Run crower 50232 with solid lifters?
Started by turbodave, November 12, 2022, 09:23:11 PM
turbodave
Thoughts on running solid vs hydraulic on a cam like this?
I already have adjustable forged rockers; just wondering if there is any significant gains to be had going solid?
You need an adjustable rocker setup or adjustable pushrods. You will gain a little top end. Acts like a smaller cam. Recommend the lifters with the small oil hole on the face. Will have to experiment with closer valve lash.
https://www.motortrend.com/how-to/solid-lifters-on-hydraulic-cam/
Was not aware you could do that.  I have the same cam still in the box patiently waiting.
I have a solid lift cam in my ol' Camaro because adjusting hydraulic lifters was so messy.
minorv8
That is a pretty mild cam. The only real reason for solid lifters is that hydraulic lifters would not allow high revs. I doubt very much that this cam requires solid lifters.
The Crower 50232 with hydraulic lifter combination is fine - ran that combo in my Olds 215...largely due to the recommendation of Dan Lagrou at D&D. who promoted that cam profile for the BOPR engine.
Using solids should result in a little more lift and duration. Not much, but the ramp used to engage the hydraulics becomes part of the cam profile instead.
