General Category => Classified Ads: Swap Parts Here! => Topic started by: J Man on November 13, 2011, 09:07:24 PM
Title: WANTED: 4.6L Rover block
Post by: J Man on November 13, 2011, 09:07:24 PM
I am looking for a 4.6L block (wanting to take it out to a 5.0L) or rebuildable core. I would need something near OH or you will have to be willing to ship. I have a Olds 215 motor I can offer in trade if you are in need of one of those. I would prefer a PM if you can help as I should get notification of message (I onlt get on here every couple of weeks). Thanks for any help.
Title: Re: WANTED: 4.6L Rover block
Post by: WedgeWorks1 on November 15, 2011, 08:58:35 AM
You can also use the 4.0 block since they are identical. The internals determine the displacement from 4.0 to 4.6.
Post by: J Man on November 16, 2011, 10:39:42 AM
I wasn't sure if they were the same or not, Thanks for the heads up/
Post by: J Man on July 13, 2013, 06:43:38 PM
Still looking
Post by: WedgeWorks1 on July 13, 2013, 10:02:24 PM
The issue is finding one with good liners.
Post by: roverman on July 15, 2013, 02:48:39 PM
Because of long-standing  issues of "core shift", with the 94mm bore blocks, it's always best to inspect a bare a bare block for cracks in the liners, and/or liners being dropped down from the deck. The safest procedure is to have a block pressure tested, before buying.  New  oem rplacement blocks are available, but not cheap.  Good Luck, roverman.
