General Category => MG Sports Cars => Topic started by: glassman on February 26, 2010, 06:59:14 PM
Title: MGB engine swap
Post by: glassman on February 26, 2010, 06:59:14 PM
Has anyone considered the installation of the Jag 6 cyl in a " B "? I just read an article where a 3.8 was very professionally and cleanly installed into a mid 60's Sprite.The car looks great and drives well with only a 3lb increase in front weight bias.It uses an XKE trans and a Toyota PU rearend, shortened of course. The magazine is Exotic and Sports Cars published by Hemmings. Just thinking of a long term retirement project.
Title: Re: MGB engine swap
Post by: Moderator on February 26, 2010, 08:39:06 PM
Thanks for posting.
I believe the car you're talking about is featured here:
<a href="http://www.britishv8.org/Other/AaronCouper.htm">Aaron Couper's Jaguar-Powered 1961 Austin Healey Sprite</a> (64 photos)
"looks great"... Certainly!
"drives well with only a 3lb increase in front weight bias"... Yeah, right!
It's a low polar moment car with tiny tires and a VERY heavy engine.
Someone might like the way it drives, but handling expectations vary widely. It won't corner like <a href="http://www.britishracecar.com/JohnMcCue-MG-Midget.htm">this Spridget</a>!
If you're were going to put that much time and money into a Sprite, and you wanted to use a vintage British engine, why not consider a true thoroughbred racing engine... like perhaps a Coventry Climax FWE?  Even for an MGB, the Jag engine is over-the-top. That's what I like in a show car... but not for carving canyons or getting groceries.
A Jag 12 has, of course, been installed in an MGB. Photos <a href="http://www.britishv8.org/MG/MGB-V12.htm">here</a>.
Post by: castlesid on February 26, 2010, 09:27:49 PM
An extra 3lbs over the front wheels!!! more like 300 but with the set back I suppose you might be able to halve that figure.
Not an ideal  swap for a B although you could probably drop one into a C without too many issues but it would still be front heavy.
Kevin
