BRA 289
Started by Migge, July 07, 2010, 07:52:12 AM
Looking good... And like a ton-o-work!
Migge
Thanks, hope to be on the street in he next 12 months.
Migge
Well,
everything time intensive. Old fashion latches.
Migge
Bill Young
Great craftsmanship on the latches and all the other details. Are those stainless pieces?  Might have to "borrow" your design for my next project, really like the look.
Migge
Yes Bill,
stainless but will be painted black :-)
Migge
The GRP work kill me. Habe added many many layers GRP to the underside edge. Will get the curved body shape of the originals. So after adding it I have to reshape it by sanding most of it off. Also made a tow hook from M16 nuts and threaded rod to weld it to the chassis.
Migge
The old BRA body is underneath straight with a small lipp at the side to cover the outrigger steel frame a bit. Additional there is a sill along the side :-(. To get the body more (original) curved from front to end and underneath I had to laminate many many layers of GRP and had to reshape it.
Migge
Another pic from the edge and the front opening. I had to laminate a few layers to get grille mounted, later :-)
Migge
To get the right look I need the front fender spats also. I found 2 different seller in the US. One is so expensive, I asked 3 times for the price!! The other one was very helpful and the price was okay. Of course additional shipping, duty, tax :-(.
Very disappointing is: they do not fit at all. The radius is totally different and the angle to the body also and the two sides are different too. Result will be: do everything yourself or cut the body and cut the spats and reshape everything again :-(
Migge
Update: DIY!
Used some stripes of Gaffer or Duck tape to save the body and laminated 2 layer GRP on it. The Duck tape will not glue on the inside of the GRP :-) Made a rough mould of cardboard and used construction foam to fill it. Then I cut and filed the form to give it the right look and dimensions. Glued some tape on the PU foam to protect it from the next 2 layers GRP. Sorry, no pics from the finished spats
Migge
Migge
To get the fuel cap "down". Made it from aluminium and a few layers of GRP. As far as I know, only a handful had this changes made. Black one is the original Cobra.
Migge
Migge
Brackets for the aluminium doors
Migge
Worked on the steering
Migge
Migge
Pedalbox, bearing mounting for throttle etc.
Migge
Migge
Right now I'm trying to fit my alumnium doors. Another nightmare!
Migge
Before that I had to reshape the cockpit to original dimensions aka smaller.
Migge
Nothing to do with my project, just a gift for a buddy who is running a Volvo Amazone with top chop and Rover V8 inside. These Valve covers will look more period 60s. Old Rover valve covers, 2 vintage Offenhauser breathers and 2 vintage Offenhauser engine plates, sandpaper, wrinkle paint, aluminium polish and muscle grease.
Migge
Door lock brackets and door sills are done
Migge
bsa_m21
Beautiful Workmanship!  Well done.
M.
