4.020-inch Bore
Started by WedgeWorks1, December 11, 2009, 09:30:27 PM
WedgeWorks1
Just add some humor to this thread the cam came in and the grind is "wierdo" marked on the end of the cam. I really wonder about the guys who get orders in for some very specific requests. We now have the cam and can complete the assembly and dyno time!
NixVegaGT
Dude. I am absolutely certain that my stuff is marked that at my machine shop too. LOL! On the other hand, a couple of the machinists are pretty geared up to work on some of my ideas. Usually they are buried in the same ol' SBC stuff. Over and over.
WedgeWorks1
Its getting closer..............
tr8todd
Looks good Mike.  Is that getting a set of 340 heads?
WedgeWorks1
Dont know yet.....Tim is on the fence about it. If thing holds together its gonna rock! This is truely and experiment! We are after RPMs since it is an oversquared bore to stroke arrangement.
Mike, did you guys make your own girdle plate, or buy one somewhere? That's on my list of to-do items for the 340. Obviously the dimensions are a little different but in many ways similar.
WedgeWorks1
It was machined as a one off.
pcmenten
Looks like a 4.0/4.6 block but it's got a cam from an earlier engine.
Impressive machining to squeeze a 4" bore from that little block.
Interesting little spigots coming out of the front freeze plugs. Wild engine block.
My guess, coolant lines for heads.
NixVegaGT
Dude. I'm super keyed up to see how it turns out. Way to go, Man.
Did you guys use drawings for the girdle? That would be useful to me if you're willing to share.
WedgeWorks1
Nic, I will look into and see if he can make more plates. I can't remember if it is steel or aircraft aluminum?
Water Jet is the best way in steel or alum. At 1/3  the weight, you know my choice. Thicker alum. will ad much needed, flexure strength, in the vertical plane. Stepped studs on the pan rail= more strength. I'd loose the stock oil port. Pictured girdle will probably "hit" a 350 crank. Put the oil pick-up in a bulkhead, in side of pan. roverman.
WedgeWorks1
Ok so here is another update: IT RUNS! Pictures and maybe the video to follow!
hoffbug
April fools??? Or does it really run..
WedgeWorks1
No joke, the engine was fired up and running for about 30 minutes.
hoffbug
Cool!.. Well what was your impression? How did it do?
hoffbug
anyone? anyone? Bueller?  Bueller?
Sorry to report, Bueller is "in-comunicado", you remember, he needed a kidney ? Maybe motor hadda "bladder" problem? Who cares?- the Mopar post, is going strong, and WE "share", Mike .
tr8todd
I talked to Tim about the motor over the weekend, and he says it sounds mean.  He is running fuel injection thru a custom made intake.  The engine is going into his TR8, and he expects to see at least 350HP at the rear wheels.  Just a guess here.  I'd bet it was broken in on the dyno, and he all ready knows what it will do.   Can't wait to see this one in action.
WedgeWorks1
Todd knows what I know. I did get to see the engine now fully assembled and well impressive and I hope it does spit some serious power considering it is a reduction in displacement for rpm reasons.
WedgeWorks1
Its lives after some head issues!
Dyno time will be later after the shake down cruise!
