General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: pspeaks on July 24, 2012, 09:59:51 AM
Title: Short Nosed Water Pump
Post by: pspeaks on July 24, 2012, 09:59:51 AM
During the planning of my "radiator and electric fan installation" I've become painfully aware that I should have bought a short nose water pump, but I didn't and now think I'm going to have to revisit that ill thought out decision; which brings me to my question.  What do I do about a water pump pulley that will line up with the crank pulley?  Is there a reasonably priced supplier of Ford pulleys out there?
Post by: pspeaks on July 24, 2012, 10:30:43 AM
 -- moved topic --
Title: Re: Short Nosed Water Pump
Post by: mgbv81970 on July 24, 2012, 03:12:53 PM
Paul, I don't know any specifics about your project but I know others have had good success with using the 98-2001 Ford Explorer / Mercury Mountaineer V8 pulley/water pump setup.  It's compact and the whole setup is readily available in junk yards.  In fact, I own a '96 Explorer V8 I'm going to be putting on Craiglist soon to help pay for my exhaust system on the MG!  I'm going to ask $800 for it, if you're interested...(drive it home, it runs great)
I originally purchased the short water pump from Ford Motorsports and mocked up my radiator based on the location of where that water pump sat.  THEN I tried to find a pulley to match my others...HA!!  I probably looked under the hood of every car I could in many junk yards and came up empty handed. In frustration I had a pulley made for me by combining the "inside" and the "outside" of two different pulleys to get the right diameter and offset.  That seemed like it might work out ok for me, but then at some point I actually LOST the pulley lol, and was back to square one again.  So then I got out my drill and cutoff wheel and cut the area immediately behind the radiator even further forward to make room for standard pulleys and water pump. (In my case for a 1965 289, single groove pulleys, no AC etc.)  My engine is also set WAY back in the engine bay and required extensive mods to make it all happen, so I can't recommend my install for anyone but a complete masochist given the amount of information that now exsists on installing the Ford small block into the MGB, BUT there truely is more than one way to skin a cat, so to speak.
  There is one lesson I've learned the hard way over the years of working on my car:  If you drink enough beer and stare at it long enough, there is a solution to every problem.
Scott
Post by: rficalora on July 24, 2012, 10:04:41 PM
Paul, what a bummer.  I have a complete set of brackets & pulleys from a 5.0L T-bird which uses same short nose pump as the explorers. - at least that's what I recall from when I bought the stuff.  I could have brought it up here with me this week.  Do some research and if you want it, let me know.   I think I paid $75, but if you want it I'll sell it all for $50.
