General Category => Triumph Sports Cars => Topic started by: BlownMGB-V8 on March 03, 2012, 12:11:44 PM
Title: TR-7 wired weird
Post by: BlownMGB-V8 on March 03, 2012, 12:11:44 PM
Perhaps I should acknowledge at the outset (as if there was ever any doubt) that I am an MG guy, and I realize that there are philosophical differences between the MG and TR camps that perhaps I really don't understand. But having said that I also must admit that I'm really not having an easy time understanding what is going on with the TR-7 wiring, in particular the A/C wiring, fan circuits, and the start circuit. It seems to me that there are rather established ways to do things like energize relays for instance, but when the TR electrical engineers designed the circuits for the TR-7 it seems they got really creative. Don't get me wrong, I usually think creativity is a good thing. But not with electrical circuits. They are difficult enough to follow already. Like the interconnect from the A/C condenser fan relay to the starter solenoid. I get it that not running those fans gives more battery to crank with, but isn't there already a delay circuit for the master relay? (More needless complication by the way) And isn't the white/pink wire from the ignition switched on only in the "run" position? So why does it become necessary to feed the relay ground through the starter solenoid to get the relay to turn off when voltage is applied during cranking? Couldn't they have just sourced it through the white/pink wire? So much simpler and easier to follow ant troubleshoot. Then they do the same thing on the heater fan end of it and have to put diodes in the wires to avoid backfeeding other circuits. And how does it make sense to feed the condenser fans on separate fuses yet turn them on with the same relay? If one doesn't run the air blown by the one that does just recirculates back out the one that doesn't instead of going through the condenser. It just creates twice as many failure points. And then there's the whole thing about running the harness from the fuse panel up to the right corner, around and up over the nose of the car, back down and through a bulkhead only to fit a multipin connector and run it right back through the very same bulkhead then down around the bottom of the nose to get to the fans. What the heck?!! How does that make any sense at all? Yet they did the same thing with the starter interlock wiring at the firewall. It's hard enough to figure out where the wires go without snaking them all over the car with connectors everywhere. You get an open circuit and it could be anywhere.
OK, I guess that's a bit of a rant. Sorry. All I wanted to do was fit an electric radiator fan. But I noticed one of the condenser fans wasn't running, then noticed that the contacts in the fuse panel had gotten so crappy that they would never be reliable again, so I rewired the source directly to the battery with an inline fuse the same as I was doing with the new radiator fan, but then since the fans wanted to run with the engine and A/C off I had to get into that whole mess with the A/C control relays. I installed new relays for the fans over on the battery side so the power circuit is direct and short and now I have to figure out the relay control side. The radiator fan seems simple enough, verify that the white/pink wire is unpowered in "start" and powered in "run", use it to power the relay, and ground it to a thermostatic switch on the intake manifold. On the condenser fans it isn't quite so simple. If the white/pink had been used to supply the relay coils it would be, as the manual cutout and heater blower would all be on that switched circuit. But they are on the white circuit which is powered in "start". Seriously, what is up with that? If you want to cut out the condenser fans and the A/C compressor to get more cranking power don't you also want to cut out the wipers, washer, and heater motor? It just all seems so confused. I guess I'll find a way to make it work, but what should have been a pretty simple job has turned into a week long ordeal. I guess I'm just sharing my misery. I'm already pretty sure there is no help to be had.
Title: Re: TR-7 wired weird
Post by: triumphtr2 on March 03, 2012, 07:51:50 PM
Jim. On the brighter side, Wired weird are anagrams of each other and alliterated also. Sounds like rewiring would be easier.This illustrates why these cars are no longer in existence. This gives me an opportunity to say I've been reading up on the history of your car. Pretty amazing and interesting story. Excellant reading and still lots to go. Cheers Tim
Post by: BlownMGB-V8 on March 03, 2012, 08:26:44 PM
Thanks for the compliments Tim, and I did rewire my car a few years back, but I'm not real keen on jumping in and rewiring Edith's TR-7 just now. It is however forcing me to try and understand it.
For instance, since the white/pink wire does indeed turn off when cranking (confirmed), WHY is it necessary to add a delay circuit to the A/C? That's an added relay and flasher unit, for no cause I can see but to create a 2 second pause when turning on the A/C. Couldn't be for starting the engine, and once the engine is running who cares? I think maybe I'll just remove that circuit, it's that much more to go wrong.
Then here's another weirdness. Right center relay beside the fuse block. Has a big brown wire as a feed, white/brown load, white and red control wire. Start relay? Who knows? It isn't on the schematic!
I'd love to just give up. Unfortunately that is not an option.
Post by: bsa_m21 on March 04, 2012, 12:02:44 AM
Timothy - ALL of these cars are are no longer in existance.  Not just the TR7's.  Seems the Lucas smoke leaked out of all of them.  :(
Dan,
There are about twenty variations of wiring diagrams for TR7's - and that's just the AC models.  The engineers did very weird things by today's standards.  Most of the relays and such I feel are are wired backwards, that is, power to the fan and then the relay and ground.  Very strange.
Anyhow, I've never seen the interconnect from the A/C condenser fan relay to the starter solenoid.  There is a brown wire feed from the battery that has a union that splits off wires to the starter relay and the condensor fans, switching from brown to purple green and purple pink at fused links.  Cranking should not impact the condensor fans through this circuit.
As you said, the white/pink powers only when you are cranking the motor, but it feeds the delay relay which cuts out the interior heater fans, the AC compressor clutch (to keep it disengaged), and a few AC other bits and the radio.  As far as I know, it to has no impact on power to the condensor fans.
I'm not aware of any diode on the heater fan, only the condensor fans. This prevents back feeding when running in low speed mode. Good old Triumph engineers, wiring single speed fans to run as dual speed (they run in series for low speed and parallel for high speed). Took me ages to figure out what the heck they were doing.
Here is a link to a doc that I found that is pretty clear on how the AC circuit works: http://docs.google.com/open?id=0BxOL0HRH5pDeUmM0QXdoNFZSU3lESHQ3c05lQ05JUQ
And another one on separate wiring: http://docs.google.com//open?id=0BxOL0HRH5pDeOTY1NDE3MjAtZjg4Yi00MDVjLTliODItMTY4Y2NjYTgyMTI0
(Mar 4 - fixed the bad link to the first doc and added one to another. M)
Good luck sorting it out!
Martin
Post by: BlownMGB-V8 on March 04, 2012, 02:02:32 PM
Martin, thanks for the links, that is some good information and I wish I had it earlier. My wiring seems to be different (TR-7 vs TR-8 I'm guessing) as both fans appear to switch on simultaneously using one relay. I see no way they could operate in series but will look again. However the ground side is direct to the relay so I don't think it was possible on this car. (US 1980 TR-7 DHC with A/C and carbs) I think I will set it to always run the condenser fans at full speed when the A/C is on (airflow is not that impressive), run the radiator fan from a manifold mounted (Buick V6) thermostatic switch, and possibly add a manual override. I saw mention of the starter interconnect which is as described, providing a ground for the condenser fan relay. In this car this would not turn off the heater fan etc, just the condenser fans. However the delay circuit will turn off the compressor clutch and the throttle jack (only). I think I'll rewire the sucker, get rid of the interconnect and delay circuit and control all that with the W/K wire, with the new relays placed over on the other side for the fans, leaving only the A/C Master Relay on the left. This should simplify things immensely and give a much more reliable circuit, as well as a lot more room to get at the wiring if needed.
At present I have an issue with the control signal for the Master Relay so it looks like I'll have to go back into the console to sort that out (once again). But because I am getting really tired of this business of doing things over many times I am eliminating unnecessary connectors, functions and devices, using sealed connectors where I can, and doing whatever else I can to upgrade to more modern devices. Where I need wire I am using the cross-linked insulation like what comes in the AAW kits. I figure if I just upgrade the circuits that cause trouble as I go along I can put off rewiring the car long enough that I may never have to do it.
I will check into the '85-'88 Saab 9000 radiator temp switch. If it has a wired pigtail and isn't ungodly expensive that might make a good alternate to the manifold switch, is right beside my relay box, and I wouldn't have to find a place to mount a manifold switch so I might use it. OTOH, if it turns out that even with the fans working properly the radiator is inadequate (a definite possibility), I will be looking at aftermarket generic radiators with oil coolers and will most likely need the manifold mount switch anyway. Because I may have a good usable Ford sealed unit I may just use that as it is likely to be more reliable, even if I have to put a "T" on the intake manifold to accommodate it.
Post by: BlownMGB-V8 on March 04, 2012, 03:18:34 PM
Looks like the radiator switch slip into a grommet through the radiator tank. The Saab switches are threaded. I'm not real sure how well that will work but I guess it does. But it sounds like maybe I'd better stick with the manifold switch.
Post by: bsa_m21 on March 04, 2012, 04:12:19 PM
Dan,
So if its a 1980 carb USA, then this must be your wiring diagram:
This is a real dogs breakfast.  I would change it over to the 1981 wiring.  Much simpler:
Here is a doc that describs how: http://docs.google.com/open?id=0BxOL0HRH5pDedE1INHVwamJSeEtDY3p2SmZlOEVZUQ
Full 1980/81 workshop manual is at: http://docs.google.com/open?id=0BxOL0HRH5pDeUVZxVml2OEVUYy1PZnIzcTdLd1FBUQ
And the ROM Suppliment is at: http://docs.google.com/open?id=0BxOL0HRH5pDeR3pYZ2M3bzZRai16YnZtN1dvaXdEdw
Post by: BlownMGB-V8 on March 04, 2012, 07:26:54 PM
Yep, I think that's it. Thanks for the link but since I will be keeping the A/C function (spent good money to make it work and it does work quite well until the engine overheats), those instructions are a bit off point. I think I will go with the above plan. I see no reason to keep the delay circuit, I think it just adds complexity. I have the fan relays on the power side in conventional form, and will eliminate the interconnect. Run Only power (W/K) will take care of the rest and the fans will not run with the key off, which I prefer. All that remains is to determine the control side circuits for the two fan relays and whether to wire them on the ground or hot side. I prefer hot side controls but since the heater fan is a ground side control, to be consistent I should probably go that way with both of them.
So, use the existing heater fan and manual A/C switch to turn on the A/C system and also the condenser fans.
Use a manifold mounted temp switch to turn on the radiator fan.
Power the fan relays off the W/K wire.
The Master Relay will still be energized in Start but since it is powered by W/K it will do nothing until Run.
So no fans , clutch, or throttle jack anytime except Run. Just as God intended. (OK, maybe that was in poor taste.)
Post by: BlownMGB-V8 on March 05, 2012, 12:35:54 PM
I did find one of those grommet mounted Volvo switches in the Everco catalog:
#36533, '86- '94, 197 on, 188 off, tab connectors.
But I'm thinking about a thread-in dual switch like #36480, 197/221 on, 188/212 off with wire lead outs. I could actuate the radiator fan with the low side and the condenser fans with the high side for extra airflow when not using the A/C. If I can get it that is. Turns out to be a Saab part, around $50. Pricey, but no pigtail needed as I have junkyard Ford connectors I can use.
Post by: Dan B on March 05, 2012, 12:46:58 PM
Jim,
If you need to look at a manual, there are two in the trunk of my car.  One of them has a wiring diagram I printed off in it I think.
Post by: BlownMGB-V8 on March 05, 2012, 01:33:44 PM
Thanks Dan. I've got one too so no problem there. It's just the strange way they routed the electrons that makes it difficult. But I think I have it figured out now.
Advance crossed the Everco temp switch to an IMC 80237005615, for $23.31 tomorrow pickup. So good there. It is a threaded radiator mount though rather than pipe thread so it will need an adapter, but since I'll probably need a "T" to install it anyway I may be able to just modify one leg to match, depending on the thread size.
So, sort out the console switches and it should work fine, and hopefully be reliable. Then it's just a question of radiator capacity. I'm not real hopeful on that but we'll see.
Post by: BlownMGB-V8 on March 05, 2012, 02:27:00 PM
OK here's a twist, and this one nearly had me flummoxed. On the heater blower speed control switch the wires don't come anywhere close to matching the 1980 schematic or anything close, but looking back to '77 I see matching wires on the speed switch: green/pink, green yellow, green/slate, black (one wire, not two) but no connection for purple/green which is the control line to the master relay. Where is it? And I spy a purple/green wire up around the blower motor, right size and in about the right area, sort of. Where does it connect? Dunno. It's one of those stand-on-your-head impossible to get at things. Apparently connects to the Gn/Y wire, but why at the blower?? Guess I'll jumper the Gn/Y at the switch to the Bk/O at the manual switch as there seems to be a disconnect somewhere up around the blower. Throttle cutout and cold thermostat left with the old engine so no need for all that round-about wiring any more.
Post by: BlownMGB-V8 on March 05, 2012, 07:27:13 PM
Since the delay circuit works I decided to just leave it in. It may serve a useful purpose if the high pressure switch drops out, and if it becomes unreliable it will be easy enough to bypass later. I tapped into the master relay power (white/pink- switched:Run) to power the fan relay coils, and used the existing radiator thermostat wire (Slate/Red) to send the A/C run signal back across to the condenser relay. Looks like I should put one of the diodes in this wire as otherwise an overheat condition (221 degrees or more) will bypass the A/C master relay and light off the compressor. Not exactly what you want with a hot engine. I don't like the connectors on it but if I enclose it all in heat shrink maybe that'll keep the O2 out. Looks like the worst of it is past now so I hope to finish up soon.
Post by: bsa_m21 on March 05, 2012, 09:27:48 PM
Jim,
Don't use the 1976/77 wiring diagram.  Completely different wiring.
In your 1980 wiring diagram, look at symbols #14 & #15, the cold thermostat and the fan switch.  Although it doesn't label it (ah the Brits), there is an in-harness connector between them, with the purple/green splitting into three wires, green/pink, green yellow, green/slate, with resistors dropping the power to green yellow & green/slate.  At the switch, it should look like this:
On the left side of the heater matrix (sorry, no picture), the purple/green wire goes to the cold thermostat (#14) then back into the engine compartment for the throttle cut-out (#13), where it changes to black/orange, then back to the heater matrix to the manual cut out switch (#12) on the lower console, then becomes purple/brown and connects to the master relay (#40).
Clear as mud, eh?  Having fun yet?
M.
Post by: BlownMGB-V8 on March 06, 2012, 08:55:33 AM
Thanks Martin. Apparently the cold thermostat is open because of.... well the cold naturally enough. Who would have ever figured that one out? And here I was thinking maybe it was something on the (ex)engine. Well, I guess I won't be needing that one any more since I rewired the sucker. Seriously though, did they really think the car would get so cold that you need an automatic switch to turn off the compressor? In a convertible? When they already have a thermostatically controlled expansion valve?
I have to admit, they were thinking ahead on this heat/AC system though. Thermostatically controlled heat, thermostatically controlled cold, multiple safety overrides. A few more devices to turn the system off and it would have never run at all. If they had just stuck to the basics reliability would have gone up a lot. Waited for the modern electronic controls which also had teething issues. No way to win except by sticking to what worked reliably, and even that was not a reliable tactic as proven by other marques. I guess SOMEONE had to try going high tech. (Oh yeah, by all means let's do THAT with Lucas components!)
I tied into the Gn/Y wire to the blower resistor right behind the switch and went directly to the manual cutoff switch with a wire about 1 foot long. Short, sweet, and to the point. I THINK if it gets too cold I can roll down a window or something. Actually more importantly, if I want to run the AC in cold weather to defrost the windshield I don't want some danged old automatic cold thermostat telling me it's too cold to work (brrr...).
Some time back I had replaced the heater's leaky thermostatic valve with a manual one but that was one automatic feature it would have been nice to retain. Too late I discovered a Volvo replacement that was still available but I'm not pulling the matrix back out to install one. Manual heat control works just fine.
Once you begin to understand how this all works it really isn't so bad... except for the lousy connectors... and the bad components.... and the weird wiring... and the torturous locations.... and the upside down control schemes... and all the rest that I've left out... what's left is really quite,.. er,.. below average I'd say. Well, no, for it's day, maybe sub-par. But not much. I mean, about all that leaves is the wires themselves and they are the plain old (OLD!) vinyl coated wires of previous decades, prone to drying out, cracking, and corroding just like their ancestors. It's really quite remarkable how much smoke is still left in the old creatures.
Now, looking forwards, in general our electrical systems are sealed up quite nicely against the incursion of water and oxygen with their ruinous effects except for two things. Relays and fuses. Even with o-ring sealed covers the fuse and relay blocks are open at the bottom and are therefore vulnerable. Fitting some sort of a sealed lower cover would make them much more reliable in the long run. But the cross-linked insulation on the new wires is really remarkable, as are the sealed connectors. Most aftermarket switches and components are vulnerable too but some very good ones exist. Many OEM ones are exquisitely designed. Clearly the enemy has been identified and the battle rages in earnest.
Onward,
Post by: bsa_m21 on March 06, 2012, 09:58:36 PM
Hmmm....  High tech?  Lucas?  In the same paragraph?  Oh my...  :)
"... the lousy connectors... and the bad components.... and the weird wiring... and the torturous locations.... and the upside down control schemes... and all the rest ..."    Yup.  They sure are quaint. You either love'em or hate'em. That's the company good old George founded.
Amazing thing was that they also did aircraft electronics, and had an excellent reputation for, dare I say it, reliability.
I'm just glad that by some fluke my TR7v8, after 32yrs, still has some of that famous Lucas smoke left in the system. Better get the damn car out on the road before the rest leaks out....
M.
Post by: BlownMGB-V8 on March 07, 2012, 08:42:10 AM
No kidding. Naturally complications have arisen. The "cheap" (yeah, right) Saab switch turned out to be neither cheap nor available, plus would need an adapter so I'm taking another look. Thought the one we put on the Roadmaster looked promising... 3/8" pipe thread, nice sealed connector if I can find a pigtail for it, 3 pins... Carl found the P/N for me: TU178TG and Bill picked it up at the local AZ. So.... A search brings up... NOTHING! NADA. ZIP. Now that is a rare occurrence these days on the internet. Google, Dogpile, even the AZ website, nothing. Nothing at 4 seasons either or at Wells. Guess I'll stop by the store and see if they have the part there just for the sake of continuity, otherwise I might have to think that it was one of those inverse black hole functions. It certainly was not the switch Bill thought he was buying. IF they have it, and IF I can find a pigtail, and IF the switching points are acceptable (sounds like some stove top testing may be in my future) I may use it here. I'm guessing the application may be a car (GM V6 Camaro?) too new to be in the system. At least the price is right. 15 bucks. Can't beat that for a dual switch.... if it IS a switch.
Then since I have the console out I might as well finish hooking up the seat heat (since it's almost summer already). And since I'm doing that I might as well replace that bad panel in the driver's seat upholstery, and if I'm doing that I might as well see what it would take to put new door panels on it, and if I'm doing that, I might as well glue the carpet back down... It just sort of snowballs, you know? At least there seem to be no other major issues with the wiring.
Post by: BlownMGB-V8 on March 07, 2012, 07:42:46 PM
Grrrr.... ever feel like you're going in circles? OK, so I bought the TU178TG purely so I could test it, then bought a pigtail to fit it and felt lucky to find that, figuring that at the very least I would confirm whether or not the one we installed in the MG-Roadmaster could be used. Well it can't. Turns out the AZ counter guy was clueless and sold Bill a sensor when he asked for a switch. (he's also headstrong and doesn't listen too easily) It's a sensor. A double sensor in fact, one to drive the gauge and the other to drive the ECM, both at 2K-200 ohms. It's hanging with the electrical parts now and maybe some day it'll get used but I'm not counting on it. Basically $33 down the drain.
So back to the Everco IPB and ultimately back to the Saab switch. Looked like about $55 but ultimately I found a dual Beck Arnley switch on ebay to fit a '93 Saab 9000 for $32.50 with free shipping and ordered it. BA does not list their switch points so it's a bit of a gamble but since the application is the same as the more expensive brand which does, it should be close. Of course I could have just avoided all this and just ordered the $55 switch in the first place, but then the sender (I mean sensor) on the Roadmaster would still be an unknown.
It's a screw-in radiator mount with a sealing washer though, so once I have it I will still need to make an adapter but luckily I have the equipment and know how to pull that off. In the mean time the TR has my lift tied up so I'll just have to find other work to do. That is never a problem around here.
Post by: bsa_m21 on March 07, 2012, 10:52:40 PM
Jim,
I'm confused.  The stock switch p/n BHM7285, cross references to MGB's and XJS's and is readily available. MGB Radiator 1977-80. thermostatic fan p/n URP1126. It can be had for $18 at: http://www.mgbsource.com/products/MG/1964/MGB/SWITCH-RAD-FAN-76-79/3586972/URP1126.html
Why would you want to switch over to a '93 Saab 9000 for $32.50 and have to make an adaptor??
Stock:
Saab:
I've been told, but haven't tested myself, that a 2004 Audi A6 dual temp fan switch is a direct push in replacement. Tridon p/n TFS219
$15 at Rock Auto p/n VE709097
Hope this helps.
M.
Post by: BlownMGB-V8 on March 08, 2012, 08:11:36 AM
Good to know Martin. In this case I am anticipating a radiator upgrade and would prefer to be able to use a less expensive generic aluminum radiator. The TR-7 boys tell me the stock radiator can't be expected to handle the Buick V6 and that I'm lucky to have made it this far with it. Considering that Palestine is likely to be hot, and I'll be wanting to run at speed on that trip as well as run the A/C I see that as a formula for disaster in spite of the new electric radiator fan. I agree with them actually, as it would overheat if driven above about 65 mph last summer. Putting the Saab switch on the intake means I'll only have to deal with the transmission oil cooler as an extra feature of the radiator and those are fairly common. Through-the-tank thermostatic switches, not so much.
I suppose I could weld in a bung for the screw in switch but I'd rather not. Mounting the slip in style using spring clips just doesn't strike me as a good tactic. I could probably do it but I'd rather not.
Those references are excellent resources and thanks for posting them.
Post by: bsa_m21 on March 08, 2012, 07:07:00 PM
Hey Jim,
It might be cheaper to get your existing rad re-cored with a thicker core.  Have them weld on a 22mm threaded thermostatic switch bung and you are all done.
Aside for the threaded bung (which I didn't do), I had mine redone for a bit over a $100.
M.
Post by: BlownMGB-V8 on March 08, 2012, 09:36:45 PM
Good idea. I'll check with my local radiator shop after the switch comes in.
Post by: BlownMGB-V8 on March 09, 2012, 05:49:23 PM
I think the real problem is that the TR-7 is an alliterated anagram. Whatever that means. No doubt that is what's causing me all of this trouble in the first place.
Post by: BlownMGB-V8 on March 10, 2012, 02:57:36 PM
How about TR-7 seat diaphragms Martin? Do you have a good source for those by any chance?
Post by: bsa_m21 on March 10, 2012, 07:11:45 PM
"the real problem is that the TR-7 is an alliterated anagram"
Huh?
To quote wikipedia....
"alliteration refers to the repetition of a particular sound in the first syllables of a series of words or phrases"
"anagram is a type of word play, the result of rearranging the letter of a word or phrase to produce a new word or phrase."
So you are perhaps saying that with the TR7, BL was trying to be slightly different while repeating all of the mistakes of old.  Yes?  :)
For seat diaphrams, try these: http://trf.zeni.net/weeklong/33.php
M.
Post by: BlownMGB-V8 on March 11, 2012, 12:01:43 AM
I'll have to defer to Tim on that question, though I do think it makes a great theory. Love the dog shot btw.  I should be hearing from trf soon with delivery info. Figured I'd fix the seat while waiting on the temp switch, glue down some carpet, little things like that.
Post by: triumphtr2 on March 12, 2012, 09:31:08 PM
Hi Jim. So you didnt get it after all. Wired and weird use the same letters but in a different order. And since they both start with the same letter ,thats alliteration. As to all the crazy wiring run abouts and round abouts, only in England they say . Tim
Post by: BlownMGB-V8 on March 13, 2012, 02:43:10 AM
Should have known roundabouts would be in there somewhere. Well the switch came in today. Very nice piece, and a shame to cut the pins off it to fit the new ones really. Next, finding a bung I can turn into an adapter fitting.
Post by: BlownMGB-V8 on March 15, 2012, 06:04:49 PM
I decided to buy a tap instead of trying to find a fitting, found a package deal on ebay for 20 bucks including shipping for four large metric taps in sizes I didn't have so that was a bargain. While waiting I've had time to think about how I'm going to do this. I have a vent line from behind the thermostat over to the surge tank and it makes sense to me to put the temp switch in that line. Just need a chunk of aluminum that the switch will screw into and fit it with a couple of small hose barbs. Then find a handy spot and run the hoses. The flow from the vent line will be continuous at all times as it bypasses the top half of the radiator to the tank and then to the water pump inlet (dual pass radiator) so I won't have to be concerned with steam pockets and it bypasses the thermostat too so even if the thermostat should stick closed it ought to be operational. Only downside is a lump floating about on the intake manifold but I'm sure I'll be able to strap it down somewhere.
Post by: djw090 on March 16, 2012, 09:38:26 AM
Jim, will you be putting Megasquirt on this car?
Post by: BlownMGB-V8 on March 16, 2012, 12:03:37 PM
No David, I don't think we'll be keeping it that long. I bought it as a surprise birthday present for Edith and she doesn't appreciate surprises. So, although she claims to like the car, it will be leaving in favor of the vehicle of her choice. In the meantime I've been fixing it up a bit and using it for errands. Dan and I may bring it to Texas if we don't take his TR-4, (the A/C will be nice) but once my car is back on the road it'll go back in the barn until E wants to do something with it. I'd still like to replace the door panels but aside from that it's fine.
It's actually a pretty nice little car, but if I was going to EFI I think I'd look for a newer Buick V6 to put in it and get the advantages of more power and better economy, along with all the EFI bits already there. Maybe get the tranny (4L60E I think) as a package deal with a low mileage Gen-III 3800. That would make a sweet car.
Post by: BlownMGB-V8 on March 19, 2012, 07:40:58 PM
Here's the piece for fitting the switch:
The 5/16" smooth barb goes into the manifold in the hole tapped for the vent line behind the thermostat, then the push-on fitting goes in place, leaving a 5/16" hose to go to the surge tank. Flow will be directly onto the end of the switch for good response. The housing is made from cast aluminum and is very light in weight, it will be strapped to the fuel inlet to steady it against vibrations.
Now I just need to determine which wires switch at the upper and lower temps and I can finish the control wiring. Should be out driving it tomorrow.
Post by: BlownMGB-V8 on March 19, 2012, 08:09:40 PM
The black and blue connect at a temperature below boiling. It is marked 92* 87* / 105* 100* so I'm guessing it has to go to about 230F*  to switch the second side. Maybe boiling straight antifreeze...
Had no straight antifreeze so I had to use 50/50 mix. At first it wasn't enough but as the water boiled off and the temp climbed the white wire switched.
So now the question: Does SAAB comply with the standard automotive scheme of black = ground, or do they go with the European industrial convention where blue = ground? (Or was that brown? I never can remember.)
Really it doesn't matter that much as long as the low temp switch doesn't fail, but if it does I'd like the high temp one to be connected to the right lead.
Post by: BlownMGB-V8 on March 20, 2012, 08:08:50 PM
Seems to work, time will tell how well. The first photo shows the switch location, the second is the fan relay box. Since I found that the vacuum advance that had fallen off the carb and so had one vacuum cap there will be some tuning to do.
Post by: bsa_m21 on March 21, 2012, 08:48:02 AM
Jim,
For the three wire SAAB switch:
  - The blue wire is for low temperature operation
  - The white wire is the high temp operation
  - The black wire is the common.
Martin
Post by: BlownMGB-V8 on March 21, 2012, 05:58:39 PM
Thanks Martin, that's excellent! (Especially since that's the way I wired it and won't have to change anything :-)
I got it out running errands today with the A/C on and only got slightly above half scale one time so that is promising. Looks like I may need to come up with a more permanent mount for the fan, it may just do the trick. More testing should tell, especially high speed with the A/C. Still have doubts about that, but I do have a much healthier fan if I need it (and if I can fit it in there).
I'm now trying to track down a misfire, which is irregular and apparently in the HEI (Buick V6). The timing light shows some spark scatter and irregular firing so I replaced the coil which seemed to help a little. And it seems all the lights have decided to go on strike so that will keep me busy for a bit. Typical British misconnects there I suspect.
Post by: bsa_m21 on March 21, 2012, 07:41:47 PM
You are welcome Jim.
I used two fans from a Disco wreck.  Made a bracket to mount them to, in front of the rad (no AC on this buggy.  Work great.
Re: And it seems all the lights have decided to go on strike so that will keep me busy for a bit.
While you are at it, check and lubricate both the main light switch and the hazard switch on the front console.  The wonderful Brits wired all kinds of things through the hazard switch and often it is a key cause of failure for turn signals, door lights, etc.  And, be VERY careful playing with the column mounted combo turn signals, horn, hi low switch.  There are plastic bits in there that get REALLY brittle and break if even slightly abused.  Another wonderful piece of British engineering.  You can buy replacements on ebay and most of the regular suppliers, for anything from $40 - $200 depending on the seller. Don't bother buying a used one.  They are as bad as what you already have.  :)
M.
Post by: BlownMGB-V8 on March 26, 2012, 03:08:22 PM
All the lights but the two front side markers simply came back. Go figure. Well, except the high beams. So I've been trying to tune up the engine with qualified success, and here's something that I suspect fits the weird wiring category. When I remove the vacuum hose from the distributor the engine runs fairly smooth and I get a steady strobe flash from the timing light. When I plug it back in, the timing light goes out completely and the idle gets very rough like it's hitting on 3 or 4 cylinders. Honest Injun (PIC) that's exactly what it does! What gives? Another infiltration of the dastardly, nefarious, and satanic Lucas influence? (at least it doesn't squirt wiper fluid out of the plug boots)
OK, well there IS an electrical component connected to the vacuum can. The pickup coil, And that is the only remaining component in the HEI that hasn't been changed. Guess I'll head over to Advance.
Post by: DiDueColpi on March 26, 2012, 04:36:50 PM
Sounds like the reluctor is out of phase with the cap and rotor. So it trys to fire between cyls.
The same thing happens if the green and white wires are reversed.
Post by: BlownMGB-V8 on March 26, 2012, 05:25:56 PM
Fred, yer killin me. Green? white? GAH!
MAYBE there's a green wire and a white wire, the ones on there just look... well, OLD. Have to see what I get with the new one tomorrow evening. I even found a test, but the heck with that! I'm not putting the old one back in anyway. Don't think I'll need to worry, the tabs are different sizes.
Obviously it was in the car too long and got infused with Lucas smoke which was incompatible with the GM parts. I understand the popularity of the HEI now though, the only connections it has to the Lucas system are the power (Ign) wire and the tach lead so it's pretty well isolated and self contained. No Lucas wires to the coil, no Lucas coil, and it even uses Chinese plug wires which are reasonably compatible. Plus, John does a pretty good job of separating them by providing an intermediate wiring harness. The problem is, since this was an old conversion the seals in the harness went bad and the smoke leaked through, causing Lucas-like symptoms in the GM unit, Every piece in there was corrupted, even the GM distributor harness. And it was so obvious what was going on once I realized the intermittent nature of the failure, if I'd only realized it sooner. I am just SO thankful it didn't get to the stage of having the windshield wiper fluid leaking out of the plug wires. I've heard that is almost impossible to cure.
Post by: BlownMGB-V8 on March 27, 2012, 03:38:56 PM
Fred, I over reacted to the green/white advice a bit I'm afraid. It was good advice and obviously well intentioned. When I was able to check, there was indeed a green and a white wire. More to the point, even though I am going to replace the coil just because it is so old and decrepit, when I did the resistance check I could not get it to fail. Rock solid no matter how I move the wires.
So... in all seriousness and putting aside the Lucas tomfoolery, unless the contacts themselves were the source of the intermittent operation, (and I slipped those out, pinched them in, and applied anti-corrosion grease) how in the world does the vacuum advance cause a misfire? From the plugs it looked to be pretty consistent on the driver's side of the engine, especially #1 which was not firing at all at idle with the vacuum connected. Resistance was 1000 ohms which is right in the middle of the range the test called for.
Well, this evening I'll get the replacement and suspect I'll have to go another round. Module is next again I suppose. Tomorrow they get a couple new one in that we can test on their machine. Could be a problem there.
Post by: DiDueColpi on March 28, 2012, 04:29:25 PM
Have a look at the phasing of the cap/rotor and pickup.
The reluctor can slip or possibly the advance can is the wrong one.
This causes the ign. to fire when the rotor is in between posts on the cap.
When the vacuum is applied it makes the out of phase condition worse and sends the spark to the next cyl in line instead.
That could explain your timing mark problem as well.
Stick the dist cap on and mark the housing at any of the plug wire posts. Remove the cap and line the rotor up with that mark. The points on the pickup should be lined up or very close to it.
One last thought. Possibly you have a mismatched distributor or components, even fire mixed with odd fire?
At any rate Lucas just has to be involved here somehow.
Post by: BlownMGB-V8 on March 28, 2012, 04:46:12 PM
Thanks, I'll look at that as soon as I can. Parts went B/O so I cancelled and ordered from Rock-Auto at 1/3 the price. Figured if I have to wait I might as well take the discount. So, not too sure how much I can do while waiting. The rotor has 3 points and I think the stator has 6 so I'll see how they line up. Got it all disassembled on the bench right now. Should be the stock distributor, all the parts match so far to an '82 Buick Regal 231 V6. But I haven't looked to see if the points on the stator are equally spaced. Anyway, the thing about the cap, that makes as much sense as anything. It's got those aluminum tabs in the top and there is more room for variations in those, being bent slightly for instance, than anywhere else I can think of. Still, it was such a dramatic change with the vacuum. Winding it up to where the mechanical would have advanced it still ran smooth without vacuum. So, who knows?
Post by: DiDueColpi on March 28, 2012, 05:39:39 PM
The mechanical advance doesn't affect the phasing of the distributor.
The three point star wheel is an odd fire part I think. Mix that with an even fire cap and there you are.
Post by: BlownMGB-V8 on March 28, 2012, 05:43:12 PM
I'll measure the distance between the points. If it's odd fire either the points on the stator, the rotor, or both would have to be offset I would think.
Post by: BlownMGB-V8 on March 28, 2012, 08:12:36 PM
Don't know how I missed this, but the cap does not have the plug towers evenly spaced. And the points on the stator are also uneven, three gaps at about .850" and three at about .515" Fred, I guess you called it. Unless there was something else odd that they did with this, someone put an odd fire distributor in this engine. I guess that would make it run rough.
You know, that still doesn't explain why there was no spark with the vacuum hooked up, but I think I might know what would. The gaps on the stator are wide/narrow/wide/narrow/wide/narrow. The plug tower are wide/wide/narrow/wide/wide/narrow.  Looks like a mismatch to me. Then, there is the 4.3 Chevy motor which apparently has 3 versions, an even fire, an odd fire, and a semi-odd fire somewhere in between. Maybe this is a Chevy distributor cap. Or maybe they got fancy with the aluminum tabs on the inside to make one cap fit all. I don't know.
What I do know is that another distributor from the junkyard is going to cost me about fifty bucks, so I'm at the decision point in the other thread. I think I'll put the trigger coil in when it comes and see how it runs. It's an escalating solution. The entire engine from the junkyard if I can find a 4.1 in a Caddy (fairly likely) would be $180, or an extra $130 for a 4bbl intake and carb along with the engine it's attached to, potentially a significantly better one than this that will bolt right in and be complete from stem to stern. Or for another $150 I can get a later lower mileage, more efficient and probably more powerful engine (3800) with it's matching transmission still attached, which will also bolt right in. And if I knew we were keeping the car that is what I would do. Probably the best thing is to take a little vacation, spend some time discussing it with Edith and take enough time to completely sort things out. But I gotta tell you guys, this odd-fire/even-fire business has sort of soured me on the whole idea. I think I've made a legitimate effort to be a fan of the V6 and in the final analysis have been forced to accept that it is a creature of endless and unnecessary compromise. And before you 60 degree guys complain, yes I realize that's a different animal. I also realize that just because this one in particular has led me through a mind numbing array of unlikely symptoms and still more unlikely causes it doesn't mean a well sorted engine won't give excellent service.  But I hark back to the days of the straight six, some of which were in the 300 cubic inch range (5L). Despite some impressive national record holder 6 cylinder cars the six was NEVER considered to really be competitive with the V8 in day to day usage. Puts me in mind of Dad's 300 straight six pickup and his 302 V8 pickup. Near identical trucks, but not even close. In my opinion, nothing has changed. I'm damned glad I never got serious about the V6 as a candidate when I first did the conversion on my car. Why compromise purely for the sake of compromise, when a Buick 300 would do the job so much better in every conceivable way?
But being here, now, I'll probably compromise and fix it as cheaply as I can. First things first though, I need to verify that it is indeed an even fire engine, and that it has an even fire crank. Clearly more fun-n-games ahead.
Post by: DiDueColpi on March 28, 2012, 08:37:26 PM
Have a look at the balancer bolt. 5/8 is odd fire 3/4 is even. 82 and newer engines had metric threads and a knock sensor boss at the rear of the block.
Post by: BlownMGB-V8 on March 29, 2012, 11:44:42 AM
Fred, do you think the 3 lobed rotor (equally spaced lobes) would work ok with the even fire stator? Nothing unique about the coil and 3 lobes should interact the same with 6 points whether they are odd spaced or evenly spaced it seems to me.
The damper bolt has a 1-1/8" head. Does that tell us anything? The intake bolts are 3/8" NC. It is supposed to be an '82 but maybe the the first ones were left overs. I haven't found a serial number yet, the closest thing is a very light stamping "629" as close as I can make it, on the right front cylinder bank front surface. Can't see well enough to tell if there is a KS boss on the back.
The distributor cap is as I suspected. The aluminum contacts inside are offset so that the gaps between them are within 1/8" of each other despite the offset in the towers. So it appears to be the right cap.
If this is an even fire engine, the crank throws on one bank are displaced from where they would have been on the other engine. This is consistent with the results. The #1,3 and 5 plugs showed a dark color after rough idling while the #2,4 and 6 plugs were white.
Maybe the new pickup will fix it.
Post by: BlownMGB-V8 on March 30, 2012, 04:12:39 PM
It did. The lobes and points have just a smidgen of interference, just barely touch, so as an experiment I went ahead and put it together that way. Once I remembered to install the rotor button it started and ran fine. So the odd fire tri-lobed rotor will work with the even fire trigger assembly. A good thing to know, wiring wise. And since this pretty much concludes the wiring portion of our program I'll also conclude that the remainder of comments belong on the "Considering a V6 upgrade - TR-7" thread and go there.
