Low mileage Ford 8.8 posi-rear with 3.07 gears narrowed to standard MGB width (disc wheel) = 52" from hub to hub mounting face (ran 205-50ZR 15's on panasports w/ -22MM offset with no interference on lowered 77B). Rebuilt to the highest standards, original ring and pinion carefully inspected for wear and checked for proper tolerances. New Moser hi-strength axles and hubs (drilled for MGB 4-bolt pattern), bearings and seals. New Wilwood four pot disc brakes with drilled and slotted rotors. Traveled approximately 7,500 summer miles since rebuild / installation. I have ~ $2100.00 invested, asking $1500.00 or next best offer. Located in Syracuse, NY and would prefer local pick-up. If buyer wishes to arrange FOB truck freight at my home address, I will strap to standard size pallet............figure ~200 lbs. (W) 315 456-1318, (H) 315 635-8963
I'm interested in this axle as a possible upgrade for my own car. (My 8.8 has drum brakes...)
Can you please elaborate on a few things?
a) Did you find that the Wilwood brakes required a bigger master cylinder?
b) Do you have a parking brake set-up on the axle?
c) Original Traction-Lok?
d) Does the axle already have provision for a Panhard rod?
e) When you say "no interference" and that you've been running -22 wheels and 205/50 tires, I've got to wonder about that 52" hub-to-hub measurement. Can you please double-check that measurement, because I think it's only possible with modified fender flanges at the least. (I'm trying to fit -22 Panasports and 205/50 tires at the moment. I'd pay more for the axle if it's a little narrower.)
Curtis...............
a) no, but I did install a proportioning valve
b) it has internal parking brake mechanism
c) oem ford posi-traction
d) no
e) i will double check over the weekend. what i can tell is that i brought the fabricator my orignal 77 mgb rear end (w/disc wheels) with instructions to duplicate width. i should point out that i have doug jackson's complete rear suspension kit which includes panhard rod system, so lateral movement is at a minimum.
Update................took exacting measurements, width is 51" from axle hub face to hub face! With disc rotors installed it's 51 1/2"!
Apologies..........
PS: Martyn - sent you an emaill yesterday morning.
Has this been sold?
I'm interested as well
Tony
I have someone that has made a commitment to purchase..................I aplogize for the delay in responding.
Thanks for the interest!
Steve
Steve,
Where did you buy the X pipe and what is the size.
Al
Al,
FWIW, Summit sells a good mandrel bent X-pipe system in 2-1/4, 2-1/2 or 3" diameter. (2-1/4 shown below)
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D642122&N=700+400304+4294891681+115&autoview=sku
Graham
It's a 2 1/2" magnaflow "tru-x".......................summit racing.
Steve
Graham & Steve,
Thanks for the info.
Al
