General Category => The BritishV8 Pub => Topic started by: Mr. T on December 07, 2009, 08:04:38 PM
Title: engine stand/air compressor?
Post by: Mr. T on December 07, 2009, 08:04:38 PM
Hey folks.
The wife and kids want the xmas list. Any recommendations for an engine stand for the rover 4.6 and an electric air compressor? What do you'll recommend for psi? Does Harbor Freight have best deals on this type of stuff?
Thanks, Tony
Title: Re: engine stand/air compressor?
Post by: Bill Young on December 08, 2009, 08:04:17 AM
Hi Tony, yes HF has a pretty good engine stand for a low price but I don't recommend their compressors. They may be fine but I'm a little unsure of the support in parts later on. From what I"ve seen some of the home improvement stores such as Home Depot or Lowes usually have good deals on air compressors about this time of year and I'd think that long term parts support would be better through them.
As for the type of compressor, it depends on what you want to use it for. If you plan on running air tools or painting then I'd say nothing smaller than about a 3hp model *(and more likely a 5 hp) 220v unit would be what you need. PSI isn't nearly as important as cubic feet per minute of flow. Here's one example. http://www.lowes.com/lowes/lkn?action=productDetail&productId=102750-1126-VT6275&lpage=nonesd
The compresssor might cost a lot more but you'll get many times more use from it than the engine stand in the long run.
HF has several different engine stands, but I have one like this, I like it because of the extra stability offered by the dual front casters. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=32916
Post by: rficalora on December 08, 2009, 09:22:12 AM
Good advice from Bill.  with compressors, bigger is better; even a 5hp w/20gal tank will have trouble keeping up if you're sandblasting or using inexpensive air tools (cheap air tools tend to cosume more air).  Note that if you'll be painting with the compressor you'll want an in-line drier & the further from the compressor the better -- the air cools so water condenses out better.
Post by: Mr. T on December 08, 2009, 06:26:52 PM
Yep, good advise Gents!
Looks like the stand will take priority since I need sooner rather than later. Based on the price of that compressor that I "need", looks like I'll be doing some Craigslist surfing at some point.
No problem turning wrenches on the engine stand - it's only when you have the car jacked-up to swap-out motor mounts while lying on your back on cold concrete, contorting your body, crink in your neck, dry grease and dirt falling in your eyes and your mouth because you're huffing and puffing to contort your body, trying to get a wrench to fit in place it wasn't made to fit along with your hand, can't see bolt because you no longer have 20/20 vision and your wearing sunglasses in a garage with poor lighting because you can't find your protective glasses - the same protective glasses that are kinda fuzzy because of all the scratches and fog up anyway.....it's during these good times that I thinks to me self - maybe I'll drop my car off at my local mechanic on Friday - catch a movie and dinner with family on Saturday - watch football and have pepperoni and sausage pizza, beer and rolaids on Sunday - and pick-up my car from the local mechanic on Monday!!!
Post by: rficalora on December 08, 2009, 06:53:18 PM
Be careful with used compressors.  A lot of folks don't change the oil or filter -- until they're ready to sell it so it looks like they've properly maintained it all along.  Hard to know what you're really getting.
Post by: Mr. T on December 08, 2009, 10:40:50 PM
Yeah Rob - with only occasional use maybe I'll get lucky - even the lowly lawnmower gets more attention than the corner compressor.
Post by: rficalora on December 08, 2009, 10:56:44 PM
probably depends what you'll be doing with it.  with all the mods I made mine got a work out.  I bought a 2nd hand 80 gallon unit from a shop that used to prep marble counter tops... ended up having to replace the pump after about 6 months.  in the end I could have bought a new one for what I paid for the used one & then the replacement pump.  For what it's worth, i would recommend Eaton Compressor (www.eatoncompressor.com).  Good customer service & good value.  The advertise made in USA, but from what I gather, like most they really assemble in USA to avoid import taxes but the components are still made overseas.  They do seem to use more cast iron parts so should last longer than most imports.
Post by: BlownMGB-V8 on December 09, 2009, 12:12:38 PM
If you can swing it, an old 2 stage Champion compressor is still a pretty safe bet. Made of cast iron and all parts should still be available. They run slower than the modern compressors but last a long time. Those are the ones you see on top of welding trucks and such. Also check out what the semi tire service trucks are now using. Those would be good units also.
Post by: Mr. T on December 09, 2009, 04:14:06 PM
Will do!
Post by: rficalora on December 09, 2009, 07:01:45 PM
Good point from Jim about slower... a lot of companies -- including a lot of the big names -- are now spinning the pumps faster so they can claim more CFM.  But that wears the pump a lot faster.  One of the reasons I picked Eaton for my replacement pump was that their specs are based on slower speeds.  I'm running mine at about 750 RPM's if I recall.
Post by: BlownMGB-V8 on December 09, 2009, 09:19:05 PM
I once worked for a guy who used a compressor that was oversized for his shop. He put a smaller pulley on the motor so that the pump would turn slower and last longer.
Post by: britcars on December 30, 2009, 10:30:30 PM
Another thing to remember is to have a good high capacity filter for your intake air.  Particularly important if your shop is very dusty.  A friend adapted an old air filter system off a big block Chev.  As well, drain any moisture from your tank often.
