FS: Buick 215 Dizzy, rebuilt, Rover (BOP 215?) timing cover, pulleys
Started by Cheapsnake, November 04, 2010, 12:22:50 PM
Cheapsnake
Cleaning out the shop:
Buick 215/Rover distributor, rebuilt with new vacuum advance, new cap, Accel points eliminator and new wires.  Used for about 5 minutes for a couple bench starts before I decided to go with an EDIS (distributorless) ignition system due to space limitations.  $100
Timing cover/water pump off a Rover 4.0.  Bought it used, never installed so can't confirm condition but it's clean and sure looks good.  $75
Rover/BOP 215 valve covers, the stock stamped steel ones, all cleaned up and painted.  $25
Other stuff:
(2) new valley pan gaskets, one of them in an original Buick OEM package.  There's only one of the rubber end seals between them.  $25 each, both for $45.
(1) set of composite head gaskets.  $30
(1) set of cork valve cover gaskets. $15
(2) crank pulleys, one fits inside the other and bolt into the HB.  I'm really not sure what they're supposed to drive, bought them with a project engine and never needed them.  Clean and painted black.  $10
All prices are + shipping.  email me at ffr2776@sbcglobal.net for more info.
Tom
