Timing cover seal
Started by relative4, February 07, 2009, 05:27:37 PM
relative4
The timing cover seal on my '80 SD1 V8 needs replacing.  The standard auto parts chains sell Felpro part 15200 as the replacement, but it's a full 1/8" too wide to fit the timing cover.  Can anyone direct me to the right seal?
relative4
Bruce Mills
While searching for head gaskets last week I discovered that the gaskets are the same for all the following.
Gaskets for Buick Skylark 61-63
Buick Special Deluxe 61-63
Buick Special 61-63
Rover 3500S 69-71
MG MGB V8 75-77
MG MGB MK1V 75-77
Triumph TR8 80-81
According to D&D
"10.00 13001 Timing Cover Gaskets – For all engines, includes rope seal"
I used the following for my Rover 3.5
Timing Cover Gasket set Fel TCS 13001
Water Pump Gasket Fel 129961
Hope it helps
Bruce
relative4
Thanks, I think I've found a couple of good alternatives to the rope seal that comes with that kit.  Part ERC7987 from Moss Motors should do the job, and D&D sells part 49532 from AutoPart International; I'll check those out.  VB's item 5-805 is much lower priced, so I suspect it may be a rope seal.
Richl705
Bruce,
This is really good information.  I think it would be neat if there was a place where all this info came together.  There have been many times when I found that a part for an MGA, which was very high priced, was available more cheaply for a triumph, and it was the same part.
