General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: tr8todd on March 20, 2011, 08:27:11 PM
Title: name that timing cover
Post by: tr8todd on March 20, 2011, 08:27:11 PM
I was digging around the basement looking for an oil pump cover and found five different style timing covers.  See if you can identify all five.
Title: Re: name that timing cover
Post by: tr8todd on March 20, 2011, 08:28:26 PM
and one more
Post by: MG four six eight on March 21, 2011, 12:06:02 AM
Top one looks like a Buick 215 cover with a Melling high volume oil pump kit and a swivel oil filter adapter base.
Bottom one, maybe  some type of late version of a Rover cover. Note the cam sensor hole.
Second one down Olds 215??
Not sure about the other two!
Post by: tr8todd on March 21, 2011, 08:43:28 AM
You got the first one and the last one right.  The last one is the famous intermediate Rover cover from a 97 4.0.  It still has the distributor boss and hole, but they are not drilled out.  I believe the top one has the oil pump and swivel from a 4.1 Cadillac engine that was used 80 to 82 ish.  I only say that because it says METRIC on it and it looks how I remember them being, but you may be right about it being from Melling.  It does have the high volume pump and spacer.  Second one down is not an Olds 215 cover.  A hint for that one is to look at where the cast in timing mark is located.
Post by: crashbash on March 22, 2011, 12:11:28 PM
Number two is 300 Buick!!!!!!!!!!
Post by: tr8todd on March 22, 2011, 01:45:03 PM
Correct.  Any guesses on three and four?  Hint GM crank seals press on the inside of the cover.  Rovers on the outside.  Found three of the 300 covers.  Anybody need one?
Post by: Moderator on March 22, 2011, 08:29:37 PM
I'm pretty sure number 4 is from a Buick V6 (but it's not the Grand National version, which used an external oil pump).
Post by: tr8todd on March 22, 2011, 08:58:13 PM
Correct.  Pretty sure it came off of the 4.1 Caddy version, but it's been so long, it could be from any old V6.  Surprised nobody has figured out the easiest one yet.  My screen name should have given that one away.  It has the part number stamped right in the middle.
Post by: mgb260 on March 23, 2011, 12:05:03 AM
Duh,TR8?
Post by: tr8todd on March 23, 2011, 08:56:13 AM
Also known as the SD1 cover used on the TR8.  It has become a highly coveted piece in recent years.  TR8 owners are reluctant to switch to a different cover as it means making up some custom brackets.  Lately TR8 owners have all become a bolt on performance catalog type of group.  Boring!!!!  Isn't the fun in the fabrication.
Title: Re: name that timing cover/ Stage II Buick V6 ?
Post by: roverman on March 23, 2011, 02:21:27 PM
Am I gonna halft' to post a pic of a "real" timing cover ? jus' sayin.
Post by: tr8todd on March 23, 2011, 06:41:37 PM
Let's see it.
