General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: bberg on March 15, 2012, 09:43:29 AM
Title: Intake Manifold-Thermostat Housing ...help
Post by: bberg on March 15, 2012, 09:43:29 AM
I have a wildcat spider intake manifold I purchased from Ian Richardson at Wildcat Engineering back in 2006 and now want to use on my triumph Tr-8 with 4.6L engine swapping out the edelbrock.....I never purchased the thermostat housing when I bought it and need any help with where I can find one....I called Ian and he doesn't have any because there were to many options-he also said he is retiring now passing the business on to a colleague...the manifold is similar to the wilpower one available in australia..
thanks
Bob
Title: Re: Intake Manifold-Thermostat Housing ...help
Post by: roverman on March 15, 2012, 11:53:11 AM
Bob, Good luck with the "colleague". Have you checked the manifold for fit ? Mine would not fit any rover or sbb. "Maybe" a rover 4.4L .(aussie) ? I would check Offy remote houusing.   Good Luck, roverman.
Post by: BlownMGB-V8 on March 15, 2012, 02:24:01 PM
Art, what's the deck height difference between the 4.4 (P76) and the SBB 300?
Post by: roverman on March 15, 2012, 06:01:35 PM
Jim and clan. Good question, it's here in our forum-somewhere ?  Dan Jones sold mainifold to Oz ? Cheers, roverman.
Post by: minorv8 on March 16, 2012, 02:06:16 AM
I have fitted a Willpower single plane on a 4,6 engine and solved the thrmostat housing problem with std. Rover V8 part. It is not exactly pretty but works.
Post by: BlownMGB-V8 on March 16, 2012, 11:45:25 AM
I think a SBC thermostat neck might work.
Post by: Bill Young on March 16, 2012, 01:41:06 PM
Making an adaptor would be relatively simple unless hood clearance is a big problem. A piece of 1/2" aluminum plate drilled to both patterns and then countersunk for the lower pattern and you could bolt on any outlet you wanted to match the hose configuration you need. I'd recommend small block Chevy as there are literally hundereds of thermostat housings built for that engine.
Post by: bberg on March 21, 2012, 09:31:34 AM
Thanks for the feedback.....I know that Ian Richardson made two different wildcat spider manifolds-one to fit standard rover v8 heads and the other one that fits his stage 1 & 2 heads which are different.I also talked to the owner of wilpower in austraila and he said he makes all the manifolds and the wildcat spider for Ian as private label -go figure... There is a kilkenny castings water outlet part # W076 that fits the wildcat manifold but it turns toward the distributor similar to Jukka's picture-available in austraila for about $30-I believe std rov v8.I have them looking at matching another housing as well because that manufacture hundreds of them.  I did some digging and found a fel pro gasket part # 35097 at advance auto parts that is an exact match for the rover v8 bolt pattern-70mm center bolt hole to bolt hole ....hmmmmm.....says its for ford british, toyota, etc....I checked housings for a ford 4.6L engine and found looking at pictures that there are housings that are 90 degree and straight on....Im in columbus Ohio so I went to jegs store and matched a mr gasket part # 2664 ford housing $12  (lots of options there) that is 69mm hole spacing and can work-little hole widening. I went to ford dealer and found a 2000 ford crown victoria with 4.6l engine housing (motorcraft #RH44) that is straight 90 degree with nipple bleed provision on top and also a 2000 mustang 4.6L sohc water housing 90 deg straight (motorcraft #RH49) that will also work...the motorcraft has flange on the bottom (1/16 inch) where it fits into a slot that has to be taken off but it fits. And my standard TR8 housing from the original manifold also works but the hose is directly at the distributor.  I will have the manifold/housing alum coated so I dont want any chrome stuff......
Post by: hoffbug on February 10, 2019, 11:03:22 AM
Dredging up an old one... I'm working on the Astre again and am trying to figure out how to run hoses to the heater core with the Willpower intake. . The return line is on the water pump but there is no provision for a supply line off of the front water crossover where it should be.  Can you Tee off of the bypass hose somehow?
Post by: hoffbug on February 10, 2019, 01:35:10 PM
There is also a tapped hole at the drivers side rear of the manifold.. what would this be used for?
Post by: minorv8 on February 10, 2019, 03:20:08 PM
I will check my photo archives. Can't remember how I ran the heater hoses.
Post by: minorv8 on February 11, 2019, 01:44:06 AM
OK found a photo. I used the tapped hole for heater supply and a connection behind the water pump as a return.
Hope this helps.
Post by: hoffbug on February 11, 2019, 10:26:56 AM
Thanks Jukka
So you are essentially using the back port of the manifold through the heater core and  to the water pump bypass port and using the heater core as the part of the bypass?
On the stock GM engine the water flowed from the front water ports in the heads through a cavity underneath the carburetor and circle back around to the front on the manifold and exited out of the vertical thermostat housing in the front.
Have you had any cooling issues and does the heater core provide enough Heat?
On my wullpower intake the front thermostat housing crossover has a port drilled for the bypass. You can also see the modifications I had to do to my Kilkenny castings WO58 thermostat housing to get it so it would not Point towards the distributor.
Post by: mgb260 on February 11, 2019, 02:02:09 PM
You could splice one of these in each radiator hose for heater connections:
https://www.speedwaymotors.com/Inline-Fill-Adapter-with-3-8-Inch-NPT-Fitting,9244.html
Post by: hoffbug on February 11, 2019, 03:39:36 PM
Any ideas on what that threaded hole at the top of the pump is used for?
Post by: minorv8 on February 12, 2019, 01:25:20 AM
I´ve since gone the EFI route but yes it did work and provided enough heat to the heater core. The only cooling issue was my own fault. My radiator is lower than the engine, expansion tank is higher than the engine. Due to the top hose route I had an air pocket there and had fitted an air bleed connection. I ran a hose from the connection to the expansion tank. Any air would be removed. I thought that when I fitted this manifold I removed the air bleed connection from the top hose. No longer needed... WRONG ! The very test drive showed me wrong big time. So, back to garage and welded a connection back. The expansion tank is behind the engine and you can just about see a hose that has been plugged with a bolt. That is the other end of the venting line.
I have drilled a couple of holes in the thermostat so there is always some by-pass.
This is the current EFi spec. You can see the venting line running from the top hose to the tank (top passenger side). There is another hose running from the radiator to the expansion tank.
Post by: roverman on February 12, 2019, 12:32:52 PM
Jukka, have you noticed the steering get's "very light", when you take-off ?
Post by: hoffbug on February 12, 2019, 01:50:35 PM
Art..You have any idea on what that tapped hole is for on the top of the water pump I have pictured above ?
Post by: roverman on February 12, 2019, 05:24:52 PM
Air bleed, cold side temp sender ?  Forum stimulus ?
Post by: MGBV8 on February 12, 2019, 09:15:03 PM
No idea.  That hole is plugged on my Buick 300 water pump. Tony, as is all the others that I have seen.
Post by: hoffbug on February 12, 2019, 10:52:30 PM
Carl.
That what has me thinking it's something Jeep related . This pump fits a lot of applications.
Post by: mgb260 on February 12, 2019, 10:58:46 PM
Tony, Jeep 225 v6  heater bypass hose between water pump and intake behind carb?
Post by: hoffbug on February 13, 2019, 10:33:15 AM
Possibly.. I just dont know much about them  This is a list of applications.
Buick Estate Wagon 1970-1970
Application Data: 350ci
Buick Gran Sport 1970-1968
Buick Gran Sport    1967-1967
Application Data: 340ci
Buick LeSabre    1970-1970
Buick    LeSabre    1969-1965
Application Data:
Buick    Skylark    1970-1968
Application Data:
350ci
Buick    Skylark    1967-1967
Application Data: Exc. 400ci
Buick    Skylark    1966-1965
Application Data: Exc. 401ci
Buick    Skylark    1964-1964
Application Data:
Buick    Special    1969-1968
Buick    Special    1967-1964
Application Data:
Buick    Sportwagon    1970-1968
Buick    Sportwagon    1969-1964
Application Data:
Buick    Sportwagon    1967-1967
Application Data:
340ci
Jeep Trucks    CJ3    1966-1966
Application Data:
3.7 Liters and Buick Eng.
Jeep Trucks    CJ5    1971-1966
Application Data:
Jeep Trucks    CJ6    1971-1966
Application Data:
Jeep Trucks    Commando    1967-1966
Application Data:
Jeep Trucks    Dispatcher    1967-1966
Application Data:
Jeep Trucks    DJ5    1971-1966
Application Data:
Jeep Trucks    DJ6    1968-1966
Application Data:
Jeep Trucks    FC150    1966-1966
Application Data:
3.7 Liters and V and Buick Eng.
Jeep Trucks    J-100    1971-1969
Application Data:
5.7 Liters and Buick Eng.
Jeep Trucks    J-2500    1971-1969
Application Data:
Jeep Trucks    J-2600    1970-1969
Application Data:
Jeep Trucks    J-2700    1970-1969
Application Data:
Jeep Trucks    J-3500    1970-1969
Application Data:
Jeep Trucks    J-3600    1970-1969
Application Data:
Jeep Trucks    J-3700    1970-1969
Application Data:
Jeep Trucks    J-3800    1970-1969
Application Data:
Jeep Trucks    Jeepster    1971-1966
Application Data:
Jeep Trucks    Universal    1967-1966
Application Data:
Jeep Trucks    Wagoneer    1971-1971
Application Data:
Oldsmobile    F85    1965-1964
Application Data:
225ci
Oldsmobile    Vista Cruiser    1965-1964
Application Data:
225ci
