I got the 86-88(87) 10.7" vented Toyota Cressida rotors! I don't know why no one has tried this yet. If you draw an X through the rotor mounting holes and mill 2MM inside they bolt up to stock hubs. They are a little further out than stock but that is good as it makes room for caliper adapters for the small 86-88 4 cylinder 4X4 Toyota S12-8 calipers or 86-91 Mazda RX7 Turbo II aluminum calipers. I already have a set of the larger S12W 4X4 V6 86-92 calipers,same mounting as smaller S12-8. Tommorow I am ordering the RX7 calipers. Should have prototype caliper brackets soon. Might even fit under Rostyles.
Here is a photo with the larger S12W V6 Toyota caliper. The shiny stud is 90's Camaro/Firebird/Corvette(12mm), about 1/4" longer. So with a 1/4" spacer the caliper does'nt stick up beyond the wheel mating surface if you ground the fins down. The smaller Toyota and Mazda calipers probably don't need a wheel spacer. I just ordered the 88-91 Mazda Turbo II aluminum 4 piston calipers for $35 each at a junkyard through car-part.com.
There is a straight bolt on conversion for Toyota brakes on a TR4-6 on the VTR website, if you want to compare.
Dan, Here is a picture of the U.S. spec 86-88 Toyota Cressida 10.7" vented rotor with large 86-92 Toyota V6 4X4 S12W caliper on a TVR. And pictures of the newer (92-95)RX7caliper with Mazda name polished off and painted Alfa Romeo. On the TR4-6 and TVR the center hole in the rotor has to be opened up slightly or hub diameter turned down. The caliper bolts on like stock, some have had to use washers to shim to center. As far as I know the MGB has never been adapted. The mounting holes have to be slotted inside 2MM. The center hole is a little larger than stock MGB. A bracket has to be made for the caliper (3.25" spacing on MGB,3.5" on Toyota). The 86-91 Mazda RX7 Turbo II aluminum caliper or 92-95 RX7 aluminum caliper requires a simple bracket to bridge the 3.25" MGB mount out to 6 1/8" wide Mazda caliper mount. Even the Triumph and TVR guys should be interested in the Mazda calipers. You can use the 11.7" Mini Cooper S rotor for big brakes (16-17" wheels). Would require 1/2" wider brackets.
Brackets like these would be necessary. First one for Toyota calipers,next one for Mazda.
These pics are on a TR7 and a Volvo but, you get the idea.
86-91 Turbo II calipers(GSL also) aluminum 4 piston that I ordered from wrecking yard look like this. Internally and mounting are the same as newer ones (same rebuild kit). Specify the newer ones for performance pads. The older calipers are more common and cheaper. Remember, you can sand off the Mazda name but leave the ridge on the newer one and the square bump on the older one,there is a passage underneath.
Got my RX7 calipers today. About the same size as Toyota but 5 lb instead of 9 lb. Smaller Toyota somewhere in between,probably 7 lb. First pic is of pads, left 2 red ones are Large Toyota,2 on right Mazda. The smaller Toyota pads look similar to the Mazda's.
Mazda 86-91 Turbo II calipers with name ground off.
Do you have the measurements from the centerline of where the caliper would sit to the closest mounting surface where the bolt goes through (where it sits against the bracket)? I was thinking about these for the front of my alpine nut can't find any info on the measurements. What size master are you going to use? Wasn't the Mazda disc .81" thick? Thanks
I'll try and get the measurements for you soon. 22mm thick rotor(.88),same as many Toyota,Nissan. 7/8 master, I personally like the aluminum 80 Ford Fairmont. I'm just doing prototype work for those who want to upgrade the stock MGB hub. What wheel bolt pattern is Alpine, I thought it was 4X4.25 like some late Fords and Volvos, should be lots of rotors available 10.5" to 11.5" to fit the caliper simply move the mounting bolt spacing on the center of adapter bracket as necessary.
Ive been following this thread to see if i can get any different ideas. Thanks for the info i looked at the Toyota calipers at my local parts house and they appear those would be easy for a caliper swap. How thick and what kind of material is good to make a bracket from? I think if I made a bracket then the Mazda would be good for a cheap front upgrade.
For me as a rule if you need to go 1/2" or more thick use 6061 aluminum. I like 1018 steel bar or flat plate 1/4"- 3/8" thick and use 2 pieces sometimes to offset. Use grade 8 bolts,nuts and washers and Loctite blue threadlock also. Remember to center the caliper to rotor. Sometimes the 4 piston calipers require a wheel spacer for some rims also.
Thanks. The sunbeam rotor bolts to the back of the hub, so caliper thickness isnt too much of an issue. When I get around to doing it I think ill use a rotor hat and ring type rotor, bolted how the original one is bolted on, and make a bracket for the caliper.
What's the bolt circle hub to rotor? You might be able to use the Cressida rotor by slotting the holes,use a grade 8 washer under bolt head. Those separate hats like Speedway and Wilwood have multiple 5 lug bolt patterns and would probably work if slotted but might have overlap going to 4 lug.
Im not sure, i never had the hub off the car to look around the back. This is what it looks like. I saw a pcture of an old racecar on ebay where they turned down the Sunbeam rotor, drilled it, and used that to mount a ring type rotor on. I dont know if thats a good setup or not.
If I had to guess, the bolt circle to bolt the rotor on is somewhere in the 3-4" range.
Robbie,TR6 is 4X100mm same as Cressida,MGB hub looks similar but is 4X96mm. You might luck out or if quite a bit different you could drill the right pattern between the existing rotor mounting holes. If you use the aftermarket rotor/hat you would have to use shims between the pads and pistons(.035 on each side) to make up the difference in thickness (.81 to .88). Here is the measurements from caliper center(piston) to mounting hole centers,Toyota 1 3/4",Mazda 2 1/2". The Toyota stock was a 10.5" rotor and the Mazda was an 11" rotor. Hope this helps you.
The sunbeam has 4x4.25 bolt pattern (4x108).
Robbie, The wheel lug bolt pattern is usually different than the rotor pattern but if that is the pattern,you can slot out 4mm on Cressida or drill new 4X108MM holes between existing holes ,or go on Rockauto.com and search for a Volvo or Ford 4X4.25 pattern 10-11" rotor with a short hat. Then you can bolt behind rotor like stock, similar to TR6 or MGB.
Another pic of 86-91 caliper:
Comparison between stock and small Toyota(S12-8)caliper:
Thanks, Jim!
You really should weigh them while you're at it, though. ;)
Carl,I don't have the small Toyota S12-8 caliper,but have heard it is close to stock. I did weigh the large Toyota at 9lbs and the RX7 at 5lbs. .I just weighed the stock one at 6lbs.So until I get one,7lbs sounds like a good guess. The pads are about twice as big ,plus wider clamping surface.Plus vented rotor, which is about 4 lbs heavier. I have an idea you might be interested in, I need to have someone try the prototype Cressida with Mazda RX7 calipers including brackets when I'm done. Probably work really good with your new tires.
Stock rotor and caliper=15lb. Cressida rotor and RX7 caliper=18lb. Vented rotor and 4 piston caliper with large pads still an upgrade with only 3lb weight penalty! Small Toyota caliper would add 2 more lbs but, would allow more variety of wheels to fit without spacers.
Looks like my reply disappeared.
Anyway, Sounds real interesting, Jim. When you get ready give me a shout.
Carl, It'll be a little while but,here's the plan: I send you the hubs I have with rotors attatched, new wheel bearings/seal rebuilt RX7 calipers (with Mazda name sanded off and painted aluminum Hi-heat). You try them and if you like them, buy at my cost for parts and if not you pay to ship them back. Your master and booster should work fine. I would recommend stainless braided lines and GT rear wheel cylinder. You will need adapter fitting from 10mm x1.0 Jap to either MGB bubble flare or AN3 depending on your flex line(NAPA). Your choice on pads, I usually get the autostore ceramic ones. My cost for rotors $35 each,calipers $35 each,caliper rebuild kits $40 for both,wheel bearings/seal $30,caliper brakets,bolts,hardware $20. $ 230 total. Hubs/studs and labor free. I would use your positive comments for advertising. What do you think? I will be selling brackets for RX7 and small/large Toyota for $40 pair with bolts,hardware,concentic ring,instructions.
I will likely be using my hubs as I just put new bearings in them last year & shimmed them right where I want 'em. Plus, I may be drilling them for a new PCD. My wheel search is not going much better than JB's.
Carl, That's O.K. I just thought you would be the perfect test driver for the brake kit. You know a lot of wheels are dual bolt pattern(4X100mm and 4X4.5"),some people don't like the 8 hole look though.
"I just thought you would be the perfect test driver for the brake kit."
Well, I just happen to agree. ;) Any chance all that would fit under my ARE 14X6 wheels? I like the whole concept. 'cept for gaining 3 lbs unsprung weight for the rotors. Aluminum hubs may fix that.
Should but,four piston calipers stick out a bit and sometimes use of wheel spacer 1/4" or so may be required.
Typically I think you will need about 2" from the rotor to the wheel flange.
I have considered alloy hubs and may have to go that way, depending on other factors. The material cost for 6061-T6 for both hubs is around $75+shipping, then there's several hours of machine work and a half dozen set-ups involved. I doubt I could complete the job in an 8 hour day, just to give an idea of what it takes. That'd make for some expensive hubs unless you could find some off another car that'd work.
I measured my parts and am exactly 2" and the caliper sticks up 1/4" and that litte bump about 3/16" more. Can't grind down as it is a fluid passage. 2 1/2" would be better. Looks about the same as the picture above. RX7 stock rotor to wheel is 2 1/2". I might have to use a 1/2" aluminum spacer between hub and rotor for this one and look for a similar rotor with a 1/2" taller hat. RX7 Turbo II stock had a 10.85" diameter rotor and used 14" wheels.
Would this be the smaller Toyota caliper?
Thats the one for the solid rotor, Carl. Notice it has one small and one large piston to even out pad wear. Even though both my larger ones have even pad wear with equal size pistons. Not nearly as bulky as the RX7 or Large Toyota (S-12 W). Check out the picture of the RX7 above. I am doing brackets for all three. Both Toyota' would be the same. I just wasn't planning on a spacer for the larger ones. It will work fine, though. The height of the Cressida rotor is 40MM and 52MM or aproximately 1/2" more would be ideal for the larger calipers. The S12 - 8 solid rotor caliper bolt right on the MGC like your picture and the TR6. There are 2 different S12-8 , one for solid rotor (76-84 Toyota 4X4 4 cylinder pickup) and vented rotor version like my kit(86-88 Toyota 4X4 4 cylinder pickup and Four Runner). Here's a picture of the vented rotor one on Cressida rotor on TR6:
I'm going to start looking around locally for some plate to make brackets out of. Should I be looking for 1018 steel plate 5/16-3/8?
You want to try your rotor and caliper on first to determine thickness,or use measurements. I would recommend 2 1/2" between wheel mounting face on hub and rotor. Your bracket might end up on either side of stock mount. Use a minimum of 1/4" steel and if over 1/2" use 6061 aluminum. Here is the best internet supplier of metal: http://www.onlinemetals.com/index.cfm
templaterx7.jpg This template is for a Volvo conversion but gives you an idea. The RX7 holes might end up lower or higher and not straight across. I slide the caliper up or down until the ear is close to the stock mount to determine thickness of bracket.Remember the caliper must be centered, I use equal shims in the caliper slot to center. Also grade 8 bolts and hardware, blue locktite on threads.
Here is a steel bracket used on a BMW:
picture of RX7 pad shims:
Hi. Great thread. I have a TVR 3000M over in Seattle and I just started looking at front brake upgrades. The small and large Toyotas fit but seem HEAVY so have been looking at Wilwood's. But, I like the idea of the RX7 aluminum calipers. I have a '87 RX7 turbo rally car which I've run both rally and on the track and can attest to the quality of the Mazda brakes. Any thoughts on fitment? I'd be going with the cressida rotors. Thanks!
BTW, I can do the FEA stress analysis on your design work. I just need a .dxf
Jim, I'm getting in late on this deal, what's the center to center dimension on the mounting lugs for the Small Toyota caliper for the solid rotors? Looking for an upgrade for my Midget, but need to cram everything inside a 13" wheel so smaller is better. Midget mounting is same as MGB I beleive at 3.25" center to center.
Jared, Picture of Volvo template gives dimensions for bolt spacing on RX7 calipers. You can use 11" Corrado rotors also if you open up the center hole. They have neat little cooling windows in hat. Might need 1/2" spacer between hub and rotor to allow somewhat thick RX7 caliper to clear wheel. Basically allow 2 1/2" from wheel mounting face on hub to rotor. Bill, I think the small Toyota 4 pot would be excellent on the Midget! The bolt spacing is 3 1/2". Clock the lower caliper mount above the lower mounting hole. You might have to grind the inside edge of the caliper housing and pads because of the smaller diameter rotor. Also you would need shims behind the pads because of the thinner rotor.
Robbie has mounted his RX7 calipers and Nissan pickup rotors on his Alpine. I'm sure he'll post information on this site.
Thanks Jim. Clocking the caliper isn't an option on the Midget, run into clearance issues with the lower control arm or the shock arm up top at full lock unless the caliper is basically dead center and on the short side as well. I have tried to fit the RX7 calipers and also some Volvo calipers without luck because of the clearance issue. Austin Princess caliipers are a bolt on but basically un obtainable here in the US. I've read that there are some early Land Rover calipers that also will fit but again hard to find here in the US but I'm looking into that now. Looks like I might have to go with the more expensive Wilwoods and have mounts machined for those.
Bill, Maybe you could offset drill the mounts and calipers to make up the 1/8" difference per side and use a larger diameter mounting bolt.
Or buy that Austin Princess on ebay and get the seller to just send you the calipers...
Heres a picture of the back view. I finally got to drive the car today after a few months of upgrades. I have 1 water leak t address and the turning on and off at the right temp of the electric fans, and ill be back on the road.
Robbie, Cool! How would you rate the brake upgrade compared to stock brakes.
Hi Jim,
I'm a little lost. What of all these cars share the same hub with the TR6? I know the MGB and Midget do not, what about the Alpine pictured above? Have the RX7 brakes already been fit to the TR6 hub by someone? Thanks.
All of the hubs are different but the principal is the same. A piece of aluminum or steel bar stock adapter from the stock 3 1/2"(3 1/4" MGB) mount to the 6 1/8" mount of the RX7. Thickness will vary. Look closely at the Volvo picture and Robbie's Sunbeam picture. The original (same as Toyota pattern) is in the middle of the adapter,RX7 are outer holes.
Well, I only drove the car about a mile because I have a slow drip from the Saab thermostat t I put in, but the brakes have less pedal travel and I can actually lock them up now, which I was never able to do before. I'm using a Nissan F10 master, 3/4 bore. I also need to figure out if the back is getting enough braking. Any suggestions on how to do that?
Drive it in the rain and brake hard to the point of just about locking up the front wheels in a tight turn with a safe runoff area. This can be done in a large vacant parking lot. If your rear brakes are doing anything this is where they will put you slightly sideways. Mucho sideways is too much, no sideways isn't enough. Play with it until you get the feel for it, then you can try it on dry pavement.
Robbie, You are probably well matched, as that combination was designed by Mazda to work together. I'm curious if your master for the rear brakes had a built in residual valve you removed.(drum brake on rear Datsun pickup) If not your rear brakes may drag. I use a 2lb residual valve front and rear and throw away the anti-rattle clips on the front calipers. Also on alot of these conversions make sure you have a little freeplay on the master pushrod. Either wiggle it a little where it connects to pedal or have 1/4" freeplay at pedal. Did you use ceramic pads and the shims behind the pads?
No shims behind the pads. On the front I used Wagner thermo quiet pads, whatever they are.
To check the brake bias between the front to rear, is done in a straight line.
Have a friend stand on the side while you brake hard and observed if the front lock up first or the rear.
The ideal is for the fronts to lock up first and then the rear.
If you have an equalizer valve on the MC then doing its job.
Teh danger is to lock up the rears first, this may cause the car to spin.
If the rear locks up first, you will know it. ;)
Sorry to resurrect this awesome thread but I have one question; What did you all end up deciding for the MGB front brakes? I ended up getting lost and rereading and reading until my wife's friend just woke me up at the computer and now I can't figure out what my notes mean.
I'm just trying to create my parts list from your "best practices" and learn from your innovation. I don't own a machine shop and have little confidence in most of the ones around here so bolt-on and light weight and simple are good for me.
NCtim
Almost a bolt on. You will need 1/2" aluminum spacer either between rotor and hub (use MGB rotor as template)or hub and wheel (longer studs for 98-2002 Camaro/Firebird/Corvette 12mm) to allow wheel clearance for the thicker 4 piston calipers. The 4 holes in the Cressida rotor have to be reamed slightly to match the MGB rotor pattern. Also could use the slightly larger diameter (11") 89-91 VW Corrado rotor. It has cooling holes in the hub. You would have to open up the center hole to match the MGB rotor. Rotor offset would determine the thickness of caliper adapter. VW Corrado rotor pictures:
Thanks Jim.
Cheers,
Tim
