I am on the verge of ordering a set of TA heads for my 300 and am currently trying to come up wioth a plan for the intake. just wondering what the rover 4.6 deck height is. my 300 has a deck height of 9.543
All the Rover engines except the Australian 4.4L share the same deck height as the 215 Buick. Dan Jones has a page with deck height and other useful specifications at:
http://www.leylandp76.com/technical/tech-headflow.html
Here is also a link to a page with most of the available intakes:
http://www.mez.co.uk/ms12.html
Hope that helps,
Rob, The quick answer is 8.960" std., or .06" shorter than sbc. This makes a lot of high value sbc rods/pistons viable. I need the port dimensions of the John Eales , Webber DCOE manifolds,(swan neck and cross ram). These could be modded to use TPI. Tell us about your planned build. I ordered my TA heads back in September, "should" receive mid Jan. Good Luck, roverman.
