General Category => MG Sports Cars => Topic started by: pspeaks on May 14, 2010, 08:23:03 PM
Title: Transmission Fluid
Post by: pspeaks on May 14, 2010, 08:23:03 PM
I'm sure it's been discussed here before but I have another dumb question.  Does a WC T-5 use Dexron II or III, and how much does it hold?  Also I was told that you can add fluid by pouring it into the shifter hole, is that true?  See, I told you it was a dumb question.          "P"
Title: Re: Transmission Fluid
Post by: motek on May 14, 2010, 10:04:12 PM
Dextron III. I think I used Dextron VI in my Tremec T5 which is the synthetic version but says on the back it is compatible with Dextron III. I pored in about three quarts into the side until it came out the side hole. Later I realized there is a top hole with a rubber bung.
Post by: pspeaks on May 15, 2010, 09:50:00 AM
Thanks George, I have to tow it home from the hanger with a tow bar this morning and need to replace fluid lost during installation because I didn't have an extra slip yoke.  If (what am I saying IF) I ever have to pull it again I'll get an extra yoke first.  Thanks again for the info,     "P"
