General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: palmjeld on January 01, 2011, 11:05:24 AM
Title: TBI or Carb???
Post by: palmjeld on January 01, 2011, 11:05:24 AM
Happy New Year everyone.  One of my cars is a '64 Sunbeam V8 (Tiger clone). I am thinking of switching out my Edelbrock 600 cfm carb for a TBI system.  I'm presently running the carb over an Edelbrock F4B medium rise manifold. My engine is a 302 bored .030 over. I'm running a mild Ford Racing street/strip cam.  All this goes through a C4 automatic to the stock Tiger rear-end.  The car is very quick - at least by '64 standards.  I am looking to improve the fuel efficiency, though, as I most often use it as a highway cruiser.  Thoughts?
from sunny, cold, blustery South Dakota
Paul
Post by: palmjeld on January 01, 2011, 01:39:32 PM
 -- moved topic --
Title: Re: TBI or Carb???
Post by: MGB-FV8 on January 01, 2011, 08:41:38 PM
Paul, I'll chime in based on some personal experience.  TBI fuel injection, because of its constant mixture monitoring will give you better driveability and fuel economy; horsepower wise should be comparable if the throttle body is properly seized.  However, sequential multi-port fuel injection with long/tuned intake runners would be the better choice for economy and power.
There's lots more factors other than fuel induction that can enhance fuel economy, such as, gearing, tire seize, exhaust improvement, engine timing, choke setting, friction and drag etc., etc.,. What MPG are you getting now?
Jacques
Post by: Orange Alpine on January 01, 2011, 10:16:42 PM
Hi Paul
Here are my thoughts:
It seems Edelbrock provides carbs with either economy or performance jetting.  Do you know which you A) have, B) would prefer?
A change in rear end ratios is probably in order, do you know the ratio you now have?
Why TBI, why not multiport EFI?  Here is a multiport step by step "How To". http://www.therangerstation.com/tech_library/V8EFI.html
See you in September.
Post by: palmjeld on January 02, 2011, 08:46:40 AM
thanks for the replies regarding the pending switch to fuel injection.  I'd prefer to go multi-port but am not sure I have enough room under the bonnet for all the apparatus.  Things are really tight on the Sunbeam.  More research needed on that.
Rear end - 2.88     tough to get anything lower without going to AOD  tranny.  The final ratio on the C4 automatic is 1:1.
A tranny swap is a possibility.
Current mileage is around 17 when I behave myself on an interstate and stay around 65 mph.  I'd like to boost that a bit, especially considering the rising cost of gas.
Carb is jetted for economy.
look forward to seeing you Bill.       How's the Duratec project?
Paul
Post by: socorob on January 02, 2011, 03:37:50 PM
for hwy cruising overdrive is always a good idea.I went from a c4 with 3.55 rear end in my v6 alpine to a t5 with 4.11s and it turns over less RPMs at 70 now than it did before. I got the mustang V6 t5 so i could get the one with the larger overdrive gear. The 5th gear ratio is .68, so at 70 im turning about 2750ish. Much better drivability wth the t5 and fuel economy, plus sports cars should have a manual tranny anyway. Good luck with your V8, im sure thats a fun car.
Post by: palmjeld on January 02, 2011, 07:21:31 PM
thanks for the reply.  Yeah, it's a hot rod.  Lots of power, especially from 3500 on up.  I've had the car up to 120 on the interstate and it was still climbing.  If I was 20 I'd probably know what the real top end is!
Paul
Post by: Orange Alpine on January 02, 2011, 07:33:19 PM
The Duratec project is currently in pieces.  Know anything about a Ranger M5 R1 tranny?
Post by: MGB-FV8 on January 02, 2011, 10:55:39 PM
Paul, what is the weight of your car and also the rear tire seize?  IMHO, the car could see 20 MPG.
Jacques
Post by: socorob on January 03, 2011, 02:06:20 PM
Along the same lines, does anyone know of a factory tbi that can be bolted to a 4bbl manifold that can be megasquirted or something similar that flows 400 cfm or up?
Post by: MGB-FV8 on January 03, 2011, 10:37:28 PM
Try the early GM Chevy cars and P/U trucks 305 c.i. and 350 c.i. starting in 1986 up to the mid '90s.  Also, the Dodge trucks (V-8) with 318/360 c.i. from 1987 to 90 something had a throttle body with built in injectors. Some minor modification (adapter plate) to adapt it to a 4 barrel intake may be required.
Post by: palmjeld on January 04, 2011, 11:49:57 AM
The car weighs about 2250 lbs.  The tires on the car are 185/70/13's.  The 13 inch tires are standard for both Tigers and Alpines.  Many owners have modified their cars and run 14 inch tires.  Some have even gone to 15 inch.
The Chevy 350 throttle body is often used in the swap between carbs and TBI.  There are a number of different electronic control systems that can be used, including the original GM.  Megasquirt gets good reviews.
If $$$$ was no issue I'd install an AOD tranny, upgrade to 14 inch wheels and install a fuel injection system. At this point I think the least expensive part of this will be the switch to the TBI injection.
later
Paul
Post by: joe_padavano on January 04, 2011, 02:01:56 PM
"Along the same lines, does anyone know of a factory tbi that can be bolted to a 4bbl manifold that can be megasquirted or something similar that flows 400 cfm or up?"
Um, how about a factory Ford TBI as used on the mid-1980s 302s?
Post by: MGB-FV8 on January 04, 2011, 06:30:34 PM
Thanks Joe, I forgot about mentioning the Ford TBI.  Paul, if you could find a 1985 LTD or full size Ford/Mercury car with a 302 that would be another choice although I can't remember if the EGR valve (with position sensor) was part of the TBI or bolted to the plate underneat it?
Post by: mgb260 on January 04, 2011, 11:20:05 PM
The thread on Rover with 2  downdraft 2 bbl carbs on this page has a picture of mid 80's Ford TBI. Holley 2 barrel bolt pattern.
Post by: Orange Alpine on January 05, 2011, 08:33:07 AM
Paul, why go to 14" wheels?   I felt the same way, but decided to go whole hog and am going 15".   I think that in a few years the 14" tire market will be as dead as the 13" is now.
Be aware that 6" wide Saab 9000 wheels are a perfect fit for the Alpine.  Correct bolt pattern and off set.  Most styles are 15", a few are 16".  Add some P195 tires and you would be in business.   Get genuine Saab wheels, I think the aftermarket wheels are "close", but we know that "close" is not always good enough on an Alpine, right?
If interested, check out the listings on Saabnet and car-parts.com.  The used wheels from these sources seem to be very reasonably priced.
Post by: socorob on January 05, 2011, 11:20:12 AM
ive read that the gm tbi is around 450-500 cfi, im trying to find the info on the ford. There is a good write up on the gm here.
http://www.diyautotune.com/tech_articles/megasquirt-carb-to-efi-part1-nova.htm
I think i may have hood clearance issues with that, but ill go to the local upullit yard to see if i can get some accurate measurements. Summit sells a plate to mount the gm tbi to a 4 bbl intake.
I have 15 inch vtos, they are 4.4 backspace, look nice. If i have to do it again, id go with 4 inch backspace for the rear, and a little more on the front, to get the wheels more inline. Heres what it looks like. I would probably go to 16 inch if i had it to do over, 1 inch wouldnt make it look that much different, and i think in the future sport tires will be better supported.
http://www.youtube.com/user/socorob?ob=0
Post by: palmjeld on January 05, 2011, 11:06:56 PM
Nice youtube Alpine!  The wheels look good on the car.  How much trimming did you have to do, if any, to get lock to lock turning with no rubbing?
The guys at diyautotune are very helpful.  Matt was quick to respond to my questions and helpful.  When it's time for purchase that's where I will go.
Post by: socorob on January 06, 2011, 10:11:10 AM
I didnt do any trimming, but i think the PO rolled the front valance already. These tires are less than 1/4" taller than the 13 inch tires that i replaced, so not much difference there. If i can find a suitable tbi that will fit under my hood, ill go with diyautotune also, theyve answered every question ive had and have been very helpful. Im having trouble find how much the 302 tbi cfm rating is, and the height of it. I have limited space, 5-3/4 inches from where the carb sits on the manifold to the top of my aircleaner which i think almost touches the hood, so i may not be able to find anything to work and have to stick with a toilet on top of my engine.
Post by: Bill Young on January 06, 2011, 02:04:06 PM
Paul, I think you should be getting a bit better with some type of FI either TBI or MPFI. I'm running a much smaller engine of course but my 2.8 with MPFI, a T5 with a final overdrive ratio of .76, a 3.43 rear gear, and 205 60 13s I get around 25mpg on the highway. The effective gear ratio in 5th is 2.60 so your 2.88s should be close. I'd think you would probably get around a 3 to 4 mpg increase with the injection, but an overdrive trans would make far more difference. Increasing the wheel diameter probably won't buy you much as you are effectively limited to overall diameter by the wheel wells anyway.
Post by: rficalora on January 08, 2011, 10:02:28 AM
RE: which i think almost touches the hood
A quick way to find out how much clearance you have is to get some kids playdo or something similar.  Make a ball a little bigger than you think the space is, put it on top of your air cleaner & close the hood.  The hood will flatten the playdo & you can then measure how thick it is to know for sure how much space you have.  Remember to look at the crown of the hood & where any cross braces are to decide where to put the the ball so you'll catch the area with the least clearance.
Post by: socorob on January 11, 2011, 09:39:00 AM
Ive been looking around a lot, and seems like gm used the same tbi with different injectors for the small blocks and V6s. For a 2.8, with some headwork and a larger cam, should I use a tbi with 4.3 injectors or 350 injectors, since that was only a little over 200 hp in that era? If i get the 350 version, could i just use megasquirt and have it deliver a little less fuel if its too much?
Post by: palmjeld on January 11, 2011, 12:37:14 PM
Hi Rob
Like you, I've tried to do some research/study in this area.  Based on what I know about Megasquirt and the GM TBI you could go with the stock 350 injectors and let the computer adjust the fuel flow.  Having said that I found some info showing there are injectors that are a better match for your 2.8. I found the following on another web site:
These injectors are rated at the pressure used by the factory, about 13 PSI Application Throttle bore size Injector color code Flow rate Part #
2.8l v6 1-3/8" Black/White ??? GM 5235430
4.3L 1-13/16" Yellow/Blue ??? GM 5235203
5.0L 1-13/16" Green/White 40 lb/hr GM 5235279
5.7L pickup 1-13/16" Orange/Black 55 lb/hr GM 5235206
5.7L Cop Car
1-13/16" Yellow/Brown 65 lb/hr 17084327-ACR
Late big block pickup 2" Blue/Black 80 lb/hr GM 1708430 big block pickup 2" Dark Red/Dark Blue 90 lb/hr GM 5235231
later,
Paul
Post by: socorob on January 11, 2011, 11:37:24 PM
A few places ive read said not  to match the injectors to engine displacement, but to horsepower rating. Get the injectors that are equal to or a little above what your hp is. Ive read so much, its hard to know whats really right or wrong. In a few weeks ill try to get over to the u pull it yard and get some good measurements. Im trying to keep the cost low as possible, so ill get as mch as i can off a donor vehicle. But first, i just got my cam in, and lightened lifters are on the way, had my spare heads magnafluxed, and getting ready to send them off for bigger valves and port/polish/mill. Hopefully at least this part will be complete by summer, then next will be efi. Head work is very expensie these days.
Post by: socorob on January 14, 2011, 04:26:08 PM
Yesterday I ended up passing a u pull it yard on the interstate and pulled in.. these gm tbi's were missing off most cars. The few V8 cars that had the tbi's on them still were all missing the injectors. Maybe this swap is very common? I finally found one on a 4.3 astro van that just got there a week before after looking in about 40 different cars. In a couple months when i get around to doing this, ill see if these injectors will work, if not ill swap them for 305 injectors. The collar that goes between the tbi body and intake is very tall, but if you find a blazer 1990ish, it had a slightly different looking fi system, i think it said mpi on it or something like that, but it had the same collar as the tbi, but was only about half as tall. The tbi with that collar is about 3-7/16 inches tall to the top of the collar. I also read a lot of people use an econoline van frame mounted fuel pump with the gm tbi. There were only 7 or 8 vans there, and only 1 had the fuel pump in it, all others were taken already. I was also having trouble finding the IAT sensors in the air cleaners, those were all taken too.
Post by: rampant racing on March 20, 2011, 02:48:38 AM
my friend mark has an 88 ford t bird.302 injected,3.73 gears and an overdrive.he gets 28MPG! he is a fuel efficiency nut(read that cheap) and knows the mpg of all his vehicles .he has an aod trans in the car.if a motor is lugging at low rpm it can take more fuel to run than an engine at a higher rpm and running efficiently/smoothly.your best bet is an aod trans and a taller tire if you can.the lower first gear in the trans will get you out of the hole quickly and highway cruising will be very EASY on the wallet.my 2008 mustang is at 2000 rpm highway speeds and gets 30 mpg canadian gallon.now stock they have a 3.31 gear and get 35mpg but i put a gt rearend in it with 3.55 gears.keep in mind it is also supercharged and makes 350rwhp ,that's well over 400hp at the motor without the nitrous.get yourself an air/fuel gauge and wideband o2 sensor to keep an eye on things.you should be getting more mpg but your cam may be hurting you. what are the cam specs (all of them) and what is the vacuum at idle and cruising?if you go sequential you tb can go just about anywhere and the injectors won't interfere at all with hood clearence.hear is a pic of an intake i made for my stang ,notice the tb is lower down at the front.you could make a bonnet or plenum on top of the manifold and mount the tb forward or off to the side.because the sequential efi system only passes air and not fuel through the tb it can be just about anywhere.tb injectors with the injectors in the tb still must deal with fuel distribution problems to all cylinders such as fuel suspension dropout and fuel perculation on hot days especially if you race it or are a spirited driver.mutiport efi is the ONLY way to go in my opinion if you are going to switch to injection.just my 2 cents.good luck.notice the box between the runners on the manifold.it is filled with dry ice and chills the manifold to -38degrees.cold air=hp.it was worth 2 tenths of a second in back to back testing in the 1/4 mile.yes that is frost on the manifold.i just sit a six pack on it for a few minutes if i get beat out and drown my sorrows.lol
Title: Re: TBI or Carb??? Budjet ???
Post by: roverman on March 21, 2011, 02:02:29 PM
IMHO, NOT being an expert, I feel tbi's do just about everything better than carbs, especially for street use. Things like a correct air-fuel ratio, regardless of atmospheric conditions, are a big. Used/rebuilt oem systems are real cheap and adaptable to our motors. Fuel distribution ? Say (2) 2bbl/tbi's on an Offy/ 2bbl manifold, should have very good distribution.I feel tbi's also "atomize" better. Why not use Rover injection ? Good Luck, roverman.
Post by: 302GT on March 27, 2011, 07:59:03 AM
A carburetor, if properly set up will do at least as well as most TBI set-ups, and not much worse than a port injection set up once the engine is warmed up. Cold starts are a different matter.
High mileage is not really that dependent on a perfect air-fuel ratio; the real key is ignition timing. Any carburetor (if properly set up) can provide 16:1 A/F ratio at cruise. The limit to using a lean ratio is burning it. All modern fuel injected cars have an integrated engine management system of which the fuel injection is just a part. Computer control of ignition allows the use of 10:1 compression and regular gas, impossible with "old school" technology. It also allows ignition advance levels of 50 degrees or more at cruise conditions. High compression and high ignition advance contribute greatly to fuel economy, but need computerized ignition control to be practical.
A lean mixture burns slowly, a nearly closed throttle lowers actual compression to as low as 4:1; a very advanced ignition timing is needed to get the most from these conditions. With a knock sensor, timing will be advanced just short of detonation on the most sensitive cylinder (impossible with a conventional system). When the throttle is snapped open from cruise conditions, compression may go right up to 10:1 and the A/F ratio may go to 12:1. If the timing stays at 55 degrees there will be severe detonation. Computerized ignition systems can handle this easily, conventional systems cannot. Note that most of the carbureted conversion V8s run just a mechanical advance distributor, not even a vacuum advance. This gives, at most a 20 degree range to vary ignition timing, and has no provision for advancing timing at cruise conditions. No wonder carburetors give much worse economy than fuel injection...
To get the best economy, add an integrated engine management system, not just fuel injection.
Post by: BlownMGB-V8 on March 27, 2011, 11:45:35 AM
Thanks Larry, that's some pretty advanced thinking. :-)
There are a few of our cars capable of this, and our numbers are growing.
