General Category => Healey Sports Cars => Topic started by: mtnrek@yahoo.com on November 09, 2011, 09:25:27 AM
Title: Knock off hub replacement?
Post by: mtnrek@yahoo.com on November 09, 2011, 09:25:27 AM
I want to go to a 4 or 5 lug, preferrably a 5 lug, replacement for the knock off spindles....
any suggestions where to look?
thnx
Title: Re: Knock off hub replacement?
Post by: mgb260 on November 09, 2011, 01:16:58 PM
Machine the splined portion off. Drill hub to 5X4.75 lug pattern. Or if the bolt pattern bolting the wire wheel hubs is that already use a 1" spacer like picture below. S-10 rear has same pattern. Rear on 83-92 S-10 2WD is only 54" wide. Might not even have to be narrowed.
Post by: mtnrek@yahoo.com on December 13, 2012, 05:24:15 PM
where do i get a spacer like this?
Post by: HealeyRick on December 13, 2012, 06:28:46 PM
Here's another approach:  http://modifiedhealeys.org/Technical/Wire-2-SolidWheelAdapters/Wire-2-SolidWheelAdapters.htm
Post by: mtnrek@yahoo.com on December 14, 2012, 08:11:17 AM
thanks for the heads up, i found the spacers at multiple locations, i just need to take some measurements on the car. then i can put it together. fo rthe meantime i'll use the wire wheels i have. they're just a lil rusty and too expensive to replace (for right now anyway). i'm planning to put some mustang svt wheels on it.... or something similar.
