General Category => The BritishV8 Pub => Topic started by: WedgeWorks1 on September 28, 2013, 09:44:17 PM
Title: Finally!!!!
Post by: WedgeWorks1 on September 28, 2013, 09:44:17 PM
Its up and I am partially moved into my new 26'x30' garage. Unfortunately though a TR6 for a new harness and a 57 Thunderbird has beat my TR8 for occupancy. I do however have the walls covered just to give it that homey feel. A loft is coming and then a 2-post lift!
(http://i1012.photobucket.com/albums/af242/wedgeworks/Man-Cave/GaragePic39_zpsad3efd03.jpg)[/URL]
(http://i1012.photobucket.com/albums/af242/wedgeworks/Man-Cave/GaragePic41_zpsed53f83f.jpeg)[/URL]
(http://i1012.photobucket.com/albums/af242/wedgeworks/Man-Cave/GaragePic42_zps69155a23.jpeg)[/URL]
Title: Re: Finally!!!!
Post by: BlownMGB-V8 on September 29, 2013, 11:04:42 AM
Might look empty now, but just wait!
Post by: BWA on September 29, 2013, 11:55:26 AM
Where is the insulation and heater?  Doesn't Maryland get kind of cold in the winter or do you stop doing stuff over the winter?
Great looking garage.
Byron
Post by: rficalora on September 29, 2013, 04:06:58 PM
Looks great Mike!  I like how you kept the ceiling high.  Plans for a lift?  My ceiling is only 8' - I've been reading up on what it'd take to revise it.  Seems like it's a pretty big job.  You were definitely smart to build it that way from the outset!
Post by: WedgeWorks1 on September 29, 2013, 07:06:51 PM
I am doing insulation and eventually drywall. Two post lift yes! Since the bottom of the ceiling is 13'-3"
Post by: MGBV8 on September 29, 2013, 07:34:11 PM
13'? Great. I was trying to guess based on the height above the garage doors plus the raised ceiling. It's higher than I thought.
Post by: WedgeWorks1 on September 29, 2013, 09:13:04 PM
I have 8' tall garage doors and the walls are 11'. I have TWO 240v 8 and 6 gauge lines run out to the garage. I'm ready for the lift, compressor and welder.
Post by: billymgb1000 on November 01, 2013, 09:48:31 PM
Garage looks awesome did you make sure your floor is thick enough for the lift
Post by: WedgeWorks1 on November 01, 2013, 09:56:43 PM
It's a 5 inch slab with two grade beams 24" wide x 16" deep right where the lift will go.
