I only found one supplier. tsimportedautomotive thats a mouthful.
Try The Wedge Shop. D&D might have one too? I hope you dont plan on driving on the street a lot with the aluminumn flywheel.
I do not want an aluminum only type. I want a steel insert type. thanks for the it is appreciated.
Hi,
A bit far for you gents but over the muddy ditch-
http://v8tuner.co.uk/product.php?id=445
Not cheap though, even before postage.
cheers John
As far as I know the aluminum flywheels sold have a steel insert.
Robert, Be easier if you stated your desired disk dia.? Single/double ? All steel for a double weighs under16 lbs." Fidanza" sells alum/steel flywheels,no Rover, but will sell "replacement"steel inserts, with bolts/nuts. I'm using for a 10.5" disk.Good Luck, roverman.
I dunno guys I think ill stick with my first option at around 400$ U.S. but clutch type. Im not sure yet Ill probably go doubble plate. I have to get the engine macined now anyways. I found helicoils in the block. but my life is on pause for military training untill x-mas.
