Back from vacation so time to once again try fixing my locking front brakes..nothing has worked so far
Started by limey222, September 22, 2015, 11:12:55 PM
limey222
No offence taken Jim,  and just my luck to get a bad one.  This project has been a comedy of errors in many ways, at least from my wife's viewpoint. She can't understand why I undertook it in the first place and just sees me being frustrated and disappointed all of the time, but hey, its the nature of these projects. She doesn't know that the old engine, a  Ford 2.8 V6 and 4 speed box was on its last legs.  I can tell just from the limited driving I've done with the GM 3.4 and T5 combo that its going to be amazing in comparison to the old setup.   I just want so badly to get it up and running while there is still some warm, fall weather driving to be had.
Fingers crossed that the new master cylinder will do the trick.  I have a set of recondioned caliper assemblies on hold with a local supplier just in case it proves to be them but I doubt very much that it is.  I've spent so much money on this car so far, that it would be silly to short change it so close to it being finished if i proves necessary.  The only other outstanding work will be to hook up the tach with a signal from the. coil pack.
RMO 699F
Michael, three times in my lifetime I have experienced front disc brakes locking up after a short drive in the MGB...each time I replaced both front flexible brake lines and the flexible line that goes to the rear....it cured the problem each time. The situation was the same in that after a few hours after the lock up event, the fatigued/collapsed hoses would relax and let the brake fluid back into the system and the wheels would spin freely until I drove again and applied pressure to the brake pedal. Many on this forum have much more knowledge about this issue, just relaying what has worked for me in the past.
limey222
Mike,
I appreciate your comments but my stainless braided hoses are only 6 months old, I can't believe that they are causing the problem. My problems only started after installing a new master cylinder.
limey222
OK, getting vaguely suicidal here, installed the new brake master cylinder, two of us bled these system. The other guy has worked on MG's for years.
Took off around the block (short blocks) by the time I got back to my garage I could feel the front brakes slightly dragging.  Around second time and they got progressively worse....same old problems, had to really gun it to get back up my drive.  When we were bleeding the system the brake cups were moving OK, he could see them and I could here them from inside the car.   The shuttle valve has also switched off mid-position again indicating a pressure differential.
The lines are not hot so fluid expansion is not the culprit. The problem is progressive, the more I use the brakes the worse it get until full lock up.  Cracking the front bleeders releases the brakes, what the hell can be causing the pressure build-up and not allowing a return to "tank".
No crushed lines, no collapsing hoses, sure two cylinders in row from different suppliers and manufacturers can't be bad.
There is the slight possibility that the trap valve in the MS is installed backwards (spring on outside of the valve.   People are telling me on different thread that it should cause this brake lock problem but I'm going to take things apart and make sure that its correctly installed.
Is it possible the shuttle valve is somehow acting as a check valve in the front circuit? The only thing that that seems to make sense to me is that there may be some configuration where the port to the M/C gets blocked. I bring this up only because of the way the M/C is routed into one of the side ports. The only two possibilities there that I can see might be if the piston was installed backwards or if the piston's seal location is not in spec so that it blocks off the M/C port.
limey222
it turns out that it was that darn small trap valve and spring that was installed backwards (spring on the outside) that was causing the problem. So both of the new master cylinders are good. I removed the darn thing completely as some people have been running without one for years with no detriment.
The brakes are working perfectly now.
limey222
Yes indeed, many hours wasted and dollars spent all because of maybe a 25 cent part.  Hopefully others will learn from my experience in the future.
