Rover 3.9l front cover
Started by sunwharf, February 22, 2009, 03:47:44 AM
sunwharf
Hi Folks,
I live in the UK and am having real problems locating a part. My car uses a modified version of the 1992 Land Rover 3.9l EFI engine and needs a replacement front cover (oil pump/timing case). My engine is the last type prior to the introduction of the Serpentine engine. I know I could convert to Serpentine but really want to avoid that. I have trawled the dealer network and independents in the UK and there does not seem to be one in existence. I also contacted Landrover direct and they confirmed they have none themselves.
To get the car out on the road I have fitted a cover (3.5 pre SD1 I think) sold by the MG owners club which is much earlier and missing various lugs etc.
Does anyone know of late pre-serp covers being made anywhere in the USA please?
Nick
EastCoastRoadster
I may have what you need.  I'll PM
castlesid
Nick,
I'm uk based and frequent the V8 Owners Forum, you will get very good advice and assistance from a great bunch of friendly and helpful guys.
What is actually wrong with the original front cover for the 3.9  I have one from a 93 pre serp engine in the garage somewhere.
Is this for a MGBV8 conversion? as this type of cover will not usually work  for clearance reasons.Most UK people use the SD1 cover with a P6 water pump and P6 or modded SD1 crank pulley to put the engine in the standard MGBV8 position.
http://www.v8forum.co.uk/forum/index.php?sid=df7988faa6ab21594a588ef5850a8f17
Kevin.
