General Category => Engine, Transmission, & Rear Axle assy. => Topic started by: mlieb on February 28, 2010, 04:10:41 PM
Title: S-10 Rear end Swap
Post by: mlieb on February 28, 2010, 04:10:41 PM
Well I`ve been gone for a while but I made it back!!
Just got a nice rear end from a 93 S-!0 And want to make it work in my Midget.
I have the 2.8 engine and T5 transmission (from a camaro) in.
I know it will need to be narrowed but could use some ideas on suspension and getting things to go together.
Any help??
Title: Re: S-10 Rear end Swap
Post by: NixVegaGT on March 04, 2010, 08:37:04 AM
Is the midget coil springs? One thing we do for the Vega is swap out the perches and brackets from the Vega 6.5" housing to the S10 housing. Are you planning on shortening it yourself? One thing I've seen other guys doing was using thick angle iron and clamps to hold everything straight and together.
ANybody else?
Post by: Bill Young on March 04, 2010, 08:50:21 AM
Mike, it really depends on just how much you want to fabricate as far as the rear suspension. I stuck with the stock leaf springs (I did use the heavier 1500 versions) and just added some traction (anti tramp) bars and a panhard rod. Simple and reasonably effective for a street car. If you want to go with something like coil over shocks then you should look at the suspension designed by Brian Kraus for his Mazda powered car. http://www.britishv8.org/MG/BrianKraus.htm  That shouldn't be difficult to do, and although he ran the shocks up through the floor to tie into the roll cage, you could easily mount them underneath if you wish.
Clearance with the GM rear axle is good around the center section and the axle tubes aren't that much larger than the original Midget items so not much suspension movement lost there before you get into the bump stops. If you do decide to go with the leaf springs I found that stock MGB U bolts fit the GM axle and I used B spring plates and insulators as well and the stock Midget shocks should fit up to those perfectly if you want to keep the lever action shocks.
