need an MGB top door rail set
Started by DonB, October 28, 2013, 01:41:28 PM
DonB
Anyone have a set of top door rails for 70-75 MG-B?
 I've got the new chrome and biscuit covering, but the wood and foam padding is shot. Vicky B sells for $110 but they are talking 15 or more weeks out for delivery and Moss doesn't offer at all.
Want to get this thing done before the snow flies in Kansas, so now I'm going to try myself.
Don B.
Don, here is an idea for you. On my B the rails were shot and I had some thick walnut lying around. It only took a couple of days including finishing to turn that into a pair of very handsome hardwood door rails with a lot of character in the grain patterns. I used a table saw, jointer, and belt sander to get the shape of the original, matched the back side so they fit the doors right, made them thicker than OEM, and then smoothly rounded the corners and edges for a nice look and feel. They are far, far superior to the originals and even with the urethane finish wearing off now I wouldn't trade them for anything else anyone has to offer. Plus I can always refinish them any time I like.
I know you have the tools, the time, and the ability. It just isn't that hard, and it is a fun little project that really pays off for a long time to come. You should try it. If you don't have the wood you'd like contact Paxton Lumber. They have 5 stores, one of which is in Kansas City. I know the one in Cincinnati has a stock of very beautiful exotic hardwoods and they will cut it to size or get you specials sizes if you want something out of the ordinary. It's a great way to set off your car and really give it that extra touch.
DonB
Great idea! One of my local MG pals did all the interior trim in his MGC-GT in walnut and it is drop dead cool. I've had some luck in the past with both walnut and quartersawn oak on some furniture projects.
However, I'm doing the interior with MG-Biscuit so I guess I'll really need some "exotic" woods to get that yellowl/tan color match!
I bought some closed cell foam today and am in the process of protyping a pad to go on the original wood frame... then plan to cover with new material.  Better go see of the glue is dry... Hope I didn't glue it to the top of my table saw!!! If it holds, think I can use air grinder/cutoff wheel to shape the foam edges. Keep you posted.
Cheers and thanks
Don B.
Don, a little less than halfway down this page:
http://www.britishv8.org/articles/supercharged-mgb.htm
is a shot of the door with rail, panel and pocket. With the right woods you can make it about any color you like. I used a native local walnut and Birch hardwood laminated door skins.
DonB
Jim.
Nice looking job!
I think I've found a source last night. Guy is searching his inventory and I should know today.
Noting your door speaker location.... I went into the outer wall of the footwells L & R, built a waterproof surround out of two tupperware bowls and fiberglass sealer (knowing the interfender splash shields leak like a sieve) before mounting the fender, and secured my speakers there. We'll see.
In any case, thanks for the suggestions.
Don B.
BMC
Something else to consider-
I look at 1970's MGBs with the thick door top rail very similar to looking at shag carpet. I personally do not like either.
The 1968-1969 and probably 1970 door top rail is thin and just looks nicer, not over-padded like much of the stuff was overstuffed in the 1970's. Even the wood door caps that I enjoy are thinner. They just look better when they don't hang out- probably because they look taller.
Whatever the case, look for 68-69 models and see if you can figure out what i am talking about.
To each his own.
-BMC.
DonB
Great shots and suggestions... found a firm on Ebay offering new (black only) so they ordered a new set for me (in biscuit) from UK firm who makes perfect repops. A little pricey but I didn't want to spend any more time than I already had...
You can look them over next spring in Colorado.
Again, Thanks
Don B.
