A-arm spacers
Started by BlownMGB-V8, September 27, 2010, 02:14:46 PM
I had a thought last night. The angle front to rear of the LCA may cause caster changes as Fred mentions (causing the outer wheel to want to return to straight more than the inside one?) but that is also the mechanism that causes anti-dive (exactly how I still don't completely appreciate). Here the angle is slight and should only provide a small amount of anti-dive but I have heard of percentages in the 20's. I may eventually figure out how to calculate it, but based on that it looks like another of those infamous trade offs.
Before the mod, my car had a tremendous amount of caster induced steering return, enough to yank the wheel out of my hands on the autocross course and friction burn my wrist. I think that is a little excessive, but how much reduction is enough is another question entirely. But if 4* is right for a standard MGB I'd guess that half of that wouldn't be too little. Remember, we're talking about a very wide tire here, formerly a 265/50-14 and probably to be replaced with a 265/40-17, so 9-1/2" of tread width. That makes a real big difference in steering return.
Now something we've not taken into account is roll induced camber change, which I think will induce more positive camber on the outside wheel, although it will also induce more negative camber on the inside wheel. Sounds like I may want to try to control that, or else come up with a different design change. Anyone have a favorite suspension program to recommend?
Jim, this blurb from Wikipedia might help you figure out the anti dive.
In most cars it's engineered in by tilting the upper control arm more down at the rear leaving the lower control arms basically parallel to the ground. You're doing the opposite so I'm not sure how it would affect the handling. In very simple terms I always thought that it was similar to how we used to design traction bars back in the 60s. If the bar contacted the chassis to the rear of the center of gravity it would tend to lift the rear of the car on acceleration, if it was forward of the center of gravity it would tend to lift the front. Anti dive was similar in the front. If you draw a line through the pivot points of the upper and lower control arm and the intersection fell in front of the center of gravity you had a lot of anti dive, if it didn't intersect withing the wheelbase then you basically had none, and if it intersected to the rear of the center of gravity you got a lot of dive as it would tend to lift the rear. That was my take on it. No slide rule math, just seat of the pants type intuition. Right now with your spacers I'd think that the line would intersect towards the rear and cause the rear of the car to lift on braking.
Anti-dive and anti-squat
Anti-dive and anti-squat are expressed in terms of percentage and refer to the front diving under braking and the rear squatting under acceleration. They can be thought of as the counterparts for braking and acceleration as jacking forces are to cornering. The main reason for the difference is due to the different design goals between front and rear suspension, whereas suspension is usually symmetrical between the left and right of the vehicle.
To determine the percentage of front suspension braking anti-dive, it is first necessary to determine the tangent of the angle between a line drawn, in side view, through the front tire patch and the front suspension instant center, and the horizontal. Then, divide this tangent by the ratio of the center of gravity height to the wheelbase. Finally, multiply by 100. A value of 50% would mean that half of the weight transfer to the front wheels, during braking, is being transmitted through the front suspension linkage and half is being transmitted through the front suspension springs.
Forward acceleration anti-squat is calculated in a similar manner and with the same relationship between percentage and weight transfer. Anti-squat values of 100% and more are commonly used in dragracing, but values of 50% or less are more common in cars which have to undergo severe braking. Higher values of anti-squat commonly cause wheel hop during braking. It is important to note that, while the value of 100%...in either case...means that all of the weight transfer is being carried through the suspension linkage, this does not mean that the suspension is incapable of carrying additional loads (aerodynamic, cornering, etc.) during an episode of braking or forward acceleration. In other words, no "binding" of the suspension is to be implied.
You're making my head hurt.
Bill,
So does my bottle of scotch need more anti dive or anti squat?
Fred.
Maybe it just needs a few friends.  ;)
This article from BritishRaceCar.com also explains and illustrates anti-dive (and anti-squat):
<a href="http://www.britishracecar.com/PaulDudiak-McKee-Mk12c.htm">Paul Dudiak's McKee Mk12 Formula 5000 Racecar</a>
Part of the explanation is here:
QuoteIn 1969, anti-dive and anti-squat were still new concepts. After the Ford GT40, the McKee Mk12 was one
of the pioneering cars to have both anti-dive and anti-squat built in. In a nutshell, the principle of anti-dive
is that front suspension mounting points can be located strategically so the torque reaction of braking
partially cancels the suspension's tendency to plunge downward. Anti-squat is essentially the same thing,
except applied at the rear to help keep the car level under forward acceleration. Designers experimented
with anti-dive and anti-squat for better ride and to reduce camber and toe change, and their steering
effects which occur as cars take corners. But anti-dive in particular isn't something for nothing: too much
anti-dive causes cars to be "darty" and can make cars hypersensitive to bumps. It's a balance.
Modern racecars use very little anti-dive.
Interestingly enough, C5 Corvette,  LCA inner pivot is"lower" at front ! As you might guess, this accentuates anti dive and roll castor gain. Static caster is +7.4deg +/- .5deg. camber is -.20, +/- .5 deg. This works with FAT tires, up front, because of "manditory" power rack steering. I suspect those "sneaky", suspension engineers, want more wheel base on outside of turn,(cone effect/reduced slip angle), somewhat similar to"tire stagger" the oval people use, only without the "drag" on the straight-aways.This being installed in my 69' AMX, should prove to handle better, than the average Rambler.roverman.
Wasn't sure where I had the info on the air springs, but Good News Everyone! I finally found all the parts needed for the compressor kit and got everything ordered. Another week or so and all the parts should be here so I should have no trouble getting a kit together for the V8 meet. It will contain the following:
2-airbags (with centering cup and push air fittings)
1-300psi compressor (w/ 3 way cushion mounts and push fitting)
1-150psi dashboard gauge (Equis w/ push fitting)
1-bleed valve (Clippard, brass button w/ push fitting)
1-pushbutton (red w/ chrome trim ring, 5/8" hole, 1/4" spade)
3-"Y" push(insert)-to-connect line fittings
15ft-1/8" plastic air line
I've made assembly as easy and convenient as I can. Installation will involve removal of the old spring and clean up, I recommend trimming the little tab out of the way with an angle grinder for bag clearance, and if you'd like to route the air lines up out of the way you'll need to drill one or two ~1/4" holes in each spring pan and fit some rubber hose over the tubing for chafing resistance where it goes through them. Everything is just trim and insert (all air fittings are insert and push-to-connect), find a location for the compressor and drill two 5/32" holes to mount it, locate where you want the gauge and buttons, and then a little wiring for power and the switch. A Saturday morning should be all you need to get it done.
Why? Well once you're finished you can control ride height from the driver's seat. Got a problem scraping when you enter the driveway? Pump up the pressure and roll right in, let it back down when you leave. Want to lower the nose a little for a stretch of twisty road? Hit the bleed and drop it down. Plus it's sure to ride nicer with the air springs.
What I'll probably do is bring the complete kit to show and tell at the meet and take orders, plus whoever is first can buy this one and take it home when the meet is over.
I'll repost in a new thread with all the details and pictures once all the parts get here.
Will be interesting to see Jim -- I'm particularly interested in seeing wether it'd be viable & if so what would be involved in adapting to replace a coil over set up like I currently have.
Here's how the hose should be routed. As you can see it is well protected, tucked up out of harm's way and insulated by rubber hose where it might rub. Found a good spot for the compressor up in the rear corner of the engine bay.
I also redid the steering rack mounts, moving them up and forward a bit. Everything should clear nicely now, whether I use the spacer blocks or not, and there is adequate clearance to the engine. However, the straight oil filter mount will no longer work so I will have to find one from a V6 or some other SBB variety which is angled forward. I will also need to tweak the steering arms again to get them back in line with the rack.
