General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: MGB-FV8 on September 02, 2013, 11:36:36 PM
Title: Cooling article........
Post by: MGB-FV8 on September 02, 2013, 11:36:36 PM
This article pretty much depicts every problems and solutions that small British car owners may experience; very good education for anyone!
http://www.hotrod.com/techarticles/engine/cooling_system_tech/
Title: Re: Cooling article........
Post by: BlownMGB-V8 on September 03, 2013, 10:54:34 AM
A good starting point but it did not address coolant flow and that's a big issue in a car that might have the radiator partially above the coolant jacket in the heads. That problem is one that particularly does apply to us.
Post by: Scott Costanzo on September 03, 2013, 12:45:52 PM
This is the best article on cooling I've run across. It's slanted toward the LS motor but I think it applies to all.
http://www.pirate4x4.com/tech/billavista/Cooling/
Post by: MGB-FV8 on September 03, 2013, 05:54:12 PM
Scott, that was an interesting and more in depth article than my basic article link.
Post by: Jim Stabe on September 03, 2013, 10:08:07 PM
I agree the Griffin article is probably the best out there. I referred to it a lot when designing my cooling system.
Post by: BlownMGB-V8 on September 04, 2013, 02:00:28 AM
...not that it's biased or anything...
Good reference though.
Post by: Moderator on September 04, 2013, 03:59:54 AM
I smiled as I read the advice about using Spal electric fans for about the fifteenth time. Lately I've been thinking of removing  two perfectly good Honda OEM electric fans after twenty-one years of reliable service. I think I might replace them with a Flex-a-lite belt-driven fan. Simple. Lightweight.
Post by: Jim Stabe on September 04, 2013, 06:49:24 PM
OEM's make the best electric fans - period!  All you have to do is compare the wire size and you can see which has the most power. The big American OEM fans have a minumum of 10 ga and some are 8 ga so they have some serious power.The aftermarket ones have 12 ga if you are lucky and they usually provide a 30 amp relay. You have to have a BIG relay to make the OEM fans work because of the in-rush current when they start up, at least a 70 amp.
Post by: BlownMGB-V8 on September 04, 2013, 07:10:32 PM
Yea, I've been thinking about that. Any leads on a plug-in for the standard bosch ice cube relay with a higher than 40A rating?
Someone said the Caravan fan was exceptionally powerful.
Post by: DiDueColpi on September 04, 2013, 09:56:35 PM
The Bosch " icecube" style relays can actually handle more than 40 amps.
The problem is that the terminals can't.
So you won't find a reliable direct replacement.
Soldering the terminals onto the relay will buy you 55-60 amps.
Or a better choice is the VW relay # 357 906 381 B. (just an example. they are available from many euro sources)
It's the same size as the ice cube relay but it has bigger power terminals.
It's rated at 70amps 12v continuous.
Terminal blocks are available for them (with the same footprint) that directly replace the small terminal ones.
Post by: Robrover on September 24, 2013, 05:25:12 AM
I'm using 1998 Aussie Ford Falcon AU twin thermo fans with their integral plastic shroud cut down to fit my AFCO aluminium race adiator. Fans are controlled by Brian Baskin DCC pulse width controller which ramps fan speed up and down continuously depending on temp sensor in radiator. Got the same set up on my V8 Disco. These fans pull some serious cfm through the radiator.
Post by: BlownMGB-V8 on September 25, 2013, 10:16:16 AM
Got a link?
Post by: Robrover on September 27, 2013, 04:26:07 AM
http://www.ebay.com.au/sch/i.html?_trksid=p2050601.m570.l1313.TR11.TRC1.A0.Xfalcon+au+thermo+fans&_nkw=falcon+au+thermo+fans&_sacat=0&_from=R40
Post by: 74ls1tr6 on September 27, 2013, 11:16:14 AM
I bought two 83 to 86 dodge caravan fans. I hooked one up to a battery and it blew my hat right off my head before it was up to speed. I will be changing the TR6 fan over to one of these caravan fans, and running one on the GT build. They do have the shroud attached that can be cut down a little.
Thanks to Tom A's  research to see which one can pull up a piece of sheet medal off the ground.
The cost at U-Pull-It was $42 per fan. It moves way more air than what I'm using, and yes it has some serious wire gauge going to the fan.
Post by: BlownMGB-V8 on September 27, 2013, 12:09:01 PM
I have a rather generic fan Summit sells for the late model Camaro that looks a lot like the Falcon fan in the link above. Twin fans, sells new for about $140 I think. Moves lots of air. Not suitable for MGB without the wide radiator mod.
Post by: BlownMGB-V8 on September 27, 2013, 12:12:44 PM
Here's an oddity since we are now looking into engines such as the Toyota 1UZ and the newer Chevy engines. The 1UZ has both coolant connections near the top of the engine. I would think of that as odd enough, but apparently the connection with the thermostat housing is the water pump supply side and goes to the bottom of the radiator. Does anyone know the reasoning behind these changes?
Post by: Scott Costanzo on September 27, 2013, 03:22:00 PM
Hey Calvin,
By any chance did you measure the diameter of that fan?
Regards
Scott
Post by: Jim Stabe on September 27, 2013, 05:59:23 PM
Go look at the Volvo fans also. They are single two speed fans 16-17" but they have a neat mounting ring perfect for home made shrouds. They also have a nifty relay module for running the 2 speeds
