General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: BlownMGB-V8 on October 30, 2013, 05:35:27 PM
Title: Help getting connector pins
Post by: BlownMGB-V8 on October 30, 2013, 05:35:27 PM
It worked so well I'm going to try it again.
I need to find where I can get the crimp on connector pins for the later model Ford connectors for the IAC and TPS sensors. I believe these are the 4.6L parts as used on the Mustang. The IAC is the short fat body one that is supposed to be quicker and allow more airflow, and the TPS is the one with the oblong connector with two tabs on one side and one on the other.
Anybody know where to get those? I'm just looking for the pins. I have the connector bodies and the old wires but I want to make a clean crimp rather than use a bunch of butt splices.
Title: Re: Help getting connector pins
Post by: Rotus8guy on October 30, 2013, 07:21:26 PM
Ballenger is good for oddball automotive connectors
http://www.bmotorsports.com/shop/index.php/cPath/109?osCsid=4gl6k9b3282ctr5dh474u3gav1
Good luck,
jb
Post by: Moderator on October 30, 2013, 10:49:11 PM
That's where I got terminals and connector bodies for the Ford cam position sensor and the Chevy coil harnesses. The parts arrived promptly.
