General Category => Triumph Sports Cars => Topic started by: BlownMGB-V8 on May 04, 2013, 07:48:38 PM
Title: TR7 V6 2bbl air cleaner
Post by: BlownMGB-V8 on May 04, 2013, 07:48:38 PM
Here is the hat I made to use a low restriction cone type air cleaner instead of the 'firestarter' triangular foam element filter. The tube was excess stock leftover from Dan's TR4-EFI system and the hat was hand formed from sheet aluminum.
The car is slated to go off to serve duty as teenager transportation and should do quite well at that task.
Title: Re: TR7 V6 2bbl air cleaner
Post by: Dan B on May 07, 2013, 08:45:05 AM
That looks great!
Post by: BlownMGB-V8 on May 08, 2013, 08:12:30 AM
I thought it came out pretty good. Plenty of clearance for the fresh air plenum, a decent low restriction filter, it clears the hood and it's shiny. With a little work it could probably be polished up even better.
Post by: BlownMGB-V8 on May 10, 2013, 04:12:45 PM
It seems to like the new air cleaner. I took the car out today and it felt rather peppy. I think this is going to work out real well, and is a good match (2bbl) for a car with an automatic.
