General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: roverman on November 29, 2011, 06:07:59 PM
Title: theoretical science ?
Post by: roverman on November 29, 2011, 06:07:59 PM
How about using an adequate sized, oil laden fluid coupling for engine dyno use,(industrial applications) ? Seem to be much cheaper than water absorbtion units. These use oil inlet/ outlet, for amount of slippage. What if ? Thanks, roverman.
Title: Re: theoretical science ? tire pressure ?
Post by: roverman on December 08, 2011, 04:04:27 PM
You checked your tire pressure at 9k feet altitude. You check again at sea level,(same gage/same temperature). Did tire pressure increase or decrease ?  Food for thought, roverman.
Post by: Chromov on December 09, 2011, 02:06:23 AM
Increase, accordingly increased atmospheric pressure.
