General Category => Classified Ads: Swap Parts Here! => Topic started by: Black P-38 on January 13, 2010, 06:17:45 PM
Title: Rover 4.0/4.6 damper with 36-1 trigger wheel attached, VRS, Coils etc for MegaSquirt
Post by: Black P-38 on January 13, 2010, 06:17:45 PM
Thinking about running MegaSquirt on your Rover??? I'm selling my Damper/serp drive pulley with attached 36-1 trigger wheel, custom machined billet aluminum one piece plug to seal the cam position sensor opening in the timing cover, VR sensor, (new), VRS mounting bracket, EDIS-8 ignition module, (new), like new EDIS coil packs mounted to modified factory Rover coil pack bracket and the connectors with pigtails to wire up the module, VR sensor, coils with condensors and spout connectors.
The 36-1 trigger wheel is mounted to the rear of the damper via a custom machined brass hub adapter to keep it concentric.
I'll take $160 for all including FREE Priority Mail shipping. Quickest way to reach me is my cel: 541-808-1182
THANKS!
Mike
Title: Re: Rover 4.0/4.6 damper with 36-1 trigger wheel attached, VRS, Coils etc for MegaSquirt
Post by: Black P-38 on January 13, 2010, 06:30:12 PM
Here are a couple more pics... please note that the timing cover and water pump are shown only for display purposes and are NOT included.
I'll be posting pics of the mounted coils, new Motorcraft ignition module and wiring connectors w/pigtails shortly so please check back.
THANKS,
Mike
Post by: Black P-38 on January 13, 2010, 06:59:16 PM
Here we are...
Mike
Post by: Black P-38 on January 14, 2010, 10:34:53 PM
The EDIS-8 ignition module has been sold!!!
The remaining pieces are still available for only $99!!! That includes the Damper/serp drive pulley with attached 36-1 trigger wheel, custom machined billet aluminum one piece plug to seal the cam position sensor opening in the timing cover, VR sensor, (new), VRS mounting bracket, like new EDIS coil packs mounted to modified factory Rover coil pack bracket PLUS the connectors with pigtails to wire up the module, VR sensor, coils with condensors and spout connectors. $99 INCLUDES FREE SHIPPING!!!
Mike 541-808-1182
Post by: Black P-38 on January 15, 2010, 01:51:34 PM
Guys, this is a great deal, especially if you sell your stock damper which should easily pay half of this cost... plus the machining work is already done on the backside of the damper, the custom brass concentric adapter and good luck finding this particular 36-1 trigger wheel at an affordable price... it just happens to be the perfect size for this application. Also, mounting it BEHIND the damper keeps things compact and avoids the wiring having to cross the "belt path" as with front mounted trigger wheels.
Mike
Post by: Black P-38 on January 17, 2010, 11:33:45 AM
PRICE REDUCED TO $85.00, Shipped FREE via Priority Mail (U.S. only).
Mike
Post by: Black P-38 on January 17, 2010, 06:03:58 PM
The remaining items have been SOLD!!!
THANK YOU!!!
Mike
Post by: Mr. T on January 17, 2010, 07:14:45 PM
Dang, I got check this section more often - would have bought the LOT.
