General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: Transmitter Man on August 29, 2010, 04:28:52 PM
Title: Crank Trigger on RV8
Post by: Transmitter Man on August 29, 2010, 04:28:52 PM
First post.
Can someone tell me if MSD's Crank Trigger kit fits the Rover V8?
http://www.msdignition.com/products/crank_triggers/crank_triggers/
This ad lists Buick's but I believe all are the V6:
http://www.jegs.com/i/MSD/121/8610/10002/-1
Many thanks.
David
TVR 420 SEAC
Title: Re: Crank Trigger on RV8
Post by: BlownMGB-V8 on August 30, 2010, 09:30:11 AM
Looks like that should work, but if you are going to consider efi any time in the future I'd suggest you consider fitting it with a 36-1 crank trigger which will give you 9 times as many position pulses per revolution for more accuracy. Some systems go much higher, but the 36-1 is a pretty cheap setup. However it does require you to find or make the trigger wheel and pick-up mount. For info, search this site and V8Buick for hits on trigger wheel and such terms.
Post by: joe_padavano on August 30, 2010, 12:20:11 PM
Better read that Jegs ad again.  The link you show is for a CHEVY V8.  The ad says it fits 78-80 Buick because those cars came with the 305 Chevy motor factory installed.
Post by: Moderator on August 30, 2010, 01:04:25 PM
Hey David, welcome to the forum!
I think Joe is right: although Buick V6 was standard equipment,  as optional equipment Buick also installed Chevy V8's of various displacements in those years. However, I'd bet some company (maybe even MSD) makes a crank trigger kit for Buick V6, and in principle it might well be adaptable to Rover. Why not give MSD a phone call? Please let us know what you find out.
Post by: minorv8 on August 30, 2010, 02:19:44 PM
Check http://trigger-wheels.com/store/index1.html?lang=en-uk&lang=en-uk&target=d14.html
Post by: v8ian on August 31, 2010, 05:19:56 PM
Ive got a TriggerWheels.com fitted to my serp Rv8, I have to machine a small land onto the back of the ballancer to locate the wheel, I also made it an interference fit so its shrunk on and retained with 2 or 3 tig weld tacks,
On my other engine, a 3.9 I made a alloy adapter ring that bolts onto the back of the ballancer and then machined to take the trigger wheel
4.6 engine.
(http://i168.photobucket.com/albums/u197/ianianstewart/Picture053.jpg)
sorry about the quality of the pic, but you should be able to see how the pickup is mounted
(http://i168.photobucket.com/albums/u197/ianianstewart/ians005.jpg)
