I completed my MGBGT in July with a 302. I used the Moss coil over kit part # 268-218.At 600 miles
I noticed the shock bushings were starting to fail.I called Moss who sent me new bushings ,they are also started to fail. At this time Moss has not come up with a solution.
Has anyone else had this problem with the kit.This car is used for normal driving.Any ideas on solution?
Mike
Mike,
How about Prothane or Energy?
http://www.energysuspension.com/assets/files/energysuspension-catalog.pdf
Interested in what you do as I have about 300 miles on my Moss kit. Guess I better have a looks!
Mike
They are poly bushings,the springs are set at the lowest setting also the valve.I would think the
bushings that come with the kit should work.
Mike
Mike,
I recall mine looking like poor quality when I installed the kit, especially when I pushed them through the new large hole in the subframe for the upper mount. Sort of reminded me of WallMart products and thinking how long is this going to last. Not all urethane parts are the same.
Hey Mike,
I run into this problem with urethane bushings all the time.
They hold up well and do a superior job when stress vectors are varied and transitional.
However when subjected to a constant load they deform or "flow" and fail.
A better choice is a good old fashioned rubber bushing or a nylon or composite bushing.
If noise is not a concern then a full metal setup would be best.
Fred, you think then that urethane is not a good choice for normal street driving? Moss has been selling that suspension modification for years; surly they must know there's a problem by now. I was giving it serious thought for my GT but right now I'm replacing my radiator with an aluminum cross flow and making some changes to my steering so I guess I have a little time to think about it.
Paul
Urethane is just fine in most instances Paul.
Sway bars, control arms, suspension links etc are all good candidates for urethane bushings.
The problem crops up when the bushing is subjected to a constant unrelenting pressure.
Such as supporting the weight of a car through a coilover set up.
Unless the bushing is unreasonably large the urethane will deform and continue to deform until it finally breaks.
There are other materials much better suited to this situation.
Thanks Fred, I guess my plans are back on track. I haven't installed them yet but I have a front and rear urethane set. Still a little concern about squeaking and the correct grease to use.
Paul
Installed the Moss coilover last Winter and have put 4K miles on since...so I'll definitely check for bushing wear when it goes on the Winter blocks....as I recall the bushings are Ozzy made.(SuperPro?)
Graham,
I think the bushing are the ones on the shocks. Those were the only black ones on my kit and looked to be of suspect quality. I am sure Mike A will let us know if that is correct.
What size are they ID and OD I may be able to help you.
Thanks to every one for there input.I have contacted GAX technical who wanted the photos .Have
not gotten a responce at this time.I will let everone know when I do.
The bushings are the ones on the shock.
Bill I will let you know the size if I can ,it may be hard to do on the failed ones.
Thanks again
Mike
Coil over bushings as per e-mail This is the way they should be.
Bill,
I do have the sleeve,it is 1/2id 3/4od.1 3/4 long.They use a poly spacer in between the bushings.What material are yours made from?
Mike
Then there is low quality bushing, all QA 1 US built shock use the bushing I picture. My front end kit that was installed in 2005 still has the original bushings in the shocks.
Get a better quality bushing.
Mike A,
Did you ever get a response from Gaz? While my car sat over the winter the bushings have failed. Found this yesterday when the car was lifted to work underneath. Less than 350 miles!
Mike
Simple polyurethane tends to be something of a biodegradeable compound and needs certain fairly specific stabilizers to give it any kind of a usable lifespan. Those stabilizers tend to be specific to the application also and it seems to be pretty easy to be off just a bit on the formulation, which results in a reduced service life. Either there is something of an art in getting the formula just right, or certain chemists believe in planned in obsolescence, but a service life of less than five years does not seem to be all that uncommon (in some cases considerably less) while a lifespan of over ten years is not infrequent in superior compounds. The durometer or hardness seems to be a factor as well with softer parts tending toward earlier decomposition.
By now Urethane parts have been around for something like 2-3 decades so we're beginning to see a track record. Based on that the best is to pick those products that have a history indicating that they should be able to meet your requirements. Durability of urethane *can* be better than rubber but that isn't saying it always will be.
So what have we learned to date? Any news from GAZ or Moss on this issue. I am planning on the Moss coil-over for my car also.
Tim
What I've learned is that in general, expecting a urethane bushing the size of a shock end to support nearly 1000lbs and absorb shocks for 100K miles without deforming is not really very realistic. If any *can* do it, they are made of an exceptional material indeed and we need to identify them.
(approx. 500# at wheel x approx. 2:1 ratio at shock)
Jim,
They are not lasting 500 miles so there is more to it than that. Gaz had to change suppliers a few years ago due to a fire that consumed the original source.
Energy makes a suitable replacement.
It's a lot to ask of any bushing.
Funny QA-1 have no issues according to Bill! Also it's how they are sold so one expects them to work. Gaz does employ Engineers so I expect them to work no mater what you believe should be used. If rubber works in lots of OE Coilover application I believe Polly can be formulated to function for more than 500 miles! Oh and Jim if you were the one who made the purchase and now had to rip it all apart you too might be a bit pissed.
Should anyone want to buy the Moss setup, order three sets of Energy 99105G bushings to use in place of what comes in their kit. Three are needed because one set needs to be cut up to get the extra length in the lower bushing, this is also what Gaz did. Or source one that has a wider spacing. Another option may be the nylatron bushing Moss sell for the lower control arms. Not sure of noise etc though. Other than the bushings I am happy with the kit. Moss has been stand up guys on this and they are working on a fix as well right now. From what they say Mike A and I were the first to have the issue.
I had GAZ shocks with my Hoyle suspension kit. The bushings failed in about 1500 miles; same for all replacements. I finally went to QA1 shocks and the bushings have held up well for over 10,000 miles. I also like the QA1 shocks better because the adjustment only stiffens the rebound; the compression damping is fixed and relatively soft. With the adjustable GAZ shocks, the compression and rebound are adjusted together. To get acceptable rebound damping, the compression damping was much too stiff causing the car to jump sideways on bumpy corners.
Larry,
With your replacement bushings on the Gaz, were they all Gaz or did you try another manufacturer?
Mike
I used GAZ replacements. I considered trying another type but then a shock shaft bushing wore out on one and I gave up on them.
I have just installed Moss coil Overs and after reading above comments begining to wonder wether the cost and effort are worth it. if you guys are on average getting 500 highway miles from a set of bushes there is a major problem in manufacture and I would think both GAZ and Moss have a case to answer in selling sub standard components, that by the way are of a safty nature.
Has anyone taken GAZ and Moss to task on this issue.
Tony,
I believe Mike A and myself have both taken Moss to task. Simple answer is change out the bushing if you don't want to do it again at a later date. Maybe we were both just unlucky, maybe Poly is the wrong material. Just be sure to keep an eye on them over the first few 1000 miles.
Any updates on this issue? I´m just about to fit my Moss coilover kit.
John
Anyone using the same Moss kit in Europe can use PowerFlex PF99-111 - they are 95 shore. Don't know what the Moss ones supplied are but they feel softer than the powerflex bushes. Again you need 3 sets - one set you will need to cut up to make a spacer for the bottom shock eye.
Definately something amiss with the Moss Supplied Bushings. One shock was ok but when I took out the bushing from the other it completely disintegrated. It's more like crumbly wax than Polyurethane. Kit is maybe 8 months old and never been assembled.
I tried to ignore this thread, hoping it wouldn't effect me. I installed the Moss/GAZ shocks shortly before driving to Palestine TX for BritishV8 2012. I drove to Omaha for the 2013 meet, and I've been driving a lot since then... so I guess I probably have at least 7 or 8 thousand miles on the bushings. I'm not getting any front suspension noise and I don't feel any slop in the front suspension with my car on jackstands. I can't see the upper ends at all without taking things apart. The bottom bushings look distorted, but I don't think they've collapsed or crumbled as bad as what's shown in photos above.
Now, I'm thinking of taking off on a long road trip. (There's going to be a great vintage car race at Watkins Glen.) So, I may try making/installing some nylon bushes in a hurry. Anyone have tips about making/using nylon bushes? If I need replacement bushings in a hurry, do you think I might find something suitable at NAPA or CarQuest? Rubber maybe? We didn't always have polyurethane options, did we? Or should I just get in my car and drive? They really don't look THAT bad.
Curtis, might I suggest some alternatives to nylon, as it is known to absorb water?
The traditional choice in a more or less inert engineering plastic is Delrin. And that works fine but is quite hard, therefore does not give much isolation, and pretty much requires a lubricant to avoid squeaking. I would characterize it as a "dry" plastic. Probably more suited to competition uses.
I think UHMW (ultra high molecular weight polyethylene) would be about the best choice. It isn't quite as hard as nylon (but close), does not absorb water, has a "soapy" feel and is relatively self lubricating. Commonly used in equipment as bearing surfaces to lessen sliding friction. Generally a good bit harder and more durable than polyurethane, which is highly dependent on the particular additives used. Does not deteriorate with age. Available in standard forms, bar, sheet, rod, etc.
QuoteThe bottom bushings look distorted, but I don't think they've collapsed
Mine too! ...this is the second driving season for the Moss/GAZ suspension. I've reconciled the fact that I'll be changing out the bushings this Winter probably with the Energy Suspension 99105G bushings.
Moss clearly has some homework to do to ensure a longer lasting product.
Curtis & Graham,
At least you got some miles out of them!
Nylatron, Delrin, Rubber, interested what you guys end up trying. Front inner control arm bushings are the same size for the top, bottom needs the extra set cut to make up the extra width.
Plain rubber bushings do not work on a vertical loading, A arms rubber bushings are loaded sideways and it is minimal.
High performance shocks use Delring bushings and Teflon (different compounds). To effectively use rubber bushings in a shock were the loads are vertical, will not work.
Standard shocks use rubber bushings, this bushings are pressure fit to the shock and it is a different compound. Once the rubber is pressed into the shock it is contracted which makes it harder.
If a rubber bushing is found that fits the shock in questions, then it can be pressed in to the shock with a sleeve to further compress the rubber.
Stay away from teflon too since it creeps under load and deforms easily and permanently. Glass filled teflon is better but still deforms and is slightly abrasive. Delrin will wear unless lubricated, is the best for holding shape under pressure, but does not absorb side loads well because it is so hard. There is no ideal material for such high loading and the ultimate solution is to replace them regularly. Hence the "Race Only" designation. I'd try UHMW and if that doesn't work go to delrin and live with oiling and the squeaks(maybe). Or switch to heim joints which will still need replacing but at longer intervals.
Ok, I'll bring this back from the dead in an attempt to get a "final" answer. Has anyone used the Energy Suspension 99105G bushing? If so, what is the verdict?
Scott, Mike Stemp did in the first page in this thread. I don't know if Graham has yet.
What is the latest on all of this? Has Moss changed the busing material in the shocks? There is an ongoing discussion on the MG Enthusiast sight with a picture of a failed shock bushing but the picture does not show the bushing that Moss or Gaz used in there setup. The bushing appears to be a Prothane brand and it looks to be too big? Anyone know? Thanks for any input.
I can't speak to any bushing changes made to the Moss product since the early failures...Kelvin would know.
I can say, that since changing to the Energy Suspensions 99105G bushings, that although they seem to hold up longer, today, they are also showing signs of distortion.
For the record, here's a photo of the early Moss bushings after 2 driving seasons.
I really do not know a lot about the poly bushings..but do have some experience with injection molded parts from my years at Chrysler...if during the molding process those parts get "too hot"", they will look ok but start to crumble prematurely..moss needs to do an on site visit to the bushing supplier to review their processes...e.g. if the supplier is using a small percentage of reground/obsolete material in the process to save money parts can and will fail prematurely...if "virgin material" is used the part should to standard...
One of the properties of plastic parts is that they are "plastic". In other words as an amorphous solid the material can continue to flow from a high pressure area to a low pressure area, the rate being dependent on the pressure. You can see that in Graham's old bushings where they have gotten thicker on one side and thinner on the other. Finding a composition that resists this flow adequately yet is still compliant enough to absorb shock loads and has sufficient ductility in shear is sort of the holy grail of suspension bushings. A hard rubber is fairly good at it but has limits. Polypropylene was once considered the cure all but it really hasn't turned out to be all that and some formulations are better than others. By and large longer lasting has meant stiffer, with Delrin at the upper end of the scale.
In practical terms what this means is that you find the hardest formulation of poly that you can live with and change out the bushings when they approach metal-to-metal contact, or install delrin and live with the squeaks. Maybe install grease zerks. But each time you remove compliance from the suspension you get more harshness. This applies to the tires as well. So the road to good handling might be paved with loose fillings and other bolts and nuts.
It's a highly loaded component. 500+ lbs on each bushing as a constant load and several time that as impact loading. Of course it will take a beating. Just one of the compromises inherent in the coil-over design. It's why they are used primarily for racing or custom applications where they are likely to have more frequent replacement. You'll note, even the stock MGB spring coil sits on a rubber seat IIRC. Well, maybe it doesn't, I'm not sure anymore, but it should.
I talked with Moss yesterday and according to them the problem was solved in early 2019. I am interested in this because I am going to change to either a Moss unit or the Hoyle unit. It looks like both have had problems. Hoyle uses Autobush when they supply Polybushes. I think this is only for the A arm inner bushes. I am presently waiting for an answer. GAZ supplies the shocks and springs for both units along with the bushings. I do not know what bushings they use. If you go to the Autobush.com website they claim that their bushes only use a compound and grease secured from an American supplier, because of reliability issues. They guarantee there bushes for two years from date of purchase, which is the identical length of time for the GAZ shock unit supplied by Hoyle.
BTW I posted a picture of the current GAZ unit on MG enthusiast web site, so take a look and see if it any different than those supplied with earlier units as per Graham and others.
In summary, I have read somewhere on the internet that GAZ had a fire and that is what caused these problems, but I have not been able to verify that. To my mind, I think that Moss and Hoyle have any problems sovled as of now, but I don't know about longevity. Certainly, any coil over shock bushing should last longer than one or two seasons. They all support the weight of the car. Some are subjected to more load than others--the farther outboard the less the weight or force on the bushing. That is probably why the Hoyle and the Guzman units have less or no problem as apposed to Moss.
There ya go, just my two cents.
That's why we used solid spherical rod ends on the coil-overs in the MG Roadmaster and my roadster which operate at a 2:1 ratio. I think the Roadmaster has 9 seasons on it now.
QuoteBTW I posted a picture of the current GAZ unit on MG enthusiast web site, so take a look and see if it any different than those supplied with earlier units as per Graham...
Here's the shock info that I have on file
Moss Coilover front suspension #268-208
GAZ Part# GP8-1129
MOSS Europe Part# TMG49025
MOSS USA Part# 268-199
Graham, This looks the same to me as I posted on the other web site. I did query Moss Europe and got this answer:
Since posting this picture of the Moss Coilover shock unit, I emailed Moss Europe for an explanation of what happened.
Here is my email:
Comment: Regarding your part no. TMG40750G (and similiar). I notice that you sell a replacement upper and lower bushing kit for this part number. May I ask why? I have read on the internet horror stories of bushing failures in very short times ranging from destruction to the hollowing out from load and consequent distortion of the bushing hole. These claims and your substitute bushing prompts my question. Please let me know what the present status is of these coil over kits. This and some others are presently on backorder--Is these because of bushing failures? Thank you for your help.
And their reply:
Hello James,
For years we have offered alternative bushes as (A) replacement and (B) upgrade.
Problem then occurred in 2009 with Gazzmatic poly bush supplier (Powerflex) as their factory burnt down. Gazzmatic found another supplier (they did not want to use superpro) but their bushes were not as good.
They have been trying out new design bushes over the years using bottom bushes such as fitted to Peugeot expert but these suffered distortion.
They have since used a bottom bush which is as used in their Jag range which has cured the problem,
We cannot build anymore kits at the moment as we are out of stock of 5/16unf bolt.
Regards
Mick Pratt
Technical Support
Moss Europe Ltd
Unit 16, Hampton Farm Business Park.
Bolney Way. Feltham. Middx
TW13 6DB
QuoteThey have since used a bottom bush which is as used in their Jag range which has cured the problem
Part no?.... kit?.....
At least, the bottom bushes are easier to replace than the tops!
Graham,
Spot on on the ease of replacing bushings. Perhaps if you email Moss they will tell you the part no. of the bushing they now use. They do have the SuperPro and the part no.s are TMG49025ASPK for the top, and TMG49025BSPK for the bottom. They are listed on the Moss Europe web site.
Thanks for the SuperPro info, James. Have sent an inquiry off to Moss UK.
As a follow up to conversations with Moss (UK), it appears that GAZ has released an updated shock with a revised bottom eye/loop that precludes using the TMG49025BSPK SuperPro bushing...this part will only service the old shock eye.
Here's photos of the original shock and bush (right) vs the new design shock and bush.(left)
I have just acquired the late build Moss Gaz coil over shock kit. The bushings are indeed different. Please see the picture for the look of the new lower shock bushing.
I am getting old and hate to learn new things. I just learned how to resize pictures so that they could be posted on this site. I use an Android computer now after years of using Microsoft. I like the computer but the picture resizing (I thought) was a challenge. I did as Curtis suggested and downloaded a free resizing program and the above post is a example of that. I will post more pics of the shock as I take it apart for analysis.
Suffice to say that this shock and the bushings are significantly different than the earlier examples. I do not know whether this mod of the lower busing solves the problem of bushings wearing out, but according to Moss it does. It is a pity, as Graham has just revealed that the new shock does not accept the Superpro busing replacement that Moss Europe sells. It is a bigger pity that they do not mention it on their website.
Graham, Do you know if the upper replacement bushing kit from Moss Europe fits the latest shock offering from Moss? The lower one certainly doesn't fit!
MOSS rep indicates that Superpro Part Number: TMG49025ASPK will service old and new shock.
https://www.moss-europe.co.uk/superpro-bush-kit-gaz-shock-absorbers-top-polyurethane-tmg49025aspk.html
Which Moss rep? Kelvin?
QuoteWhich Moss rep? Kelvin?
Nope.....inquiries went to Moss UK (Mick Pratt)
Hopefully, it was good intel.
To all that uses Gaz Coil over shocks.
Me too have Gaz coil overs on the front suspension and a 4 link suspension with Gaz coil overs on the rear axle. The car is still on a rotissery so I have no experience or data about the lifetime of the bushings. I will investigate with Gaz in the UK about this issue. That is where I got the shocks from.
In the meantime I will keep looking for further news about this issue.
I have the Hoyle front suspension but not road tested it. The A arms are fitted with poly bushings from Australia.
Werner
Werner, Welcome to the conversation. I don't believe that you will have the same problem with Hoyle front suspension which uses a different shock. I don't think there have been any issues with the Hoyle front suspension shock bushings. In my conversations with Hoyle they use Autobush at present for the A arm bushings but previously have used the SuperPro from Austrailia. If you are interested stay tuned for more information on the Moss Suspension bushing probems, history and what is being supplied.
