from the lowest point on the stock oil pan to the top of the GEMS plenum is 27-13/16" The distance from the bottom of the block to the top of the GEMS plenum is then 21-13/16", since the BOP215 stock oil pan I have has a dimension of ~6" from it lowest point to the block mating face.
I haven't measured one, but I think you'll find Rover 4.0/4.6 oil pans are significantly deeper than Buick 215 oil pans as shown here: http://forum.britishv8.org/read.php?11,2321
Post by: Moderator on January 13, 2014, 12:42:56 PM
QuoteSo the GEMS lower manifold is lower than the Thor lower manifold?
AFAIK 14cux, GEMS, and Thor lower manifolds are all the same height. I'd already decided to make my own plenum. You might possibly want to consider that too... (Snapshots of my results appear here: http://www.britishv8.org/MG/CurtisJacobson.htm)
QuoteWhat did you want to avoid with the Thor "returnless" fuel supply? I thought that would be preferable - one less fuel line, less energy pumping fuel not needed, less chance for a leak - less is more for reliability.
Maybe, but it's not a free lunch. You still need to regulate fuel pressure AND you need to avoid overheating fuel. This thread might be a good place to start reading on the subject: http://www.msextra.com/forums/viewtopic.php?f=71&t=42907
QuoteI suspect any number of manufacturers are now available for non-OEM installations.
Having injectors cleaned and flow tested is a LOT cheaper than buying new injectors.
Post by: mgb260 on January 13, 2014, 04:38:16 PM
On the 4 barrel throttle body there is no stack. Air filter sits on throttle body. As low as you can be. Stock carb intake is lower than fuel injection  manifolds plus no top manifold.  You have to add fuel injector bungs for the injectors.
Post by: Dan Jones on January 13, 2014, 06:33:30 PM
I think you'll find the long runner Thor manifolds will seriously limit upper RPM performance.  They were designed to increase low RPM power for heavy Range Rovers fitted with automatic tranmissons.  Not the best solution for sports car swap.
Dan Jones
Post by: GT8MX on January 13, 2014, 09:47:28 PM
Wow.  Great inputs, guys!
So here's the fusion of what I've learned from your inputs:
1 - The lower manifold is the same on GEMS and Thor.
2 - The Thor upper manifold,  while looking cool and generating more low RPM torque, is taller than the GEMS plenum, and limits upper RPM performance (both bad in my application)
3 - I can use my dual-plane factory BOP 4-BBL intake manifold with the low riser throttle body and Megasquirt as Jim Nichols suggest http://www.mgexp.com/phorum/read.php?40,2495927,2495927#msg-2495927.
4 - I can use a GEMS, and fabricate a custom upper manifold to get the clearance I need and incorporate some sort of cold air system ala http://www.britishv8.org/MG/CurtisJacobson.htm
I'm leaning towards #3, but I would fabricate a cold air system because I'm not a fan of the dinner-plate-air-cleaner perched on a throttle body.
But I have a concern...#3 uses a manifold for a carburetor that smooths out the induction pulses through the venturis, but one doesn't have venturis to worry about with EFI.  Instead, with EFI I always see long equal length runners to even out the air flow pulses and maximize the air momentum in the runners.  Plus I often see hotrodders get additional power out of their engines by putting a 1-2" spacer between the carb and the manifold, which would defeat the low profile I'm seeking.
Jim:
Have you ever seen any dyno runs on the low-pro throttle body +  carb intake manifold (or sims similar to what Dan Jones posted http://forum.britishv8.org/read.php?6,42479 )?
Post by: Moderator on January 13, 2014, 10:10:11 PM
Quote1 - The lower manifold is the same on GEMS and Thor.
Similar height, but different in many other ways.
I share your concern about option 3...
To cloud the issue even more, you could divide "3" into sub-options. There are multiple aftermarket 4-barrel manifolds to consider in lieu of the Buick design. This article shows six of them: http://www.britishv8.org/Articles/IntakeManifolds.htm
Post by: BlownMGB-V8 on January 13, 2014, 11:26:22 PM
You could use short stacks and improve the upper RPM a bit. That would also let you go with a shorter plenum cover if you made your own. Might want to look at the two EFI intakes and see which one has the largest diameter and shortest runners and use that one all else being more or less equal.
Post by: mgb260 on January 14, 2014, 08:02:57 AM
On alternative #3. You only need a spacer for more top end power. You will gain 20-30 HP on the stock intake by opening the 4 holes into 2 oval openings similar to the Performer intake.  You may have to weld a little if you expose the water jacket under the carb base. You don't want a single plane intake unless you plan on racing. The dual plane stock intake is the lowest profile followed by the Offy, with the Performer the tallest. You should port match any of them. I've seen dyno graphs averaging 30-50 more HP than carbs with same intake.
Post by: GT8MX on January 14, 2014, 08:28:53 AM
QuoteTo cloud the issue even more, you could divide "3" into sub-options. There are multiple aftermarket 4-barrel manifolds to consider in lieu of the Buick design. This article shows six of them: [www.britishv8.org]
This article leads me to the dual-plane since I'm not building a race car or track car.  The car will see track time, but it will see a lot more street time.  At least the factory BOP 215 dual-plane intake is one of the lowest.  That's what I am after.
QuoteYou could use short stacks and improve the upper RPM a bit. That would also let you go with a shorter plenum cover if you made your own. Might want to look at the two EFI intakes and see which one has the largest diameter and shortest runners and use that one all else being more or less equal.
That's what the article by Glen Towery also suggests - lowering the upper manifold - and that may have the least collateral damage.  By lowering the manifold, the plenum is lower, but nothing else has to be changed, except the runners are a little shorter.
I Googled around a bit and found several reviews of the throttle body EFI replacements for a carburetor, and they performed as well as the carb without all the hassles of a carb, but I didn't find a comparison of a long-runner EFI versus the throttle-body EFI, although I remember reading a test several summers ago where HotRod or Popular Hotrodding magazine did just that and got marginally better power from the long-runner EFI..
Post by: BlownMGB-V8 on January 14, 2014, 12:40:57 PM
Am I mistaken in thinking Glen's article deals with cutting down the cover and base plate of the plenum? What I was suggesting might be a little more dramatic. If you removed everything from the short stacks but the bell how long would it be? Less than an inch? The taller ones would be longer of course but this might let you get significantly more than just cutting down the cover and base plate would. In fact I did see one article where the owner cut trumpets into the base plate itself. I have no idea how that worked out, the length of the runners would have been different. But in practical terms the OEM Buick intake is really pretty good. I was running a 7000rpm screamer with one. That and the short 4bbl throttle body and a low profile air cleaner will keep things pretty low.
Post by: Moderator on January 14, 2014, 02:00:28 PM
Jim wrote:
QuoteMight want to look at the two EFI intakes...
Here they are, side by side:  (with Thor on the left)
I set a couple unmodified trumpets on the manifolds for grins. Thor didn't originally use steel trumpets. 14CUX and GEMS both used trumpets 100mm long.
Incidentally... I need to clean out my garage. If you want some Rover aluminum to play with, make me an offer.
Bill, you haven't described where you want your torque curve to peak. I'm not sure radically shortening the stacks is a clever idea for a street car. (You could possibly do the Helmholtz resonance calculations to optimize for a specific rpm.) You'll pretty much inevitably end up with shorter overall runner length than stock. My approach was to equalize runner volume, but leave the trumpets as long as I could while doing so.
With regard to modifying four barrel manifolds... if you're going to be milling and TIG welding anyhow, I wonder if you might just as well start with a Buick two barrel manifold? Their advantage is you can pick them up for free (or close to free).
Post by: BlownMGB-V8 on January 14, 2014, 03:27:34 PM
There you go, look at the length of those stacks. Now while it is true that optimal runner volume should be kept close to cylinder displacement, meaning you'd want to thin out those runner walls from the inside at the same time as shortening the stacks if you can (and my wouldn't that be fun), the resonant frequency is dependent on volume and it being desired to move the powerband upwards anyway, trimming the stacks is the practical way to do that, at the same time allowing the cover to be made shorter. The real question is how much, but the calculations should not be difficult. Measure the current volume and then do a proportion based on the OEM torque/HP curve and if you want to go up 20% reduce the volume by 20% by shortening the stacks. Why wouldn't that work?
Post by: mgb260 on January 14, 2014, 03:35:34 PM
Curtis, That is an excellent idea on the 2 barrel manifold. I think it could be modified very easily with the Edelbrock divided 1/2" spacer. Probably be almost identical for a much lower price. I think Bill already has a stock 4 barrel manifold but, he may want to pickup a cheap 2 barrel one to modify. You can gas weld the intake with aluminum rod similar to brazing. Even use a small Mapp gas bottle. Here is a picture of the fresh air intake instead of conventional air cleaner.
Post by: DiDueColpi on January 14, 2014, 05:52:30 PM
What about modifying the 4BBl manifold to take the top hat directly.
Then mount your throttle body in front of the top hat.
It would make for a super low profile intake.
Post by: joe_padavano on January 14, 2014, 06:15:42 PM
"What about modifying the 4BBl manifold to take the top hat directly.
It would make for a super low profile intake."
Or, just buy one of these:
http://www.edelbrock.com/automotive_new/mc/efi/intake_elbows.shtml
Post by: GT8MX on January 14, 2014, 06:35:50 PM
QuoteAm I mistaken in thinking Glen's article deals with cutting down the cover and base plate of the plenum?
You are not mistaken.  That is correct.
QuoteHere they are (Thor and GEMS manifolds) , side by side: (with Thor on the left)
Thanks.  If I were to extend air horns toward the front (like a header in reverse) to a plenum box i make, which is in turn, fed air from the front of the radiator, the GEMS lower manifold would look better, I think.
Quoteyou haven't described where you want your torque curve to peak
I would like it to be in the 3500 area for street use, not race.
Quoteyou might just as well start with a Buick two barrel manifold
QuoteYou can gas weld the intake with aluminum rod similar to brazing.
A great idea made easier.  I can't TIG, but I can braze (and epoxy).  I'll look on eBay.
Quoteoptimal runner volume should be kept close to cylinder displacement,
A good rule of thumb to remember.  Thanks.
QuoteHere is a picture of the fresh air intake instead of conventional air cleaner
Yes.  That's what I was picturing for mounting ontop of the throttle body and 4-BBL manifold.
QuoteWhat about modifying the 4BBl manifold to take the top hat directly.
That's a great idea!  That idea is one of those,"why hadn't I thought of that?" Thanks.
Post by: GT8MX on January 14, 2014, 06:50:24 PM
A follow-on question that perhaps should be a new thread....
In using EFI, am I heading down a path where I will need catalytic converters?  If so, that will be a problem, because it would be hard to find a space to fit them except behind the axle, which might be full of muffler.  I don't believe I need catalytic coverters to pass safety inpsection because the car is a 1968 Spitfire so there are no emission limits that have to be met.
Relevant questions:
1 - Can Megasquirt work with closed loop O2, but no catalytic converters?
2 - Can GEMS work with no catalytic converters?
3 - Can I put the catalytic converters behind the rear axle, with the downstream O2 sensors still mounted behind the converters?  Is that too much of a lag between the O2 sensors upstream of the converters and the O2 sensors downstream which would cause Megasquirt / GEMS to "hunt"?  Or would the upstream O2 sensors need to be mounted behind the rear axle just ahead of the converter?
Thx,
Post by: GT8MX on January 14, 2014, 06:54:09 PM
QuoteOr, just buy one of these: (Edelbrock intake elbow)
Cool!
Post by: Moderator on January 14, 2014, 08:17:48 PM
I think you're going to want to become friendly with one of Houston's many welding shops. Nearly every idea floated in this thread involves welding. (Fuel injector bosses!) Some of these joints are going to be very visible too. IMHO, TIG is the way to go.
The welder I used to know in Greensboro was great. I couldn't afford his daytime rates, but he was happy to work on stuff after 9pm while drinking beer and talking about Harley Davidsons with his buddies. His late night rates were affordable.
Megasquirt doesn't know or care about catalytic converters.
A "wanted" ad in our classified section might help you find a sweetheart deal on a 2bbl Buick manifold.
Post by: DiDueColpi on January 14, 2014, 09:59:11 PM
Great find on that elbow Joseph. I especially like the low profile box type.
Bill,
Using the GEMS injection is going to be problematic. The ECU is coded to the body computer of the vehicle that it came from.
It won't run at all without a signal from the BCM.
It keeps a vehicle that breaks down every 15ft from being stolen and driven 20ft.
The ECU can be unlocked and reprogrammed to work, but it's very expensive.
Factory fuel injection systems are very inflexible and resistant to changes out of necessity
So an aftermarket tuneable system makes more sense.
Megasquirt and SDS are two injection systems that I use a lot.
Both are relatively inexpensive and easy to use once you get over the initial learning curve.
You can use the GEMS manifold or any other for that matter with either system.
Hope that helps.
Post by: GT8MX on January 15, 2014, 10:45:45 AM
QuoteMegasquirt doesn't know or care about catalytic converters.
Outstanding.  The GEMS system uses 4 O2 sesnsors - 2 upstream of the catalytic converters and 2  downstream of them.  Another reason to use Megasquirt (at least not the factory EFI controller).
QuoteUsing the GEMS injection is going to be problematic. The ECU is coded to the body computer of the vehicle that it came from.
QuoteMegasquirt and SDS are two injection systems that I use a lot.
That seals it...Regardless of the induction system I end up using, I will use some aftermarket tuneable controller.  I'm going to start researching Megasquirt and SDS.
Thank you all for your guidance!  This has been terrific.
Post by: mgb260 on January 15, 2014, 06:36:04 PM
I would use a angle iron jig for drilling holes for bungs and chamfer top of holes. Tight slip fit and precut angle on bottom of bung. Then use this filler rod that anyone can do with a Mapp torch. A lot of guys use JB weld or Lab metal Epoxy. It is most important to have the fuel rail and intake holes identical. There are hold downs on the fuel rail to intake. The newer LS3/LS7 injectors are rated at 40lb and are much shorter and use the same o rings.
http://www.aluminumrepair.com/video_new.asp
Post by: GT8MX on January 17, 2014, 11:17:32 AM
Quoteuse this filler rod that anyone can do with a Mapp torch - www.aluminumrepair.com
I was not aware of this.  Thanks.  Their site says they also have brazing rods for cast iron.  I 've tossed out cast iron pieces beause I don't / can't weld cast iron and it wasn't worth it to pay somebody else.
Post by: BlownMGB-V8 on January 17, 2014, 03:01:43 PM
You can weld cast iron pretty easily with nickel rod. It's kinda expensive but works well.
The fluxless aluminum brazing rod will discolor and darken so your repair will show up, and it isn't as strong as a TIG repair.
Post by: 75sixer on February 25, 2014, 01:31:38 AM
Years ago I was on this forum but mostly lurked without posting but have recently returned and now may have something of interest. My project is installing a Rover 4.0 into a TVR 2500M. The fit is extremely tight so there's been a fair amout of fabrication including building a set of headers that go up and forward. Hood clearance has been very tight so I've ended up fitting a Thor manifold but scrapped the throttle assembly and used a pair of Volvo throttle bodies. Both bodies sit close to tehvalve covers on adapter blocks that change the Volvo shape into the rectangular shape of the plenum. The car is a long way from being on the road but it does run although needs tuning. Engine management is Megasquirt II using the original wasted spark coil packs. If anyone has a Megasquirt msq file for a Rover 4.0 to share I would appreciate it very much. Now the only thing too tall is the dip stick and that's easy.
Appreciate all the creative projects in this forum!
Post by: DiDueColpi on February 25, 2014, 03:10:28 AM
That makes for a pretty sweet looking low profile intake Rick.
I'm a Volvo guy so using the white block throttle bodies makes me happy!
And the WOW (weird or what) factor when you open the hood is worth it alone.
Welcome back. Kinda looks like you belong here.
All hail the mighty "B" cam.
Post by: Moderator on February 25, 2014, 09:13:17 AM
That's so very cool!
Post by: BlownMGB-V8 on February 25, 2014, 05:12:07 PM
I like it. Very..... different.
Post by: 75sixer on February 25, 2014, 09:32:36 PM
Thanks. Still very much a work in progress and looking forward to more moderate temperatures to get back on it. I'm in Maine and this coming week is forecast for highs about 20 degrees.
This is a picture of what the engine bay looks like now. Have built a thermostat housing that mounts to the front of the intake and connects to an aluminum tube to the radiator. Used a small framed Denso 105A alternator and an spring loaded idler to tension the belt. The headers are something I cobbled up from stainless tubing connecting to 2.25" twin stainless pipes. She's quite loud with the crack of a Nascar machine and that needs to be addressed. Engine managemnet is Megasquirt reading a toothed wheel on the balancer for ignition timing. Transmission is a T5.  Lots of sorting, cleaning, and rerarranging yet to be done.
Post by: Truk_Snave on March 16, 2014, 12:51:40 AM
Gems system does not talk to a becm
Thor on the other hand is another matter :-)
Post by: DiDueColpi on March 17, 2014, 12:38:09 PM
I'm afraid it does Kurt.
The ECM recieves a digital code from the BECM to enable the injectors.
This happens over pin 25 at the ECM.
Without this code the ECM will not power up.
It can be defeated by reprogramming. But usually the cost doesn't make sense. Unless you are keeping it in the Land Rover.
Post by: Truk_Snave on March 17, 2014, 01:54:36 PM
in a discover series 1 there is no becm
there is however a  multi funtion unit that does stuff like turn signals etc
I looked and pin 25  at connection C1007  is for coil #1
Post by: DiDueColpi on March 17, 2014, 04:18:25 PM
You're right Kurt,
The Disco 1 doesn't use a BECM.
The early ones used the CUX14 injection without any security features.
The Disco 1's that used GEMS started in 1996 and had a security code fed to them from the theft alarm unit.
Its pin 26 ( I know, I said 25. didn't have my glasses on straight I guess) @ C1017
It's the same issue as the Range Rover.
No coded signal, no start.
Post by: Truk_Snave on March 17, 2014, 05:17:25 PM
right a P38 does have a becm
now if you  look at the schem fro a disco  you will notice there is a provision for {"with out anti theft } do this you will need to ground out pine #26 at c1017 this  will work and has been working for the past 12 years since i first did it :-) please refer to diag A1 PAGE 9
 if I follow the diag not having this ground path the starter relay will not work ..
from the ETM
"On manual transmission vehicles, a ground path is provided directly to the Starter Solenoid Relay's (K137) 86 terminal. On automatic transmission vehicles, a ground path is provided to the Starter Solenoid Relay's (K137) 86 terminal via the Park/Neutral Position Switch (X16"
Post by: DiDueColpi on March 17, 2014, 07:36:17 PM
Hey Kurt,
Are we talking NAS vehicles.
I don't have anything like that on my diagrams.
And I just tried it on my 97 shop truck and it won't fire.
Post by: Truk_Snave on March 17, 2014, 09:55:56 PM
what is your "shop truck "?
Post by: Truk_Snave on March 17, 2014, 10:01:37 PM
Im using Electrical Troubleshooting Manual Part No LRL0028
Post by: DiDueColpi on March 18, 2014, 01:45:16 PM
1997 disco
Ended up with a fault code P1621 and all the remotes had to resync.
Post by: NCtim on March 23, 2014, 11:42:12 AM
I'm really interested in this. If it works then I can use the system from the 1996 I have on the 4.0.
Tim
Post by: Truk_Snave on March 27, 2014, 08:44:14 PM
it works been done for many years go look up the info in the manuals listed ^^^^^^^
I not going to list a how to on the web but the info is in the manuals :-)
or look a cat by the name of AFIROVER  on discoweb he is the wiss at this stuff
Post by: DiDueColpi on March 28, 2014, 04:27:24 PM
I think that we have our wires crossed, as they say Kurt.
You and AFIROVER are referring to the starter lockout provided by the anti theft system "spider". And it can indeed be bypassed with a simple ground wire in the disco only. Land rover also sells a bypass plug for that unit that does exactly the same thing. That gets the engine to crank but it won't turn the ecu on.
The Lucas Sagem GEMS ecu must receive a security code from the 10-AS anti theft module in a Disco or the BECM in a p38. This code is in numerical form and can be any # from 0 to 65535. Once the ecu confirms the code it turns on the check engine light to indicate that it has be enabled. You can check for it on pin 26 with an oscilloscope. It's a square wave output.
Here is a direct quote from the manual.
"Security learn mode: When the ignition is turned on, the BECM, providing it is in receipt of a valid mobilization code and is therefore not in an alarmed or immobilised state, sends a coded signal to the GEMS which the Gems then compares against a mobilization code it has stored in it. If the two codes compare OK, the Gems will allow the engine to start. This forms the basis of the immobiliser. If the GEMS ECU, the BECM, or the lockset & key fob is replaced or other data in the BECM is changed, it may be required for the GEMS to re-learn a new mobilization code. This is done by using this function to put the GEMS into Security learn mode whereby the next coded signal it receives is not compared but is instead stored as the master copy. When security learn mode has been entered the ignition must be turned off and turned back on to trigger the BECM into sending the code. The GEMS will check the incoming code and should accept it; however, if there is an error no matter how slight in the codes makeup, the GEMS can reject it, in which case there will be no valid code stored. This situation can be checked by looking at the security learn status in Inputs - Engine and Other which denotes whether the system has a valid code stored or not".
Other than having the anti theft lockout removed from the ecu by RPI or some one similar. You can utilize the 10-AS module from a Disco and have it and the GEMS synced together. Or use a product from an Australian company called Mobi-lize. It's quite clever but you still need to visit some one like me with a "Test book" "Autologic" or "Blackbox" etc. to allow a security relearn.
I'm not trying to be difficult. I just don't want someone to go to the trouble of installing a GEMS system only to find out that it won't run in stand alone mode.
Post by: Truk_Snave on March 29, 2014, 12:59:33 AM
I don't disagree with what is written but in practice  I have found it not to be all that accurate .
now that might be that I have a Test book and a black-box solutions here that makes me both dumb and not to intimidated by this issue
if it was true you would not be able to swap out ecu from disco to disco (p38's are another matter) with out having to do anything  my last 3 off road rigs have had the alarm ecu removed and one had dual ecu's( one has been reworked and one is stock ) with a spare back at the trailer that we will swap out on the trail( if needed )  with out any fancy gear :-)
K
