Engine warning light from 94 GM 3.4 PCM
Started by limey222, September 01, 2015, 07:04:38 PM
limey222
A very simple question, can anyone see a reason why I can't use a small 12v red led pilot light to signal a fault condition?  I am concerned about it having too low a resistance to ground unlike a conventional bulb.
See: http://www.ebay.com/itm/321705079086?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
limey222
kstevusa
Should be OK, I used a orange LED for C E L.
kstevusa
I just ordered an Orange 12V. led from Speedway motors assortment and connected directly to the feed from my ECM.  Nary a problem, it has illuminated; so it works.  No parallel series so is resistor needed?
danmas
QuoteGenerally, you use a resistor with a LED.
When you buy an LED labeled for 12 volts, such as these, it will have a resistor built in.
Right, Dan. I was thinking of a bare bones LED.
Kelly, in series in a basic LED application to limit the current (& adjust the brightness).
danmas
Quote... in series in a basic LED application to limit the current (& adjust the brightness)
Carl,
I used the LEDs shown in the top pic in my MG. The blue LED high beam indicator was blindingly bright compared to the others, so I had to add a resistor in series to tone it down a bit.
kstevusa
OR, just purchase from Speedway, solder and shrink wrap & mount.  No reason to complicate things  :-)
