General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: roverman on January 30, 2012, 07:09:55 PM
Title: Whats the flow ?
Post by: roverman on January 30, 2012, 07:09:55 PM
Stop wondering/guessing and find out ! I must suggest this book,"Engine Airflow" #HP1537 by HP Books. NO AFFILIATION. Concise, in depth and comprehensible, a good combination.  For instance, this book and many skilled engine builders suggest, measuring cylinder head  airflows including inlet maifolds, carbs or throttle bodies as a good first building step to designining a successfull build. Did you know that 200 cfm @ 28" H20 of inlet airflow, on gasolene, 8 cylinders should make in excess of 400hp., if other spec's are optimized ?  Onward, roverman.
